This example shows how to:
- Create a simple car with a frame and wheels attached to it using wheel joints.
- Enable car movement using joint motors.
- Use keyboard to control car movement.
The basic workflow of creating a simple car with keyboard control is as follows:
- Create car geometry: frame and wheels.
- Assign rigid bodies and collision shapes to the frame and just a rigid body to all the wheels.
Set up masses for the wheels and the frame.
NoticeDo not use real masses (e.g. 2000 kg for the frame and 10 kg for the wheels), as joints may become unstable! It might be better to use 64 kg for the body and 25 kg for each wheel to provide realistic behavior. - Connect the wheels to the frame using wheel joints. Set up joint parameters.
- Enable car movement using joint motors and assign movement control to corresponding keyboard keys.
The first thing we are going to address in this tutorial is the geometry of our car. We are going to create a rectangular car body and four wheels. We are also going to add some physical parameters to the geometry. So, we need two functions:
- The first one to create a box with specified parameters representing the car body:
/// function, creating a car body having a specified size, color and transformation with a body and a shape
Object createBody(string name, Vec3 size, float mass, Vec4 color, Mat4 transform)
// creating a car body and setting up its parameters (name, color and transformation)
ObjectMeshDynamic OMD = Unigine::createBox(size);
OMD.setWorldTransform(transform);
OMD.setMaterialParameterFloat4("albedo_color", color, 0);
OMD.setCollision(1, 0);
OMD.setName(name);
BodyRigid body = class_remove(new BodyRigid(OMD));
ShapeBox shape = class_remove(new ShapeBox(size));
shape.setMass(mass);
body.addShape(shape, translate(0.0f, 0.0f, 0.0f));
body.setFreezable(0);
return OMD;
- The second one to create a cylinder with specified parameters representing a wheel:
/// function, creating a wheel having a specified size and transformation
/// with a physical body and attaching it to the frame
Object createWheel(Node frame, string name, float radius, float height, float mass, Mat4 transform)
// creating a wheel, adding it to the frame as a child,
// and setting up its parameters (name, color and transformation)
ObjectMeshDynamic OMD = Unigine::createCylinder(radius, height, 1, 32);
frame.addChild(OMD);
OMD.setTransform(transform);
OMD.setMaterialParameterFloat4("albedo_color", Vec4(0.1f, 0.1f, 0.1f, 1.0f), 0);
OMD.setName(name);
// adding a rigid body
return OMD;
Now using these functions we can create our car. We are going to use DynamicMesh objects for the frame and four wheels. For a proper mass balance let us set frame mass equal to 64 kg and the mass of each wheel - to 25 kg.
// defining DynamicMesh objects for the frame and four wheels
ObjectMeshDynamic car_frame;
ObjectMeshDynamic wheels[4];
// creating car frame
car_frame = createBody("car_frame", Vec3(frame_width, frame_length, frame_height), 64.0f, Vec4(1.0f, 0.0f, 0.0f, 1.0f), transform);
// creating car wheels
// front left wheel
wheels[0] = createWheel(car_frame, "car_wheel_f_l", wheel_radius, wheel_width, 25.0f, Mat4(translate( -(frame_width + wheel_width)/2 - delta, frame_length/2 - wheel_radius, -frame_height/2) * rotateY(90.0f)));
// front right wheel
wheels[1] = createWheel(car_frame, "car_wheel_f_r", wheel_radius, wheel_width, 25.0f, Mat4(translate( (frame_width + wheel_width)/2 + delta, frame_length/2 - wheel_radius, -frame_height/2) * rotateY(90.0f)));
// rear left wheel
wheels[2] = createWheel(car_frame, "car_wheel_r_l", wheel_radius, wheel_width, 25.0f, Mat4(translate(-(frame_width + wheel_width)/2 - delta, -0.25f * frame_length,-frame_height/2) * rotateY(90.0f)));
// rear right wheel
wheels[3] = createWheel(car_frame, "car_wheel_r_r", wheel_radius, wheel_width, 25.0f, Mat4(translate((frame_width + wheel_width)/2 + delta, -0.25f * frame_length, -frame_height/2) * rotateY(90.0f)));
Adding and Setting Up Joints#
Now that we have the frame and four wheels we can attach each wheel to the frame with a wheel joint.
To create a wheel joint we call the JointWheel() constructor and then set necessary parameters:
- Rigid body of the car frame
- Rigid body of the wheel
- Anchor point coordinates (this point is determined by the position(translation) of the wheel relative to the frame)
- Coordinates of suspension axis (a vertical axis along which a wheel moves vertically and rotates when steering)
- Coordinates of wheel spindle axis (a horizontal around which a wheel rotates when moving forward or backward)
for(int i = 0; i < 4; i++)
wheel_joints[i] = class_remove(new JointWheel(car_frame.getBodyRigid(), // car frame body
wheels[i].getBodyRigid(), // car wheel body
// calculating axes and anchor coordinates
Object frame = wheel_body.getObject();
Mat4 wheel_t = frame.getTransform();
Vec3 anchor0 = Vec3(wheel_t.col3);
Vec3 anchor1 = Vec3_zero;
vec3 axis00 = vec3(0.0f, 0.0f, 1.0f);
vec3 axis10 = vec3(1.0, 0.0, 0.0);
vec3 axis11 = rotation(wheel_t) * axis10;
// setting up joint's anchor and axes
joint.setAnchor0(anchor0);
joint.setAnchor1(anchor1);
joint.setAxis00(axis00);
joint.setAxis10(axis10);
joint.setAxis11(axis11);
// setting restitution parameters
wheel_joints[i].setLinearRestitution(0.1f);
wheel_joints[i].setAngularRestitution(0.1f);
// setting linear damping and spring rigidity
wheel_joints[i].setLinearDamping(2.0f);
wheel_joints[i].setLinearSpring(40.0f);
// setting lower and upper suspension ride limits [-0.15; 0.15] and target distance
wheel_joints[i].setLinearLimitFrom(-0.15f);
wheel_joints[i].setLinearLimitTo(0.15f);
wheel_joints[i].setLinearDistance(0.0f);
// setting number of iterations
wheel_joints[i].setNumIterations(8);
Using Joint Motors#
So, we have a car, let's make it move.
To move the car forward or backward, we are going to use joint motors of the rear wheels (2 and 3):
- Setting a positive velocity value will move our car forward.
- Setting a negative velocity value will move our car backward.
See the following code:
wheel_joints[2].setAngularVelocity(velocity);
wheel_joints[3].setAngularVelocity(velocity);
wheel_joints[2].setAngularTorque(torque);
wheel_joints[3].setAngularTorque(torque);
To steer the car left or right, we are going to change Axis10 coordinates of the front wheels (0 and 1) using setAxis10() method:
wheel_joints[0].setAxis10(rotateZ(angle_0).getColumn3(0));
wheel_joints[1].setAxis10(rotateZ(angle_1).getColumn3(0));
To stop the car, we are going to set a high angular damping value for all wheels via the setAngularDamping() method:
for (int i = 0; i < 4; i++)
wheel_joints[i].setAngularDamping(20000.0f);
Adding Keyboard Controls#
To add keyboard control, we are going to make a handler for the keys that we need. The handler must be put in the world script update() function to be called for each frame. We are going to update car physics (joint motors) in the updatePhysics() method.
int update()
// forward and backward movement by setting joint motor's velocity and torque
if(engine.controls.getState(CONTROLS_STATE_FORWARD) || engine.controls.getState(CONTROLS_STATE_TURN_UP)) {
// TODO: increase velocity by delta
// set desired torque
} else if(engine.controls.getState(CONTROLS_STATE_BACKWARD) || engine.controls.getState(CONTROLS_STATE_TURN_DOWN)) {
// TODO: decrease velocity by delta
} else {
// TODO: decrease velocity gradually
// clamp velocity value
velocity = clamp(velocity,-90.0f,90.0f);
// steering left and right by changing Axis01 for front wheel joints
if(engine.controls.getState(CONTROLS_STATE_MOVE_LEFT) || engine.controls.getState(CONTROLS_STATE_TURN_LEFT)) {
// TODO: increase steering angle by some delta
} else if(engine.controls.getState(CONTROLS_STATE_MOVE_RIGHT) || engine.controls.getState(CONTROLS_STATE_TURN_RIGHT)) {
// TODO: decrease steering angle
} else {
// TODO: return steering angle to zero value gradually
// clamp steering angle value
angle = clamp(angle,-30.0f,30.0f);
// TODO: calculate steering angles for front joints (angle_0 and angle_1)
// set new Axis10 coordinates for front joints
wheel_joints[0].setAxis10(Vec3(rotateZ(angle_0).col0));
wheel_joints[1].setAxis10(Vec3(rotateZ(angle_1).col0));
if(engine.controls.getState(CONTROLS_STATE_USE)) {
// TODO: set a very high angular damping value for all joints
// set velocity to zero
} else {
// TODO: set angular damping value to zero for all joints
int updatePhysics ()
// set angular velocity for rear joints
// set torque for rear joints
Putting it All Together#
In this section let's sum up all described above and create a new class for our car. The final code for our tutorial will be as follows:
#include <core/scripts/primitives.h>
Car car = NULL;
/// function setting up bodies for a wheel joint
void setBodies(JointWheel joint, BodyRigid car_body, BodyRigid wheel_body)
joint.setBody0(car_body);
joint.setBody1(wheel_body);
OMD.setName(name);
// enabling collision detection for the frame
return OMD;
/// function, creating a wheel having a specified size, color and transformation with a body
// creating a wheel, adding it to the frame as a child, and setting up its parameters (name, color and transformation)
OMD.setName(name);
// enabling collision detection for the wheel
return OMD;
/// Car class definition
class Car
// car parameters
float frame_width;
float frame_height;
float frame_length;
float wheel_radius;
float wheel_width;
// car elements
JointWheel wheel_joints[4];
// initialization of movement parameters
float angle = 0.0f;
float velocity = 0.0f;
float torque = 0.0f;
/// Car constructor creating a car with specified frame and wheel parameters
Car(float blength, float bwidth, float bheight, float wradius, float wwidth, float wmass, Mat4 transform)
frame_width = bwidth;
frame_height = bheight;
frame_length = blength;
wheel_radius = wradius;
wheel_width = wwidth;
float delta = 0.2f;
// initialization of wheels
wheels[2] = createWheel(car_frame, "car_wheel_r_l", wheel_radius, wheel_width, 25.0f, Mat4(translate(-(frame_width + wheel_width)/2 - delta, -0.25f * frame_length, -frame_height/2) * rotateY(90.0f)));
wheels[3] = createWheel(car_frame, "car_wheel_r_r", wheel_radius, wheel_width, 25.0f, Mat4(translate( (frame_width + wheel_width)/2 + delta, -0.25f * frame_length, -frame_height/2) * rotateY(90.0f)));
// initialization of wheel joints
for(int i=0; i < 4; i++)
wheel_joints[i] = class_remove(new JointWheel());
// setting bodies and wheel parameters
setBodies(wheel_joints[i], car_frame.getBodyRigid(), wheels[i].getBodyRigid());
wheel_joints[i].setWheelRadius(wradius);
wheel_joints[i].setWheelMass(wmass);
wheel_joints[i].setLinearDamping(400.0f);
wheel_joints[i].setLinearSpring(100.0f);
/// method updating current car state with a keyboard control handler
int update()
float ifps = engine.game.getIFps();
velocity = max(velocity,0);
velocity += ifps * 50.0f;
torque = 15.0f;
velocity = min(velocity,0);
velocity -= ifps * 50.0f;
torque = 15.0f;
} else {
velocity *= exp(-ifps);
angle += ifps * 100.0f;
angle -= ifps * 100.0f;
} else {
if(abs(angle) < 0.25f) angle = 0.0f;
else angle -= sign(angle) * ifps * 45.0f;
// calculating steering angles for front joints (angle_0 and angle_1)
float base = 3.3f;
float width = 3.0f;
float angle_0 = angle;
float angle_1 = angle;
if(abs(angle) > EPSILON) {
float radius = base / tan(angle * DEG2RAD);
angle_0 = atan(base / (radius + width / 2.0f)) * RAD2DEG;
angle_1 = atan(base / (radius - width / 2.0f)) * RAD2DEG;
// enabling or disabling a brake
velocity = 0.0f;
} else {
wheel_joints[i].setAngularDamping(0.0f);
/// method updating car physics
int updatePhysics()
wheel_joints[0].setAngularVelocity(velocity);
wheel_joints[1].setAngularVelocity(velocity);
wheel_joints[0].setAngularTorque(torque);
wheel_joints[1].setAngularTorque(torque);
int init() {
engine.physics.setGravity(vec3(0.0f,0.0f,-9.8f * 2.0f));
engine.physics.setFrozenLinearVelocity(0.1f);
engine.physics.setFrozenAngularVelocity(0.1f);
//enabling collision for the ground
Object ground = node_cast(engine.world.getNodeByName("ground"));
if (ground != NULL)
ground.setCollision(1, 0);
ground.setPhysicsIntersection(1, 0);
//creating a car with specified parameters
car = new Car(4.0f, 2.0f, 0.5f, 0.5f, 0.5f, 25.0f, translate(Vec3(0.0f, 0.0f, 1.0f)));
// setting up player and controls
PlayerPersecutor player = new PlayerPersecutor();
player.setFixed(1);
player.setTarget(car.car_frame);
player.setMinDistance(6.0f);
player.setMaxDistance(11.0f);
player.setPosition(Vec3(0.0f, -10.0f, 6.0f));
player.setControlled(0);
int update() {
// updating current car state
car.update();
int updatePhysics() {
// updating car physics
car.updatePhysics();
