app_wall_00
You should upgrade to- Sim
SDK edition to use it.
This article describes the <UnigineSDK>/data/samples/plugins/app_wall_00.cpp sample.
The app_wall_00 sample demonstrates how to render an interface across all of the available monitors with the Wall plugin. In this sample, the engine.wall.getGui() function is used to get a GUI instance for each monitor.
It is required to launch the Wall plugin before running the sample.
Interface rendering across 2 monitors (2×1 configuration) with Wall.
The monitor with the 0×0 label is the primary by default. You can change it via the engine.wall.setPrimary() function.
- Article on the Wall plugin
- engine.wall functions
- GUI-related classes to implement a required interface
