Landscape
The section contains settings that control rendering of Landscape Terrain.
Landscape Terrain rendering settings
All the settings are also available via Console.
Operations Per Frame |
The maximum number of Landscape texture draw operations (asyncTextureDraw) that can be performed per frame. Range of values: [1, 1000]. The default value is 10. Console access: render_landscape_operations_per_frame |
Mask Dithering |
The global dither amount multiplier to be used for rendering details of the Landscape Terrain. Dithering enables reduction of graphical artefacts in case of increased Mask Contrast values set for a detail. This is a global multiplier for dithering values set for each detail mask. Range of values: [0.0f, 1.0f]. The default value is 1.0f. Console access: render_landscape_terrain_mask_dithering |
Geometry#
Preset |
The index of the currently used Landscape Terrain geometry preset. Notice One of the following values:
Console access: render_landscape_terrain_geometry_preset |
Holes |
The value indicating if decal-based holes for the Landscape Terrain are enabled. Enabled by default.
Console access: render_landscape_terrain_geometry_holes |
Visibility Distance |
The maximum visibility distance for the Landscape Terrain, in meters. The terrain is visible, as long as the distance between the camera and the terrain does not exceed this value. Range of values: [0.0f, inf]. The default value is 30000.0f. Console access: render_landscape_terrain_visible_distance |
Customizable Settings#
Geometry Settings
Geometry Progression |
The progression of Landscape Terrain geometry tessellation. Range of values: [0.0f, 50.0f]. The default value is 1.5f. Console access: render_landscape_terrain_geometry_progression |
Geometry Fade Lods |
The intensity of fading between levels of Global Water geometry tessellation. This value can be increased to remove sharp edges between areas with different geometry density. Range of values: [0.0f, 1.0f]. The default value is 0.5f. Console access: render_water_geometry_fade_lods |
Geometry Subpixel Reduction |
The minimum ratio between the polygon size (in screen space) to the size of an area in the viewport for skipping polygons rendering (the ones having a lower ratio will be removed). Notice Setting too high values may cause small but noticeable visual artifacts when the camera moves. Range of values: [0.0f, 50.0f]. The default value is 6.0f. Console access: render_landscape_terrain_geometry_subpixel_reduction |
Geometry Polygon Size |
The size of Landscape Terrain polygons defining the maximum allowed density of Landscape Terrain geometry. Range of values: [0.0f, 1000.0f]. The default value is 0.01f. Console access: render_landscape_terrain_geometry_polygon_size |
Streaming#
Preset |
The index of the currently used Landscape Terrain streaming preset. Notice One of the following values:
Console access: render_landscape_terrain_streaming_preset |
Detail Albedo Texture Resolution |
The resolution of the albedo texture for details of the Landscape Terrain.
Console access: render_landscape_terrain_detail_resolution_albedo |
Detail Height Texture Resolution |
The resolution of the height texture for details of the Landscape Terrain.
Console access: render_landscape_terrain_detail_resolution_height |
Detail Additional Mask Texture Resolution |
The resolution of the additional mask texture for details of the Landscape Terrain.
Console access: render_landscape_terrain_detail_resolution_additional_mask |
Target Resolution |
The target resolution (width x height) for the Landscape Terrain, in pixels. 1344 х 756 - (default) Console access: render_landscape_terrain_vt_target_resolution |
Texture Filtering |
The filtering mode for the Landscape Terrain textures. The following values are available:
Console access: render_landscape_terrain_vt_filtering |
Streaming Settings
Texture Memory Size |
The value defining memory consumption for the Landscape Terrain textures. The value is interpreted as follows:
Range of values: [0.0f, 1.0f]. The default value is 0.4f. Console access: render_landscape_terrain_vt_memory_size |
Detail Level By Angle |
The value indicating detail level reduction depending on the inclination of the the Landscape Terrain polygons relative to viewing direction. Can be used to reduce streaming load and memory consumption. The value of 1 corresponds to the pixel-to-pixel quality, and lower values decrease it. Range of values: [0.0f, 1.0f]. The default value is 0.95f. Console access: render_landscape_terrain_vt_detail_level_by_angle |
Tiles Update Per Frame |
The number of tiles passed to the virtual texture of the Landscape Terrain each frame. Range of values: [1, 256]. The default value is 60. Console access: render_landscape_terrain_vt_tiles_update_per_frame |
Tiles Load Per Frame |
The number of Landscape Terrain tiles loaded per frame. You can decrease the value of this parameter to reduce spikes, but in this case streaming becomes slower and more noticeable. Range of values: [1, 64]. The default value is 4. Console access: render_landscape_terrain_vt_tiles_load_per_frame |
Tiles Reload Per Frame |
The number of tiles to be reloaded per frame after applying changes to the Landscape Terrain surface. Range of values: [1, 64]. The default value is 4. Console access: render_landscape_terrain_vt_tiles_reload_per_frame |
Texel Size |
The texel size of the Landscape Terrain render textures representing the maximum level of detail for the albedo, normal, and height components of the Landscape Terrain. Range of values: [0.0001f, 1.0f]. The default value is 0.001f. Console access: render_landscape_terrain_texel_size |
Culling#
Culling Aggressive |
The value indicating if frustum culling optimization is enabled for the Landscape Terrain. When enabled, the number of culled polygons increases thereby increasing performance. In case of any issues with polygons rendering, try disabling this option (however, note that performance may drop). Enabled by default.
Console access: render_landscape_terrain_culling_aggressive |
Culling Frustum Padding |
The multiplier for the size of viewing frustum to be used for culling polygons of the Landscape Terrain (value, by which the borders of the current frustum are increased). Frustum culling is performed for the frustum of the increased size. By the maximum value of 1, the frustum borders will be increased by the size of the current frustum. Range of values: [0.0f, 1.0f]. The default value is 0.1f. Console access: render_landscape_terrain_culling_frustum_padding |
Culling Back Face |
The threshold used for culling tessellation patches of the Landscape Terrain oriented to the camera with their back faces (it is a multiplier for the angle between the tessellation patch normal and the camera's view direction). Higher values result in a smaller angle between the patch normal and the camera's view direction required for culling this patch. Range of values: [0.0f, 1.0f]. The default value is 0.5f. Console access: render_landscape_terrain_culling_back_face |
Culling Oblique Frustum |
The multiplier for culling of tessellation patches of the Landscape Terrain beyond the oblique frustum plane. Higher values result in more patches culled. Range of values: [0.0f, 1.0f]. The default value is 0.9f. Console access: render_landscape_terrain_culling_oblique_frustum |
Cache#
CPU Cache Size |
The CPU cache size to be used for landscape terrain rendering, in percentage of the total memory. CPU cache size affects intersections, physics, streaming, etc. The size of CPU cache depends on the scene. Range of values: [1, 100]. The default value is 10. Console access: render_landscape_cache_cpu_size |
GPU Cache Size |
The GPU cache size to be used for landscape terrain rendering, in percentage of the total GPU memory. GPU cache is used to accumulate tiles, that are visible to the camera, before streaming them to the megatexture.
Notice High-resolution maps require larger cache capacity. Range of values: [1, 100]. The default value is 4. Console access: render_landscape_cache_gpu_size |
GPU Cache Life Time |
The lifetime of GPU cache used for Landscape Terrain rendering, in frames. Range of values: [1, 60]. The default value is 4. Console access: render_landscape_cache_gpu_life_time |
