API Samples
Face Forward Node
Outputs a floating-point, surface normal vector that is facing the view direction.
This node actually flips the surface-normal (if needed) to face in a direction opposite to I; returns the result in N.
Ports
Name Description
NThe floating-point surface-normal vector that is required to store the result.
IA floating-point, incident vector that points from the view position to the shading position.
NgA floating-point surface-normal vector.
Last update: 13.12.2021
