Face Forward Node
Outputs a floating-point, surface normal vector that is facing the view direction.
This node actually flips the surface-normal (if needed) to face in a direction opposite to I; returns the result in N.
Ports
Name | Description | |
![]() | N | The floating-point surface-normal vector that is required to store the result. |
![]() | I | A floating-point, incident vector that points from the view position to the shading position. |
![]() | Ng | A floating-point surface-normal vector. |
Была ли эта статья полезной?
