Physical Trigger
The Physical Trigger is an object firing callbacks when physical objects get inside or outside of it. There are 4 types of physical triggers based on their shape:
- Sphere trigger of the specified radius
- Capsule trigger of the specified radius and height
- Cylinder trigger of the specified radius and height
- Box trigger of the specified size along the axes
To be detected by the trigger, a physical object must have both a physical body (with the Physical mask that matches the Physical mask of the trigger) and a shape (with the Collision mask that matches the Collision mask of the trigger).
It is also possible to specify the Exclusion mask for the Physical Trigger that is used to prevent detecting collisions with shapes. This mask is independent of the Collision mask.
- For a body with a shape, the Exclusion mask can be set on the Physics tab of the Parameters panel.
- For the Physical Trigger, the mask can be set via C++, C# or UnigineScript API.
To avoid collision detection between a shape and a Physical Trigger, the following conditions must be met:
- The Collision mask set for the shape must match the Collision mask of the Physical Trigger.
- The Exclusion mask set for the shape must match the Exclusion mask of the Physical Trigger.
Physical objects participating in the contact with the Physical Trigger can be obtained via API. The shape of such object scan also be obtained. Moreover, you can get the depth of the object penetration, coordinates of the contact point, and its normal.
- The PhysicalTrigger class to manage Physical Trigger nodes via API
A set of samples located in the data/samples/physicals folder:
- trigger_00
- trigger_01
- trigger_02
- The fragment from the video tutorial on physics demonstrating the Physical Trigger
- Videotutorial on How To Use Physical Triggers to Catch Physical Objects
Adding Physical Trigger#
To add a Physical Trigger to the scene via UnigineEditor:
- Run the project with UnigineEditor.
On the Menu bar, click Create -> Logic -> Physical Trigger.
Click somewhere in the world to place the Physical Trigger.
A new Physical Trigger node will be added to UnigineEditor, and you will be able to edit it via the Parameters window. By default, the sphere trigger with 1-unit radius is created.
Editing Physical Trigger#
In the Physical Trigger section (Parameters window -> Node tab), you can adjust the following parameters of the physical trigger:
Edit Size |
Toggles the editing mode for the Physical Trigger node. When enabled, the size or the radius of the node (depending on its type) can be changed: each side/axis is highlighted with the colored rectangle/circle. To change the size/radius, drag the corresponding rectangle/circle. Editing of sphere-shaped physical trigger
Physical Mask | The Physical mask of the Physical Trigger must match the Physical mask of the physical object. Otherwise, the Physical Trigger won't fire callbacks when the object enters or leaves it. |
Collision Mask | |
Type | Type of the Physical Trigger: sphere, capsule, cylinder, or box. |
Size |
Size of the Physical Trigger, namely:
Setting Up Callbacks#
To add an enter or leave callback, write a callback function that receives a Body as its first argument. Then use an addEnterCallback() or addLeaveCallback method to specify the function to be called.
// add the enter callback to be fired when a body enters the physical trigger
physicalTrigger->addEnterCallback(MakeCallback(this, &AppWorldLogic::enter_callback));
// add the leave callback to be fired when a body leaves the physical trigger
physicalTrigger->addLeaveCallback(MakeCallback(this, &AppWorldLogic::leave_callback));
physicalTrigger.addEnterCallback(enter_callback);
physicalTrigger.addLeaveCallback(leave_callback);
