Basic Object Movements
After adding an object to UNIGINE, you can control its transformations with your control devices. This article shows how to control basic object movements and combine different transformations.
Direction Vector#
The direction vector is an important concept of mesh transformation. To move the node forward, you should know where the forward direction of the mesh is. When the mesh is exported from a 3D editor, it saves the information about the forward direction. And when you add the mesh to UNIGINE, it has the same orientation it had in a 3D editor.
A mesh in Maya
The same mesh in UNIGINE
In the images above, the direction vector has the positive Y direction. To move this mesh forward, you should get the direction of the mesh by using the Y component (the second column) of the world transformation matrix of the mesh.
The point is that content creators and programmers should make an arrangement about the direction vector.
Basic Movements#
Prearrangement#
We are going to make a component that allows moving and rotating an object. To make the explanation unobstructed, we give supplementary parts of code and additional links here. The complete code is provided at the bottom of this article.
To use the component system, we need to initialize it. This is done in AppSystemLogic.cpp as follows:
#include "AppSystemLogic.h"
int AppSystemLogic::init()
We need the camera to observe the scene and an object that we are going to manipulate. We define these two nodes in AppWorldLogic.h and add all related logic in AppWorldLogic.cpp:
#include <UnigineLogic.h>
#include <UnigineStreams.h>
#include <UnigineObjects.h>
#include <UniginePlayers.h>
	AppWorldLogic();
	virtual ~AppWorldLogic();
	int init() override;
	int update() override;
	int postUpdate() override;
	int updatePhysics() override;
	int shutdown() override;
	// define the ObjectMeshStatic instance
	// so that it will be deleted with the AppWorldLogic instance
	Unigine::ObjectMeshStaticPtr mesh;
	//define the player camera
	Unigine::PlayerPtr player;
#include "AppWorldLogic.h"
#include <UnigineMathLib.h>
#include <UnigineGame.h>
#include <UnigineMesh.h>
AppWorldLogic::AppWorldLogic(){}
AppWorldLogic::~AppWorldLogic(){}
int AppWorldLogic::init()
	// get the current game camera
	player = Game::getPlayer();
	// set the camera position and direction to look at the object
	player->setPosition(Vec3(4.0f, -3.401f, 1.5f));
	player->setDirection(vec3(0.0f, 1.0f, -0.4f), player->getUp());
	// create the ObjectMeshStatic by using the new mesh
	mesh = ObjectMeshStatic::create("core/meshes/box.mesh");
	// set the mesh position
	mesh->setPosition(Vec3(4.0f, 0.0f, 1.0f));
Creating and Adding the Property#
We are going to write the code that controls the object's movements as a separate component to make it reusable. Create a new C++ class (the header and .cpp files) in the project. Let's name this component MovementControls. You can also check this article for more details about adding components.
#pragma once
class MovementControls : public Unigine::ComponentBase
	COMPONENT_DEFINE(MovementControls, Unigine::ComponentBase);
	COMPONENT_INIT(init);
	COMPONENT_UPDATE(update);
	void init();
	void update();
#include "MovementControls.h"
#include <UnigineControls.h>
#include <UnigineEditor.h>
REGISTER_COMPONENT(MovementControls);
void MovementControls::init() {
void MovementControls::update() {
And to assign this property to the mesh we want to move, we add the following line in the init() method in AppWorldLogic.cpp:
	// assign the movement controlling property to the mesh
	mesh->addProperty("MovementControls");
Moving Forward#
This section demonstrates how to set the forward movement of the mesh.
In this example, we use the "p" key pressing to move the mesh forward. The direction vector is visualized for clarity.
In MovementControls.h, we add the property parameters to access them via Editor and set their initial values:
#pragma once
	// define the property parameters that can be adjusted via the Editor as well
	PROP_PARAM(Node, moving_node);
	// define the movement speed
	PROP_PARAM(Float, movement_speed, 5.0f);
	void init();
	void update();
In MovementControls.cpp, we add the movement-related logic:
	// enable visualizer
	Visualizer::setEnabled(1);
	// check if the key is pressed and update the state of the specified control
	ControlsApp::setStateKey(Controls::STATE_AUX_0, 'p');
	// get the frame duration
	float ifps = Game::getIFps();
	// get the current world transformation matrix of the node this property is assigned to
	Mat4 transform = node->getWorldTransform();
	// get the direction vector of the node from the second column of the transformation matrix
	Vec3 direction = transform.getColumn3(1);
	// render the direction vector for visual clarity
	Visualizer::renderDirection(node->getWorldPosition(), vec3(direction), vec4(1.0f, 0.0f, 0.0f, 1.0f), 0.1f, 0);
	// check if the control key is pressed
	if (ControlsApp::getState(Controls::STATE_AUX_0)) {
		// calculate the delta of movement
		Vec3 delta_movement = direction * movement_speed * ifps;
		// set a new position to the node
		node->setWorldPosition(node->getWorldPosition() + delta_movement);
Another Way of Setting Mesh Position
The new position can be also set by setting the WorldTransform variable. The following examples contain the code from the Update() function of the AppWorldLogic class. The part of controls initialization is the same for this method, the difference is in the Update() function only.
	node->setWorldTransform(translate(delta_movement) * transform);
Or you can change the translation column of the world transformation matrix (see the Matrix Transformations article) to move the node:
// check if the control key is pressed.
	// here, you can also use transform.setColumn3(3, transform.getColumn3(3) + delta_movement);
	transform.setColumn(3, transform.getColumn(3) + Vec4(delta_movement, 1.0f));
	// set a new world transform matrix to the mesh
	node->setWorldTransform(transform);
Rotation#
This section contains implementation of the mesh rotation.
You can rotate the mesh in two ways, by changing the transformation matrix represented by the WorldTransform variable (recommended way) or via the SetWorldRotation() function. The following example uses the second one:
#pragma once
	// define the rotation speed
	PROP_PARAM(Float, rotation_speed, 30.0f);
	void init();
	void update();
	ControlsApp::setStateKey(Controls::STATE_AUX_1, 'o');
	if (ControlsApp::getState(Controls::STATE_AUX_1)) {
		// set the node rotation along the Z axis assuming node's scale equal to 1
		node->setWorldRotation(node->getWorldRotation() * quat(rotateZ(rotation_speed * ifps)), 1);
In the example above, the node is rotated to the left by pressing the "o" keyboard key.
  • It is recommended to set the second argument of the SetWorldRotation() function to 1 for all non-scaled nodes to improve performance and accuracy.
  • Scaling of nodes should be avoided whenever possible, as it requires addidional calculations and may lead to error accumulation.
To rotate the object by via the WorldTransform variable, you should replace the line containing the SetWorldRotation() function in the example above with the following one:
node->setWorldTransform(node->getWorldTransform() * Mat4(rotateZ(rotation_speed * ifps)));
This way is preferred, especially in case of complex transformations, as it allows to compose the transformation matrix and set it only once.
Combining Movements#
Combining different movement controls is not more difficult than adding only one movement control.
The following code is an example that adds a mesh to the world and assigns a component on it that allows controlling its movements. You can rotate the mesh by using the "o", "[" keyboard keys and move forward by using the "p" key.
AppSystemLogic::AppSystemLogic(){}
AppSystemLogic::~AppSystemLogic(){}
// start of the main loop
int AppSystemLogic::update()
	// Write here code to be called before updating each render frame.
int AppSystemLogic::postUpdate()
	// Write here code to be called after updating each render frame.
// end of the main loop
int AppSystemLogic::shutdown()
#ifndef __APP_WORLD_LOGIC_H__
#define __APP_WORLD_LOGIC_H__
	AppWorldLogic();
int AppWorldLogic::update()
int AppWorldLogic::shutdown()
	// Write here code to be called on world shutdown: delete resources that were created during world script execution to avoid memory leaks.
	// Write here code to be called when the world is saving its state (i.e. state_save is called): save custom user data to a file.
	UNIGINE_UNUSED(stream);
	// Write here code to be called when the world is restoring its state (i.e. state_restore is called): restore custom user data to a file here.
#pragma once
	void init();
	void update();
	// you can use both 'p', 'o', '[' or ASCII codes (112, 111, 113)
	ControlsApp::setStateKey(Controls::STATE_AUX_2, '[');
	// initialize the update flag and declare rotation and movement
	int update_transform = 0;
	Mat4 rotation;
	Vec3 delta_movement;
	// check if the control key for movement is pressed
		update_transform = 1;
	// check if the control key for left rotation is pressed
		// set the node left rotation along the Z axis
		rotation.setRotateZ(rotation_speed * ifps);
	// check if the control key for right rotation is pressed
	else if (ControlsApp::getState(Controls::STATE_AUX_2))
		// set the node right rotation along the Z axis
		rotation.setRotateZ(-rotation_speed * ifps);
	// update transformation if necessary
	if (update_transform)
		// combine transformations: movement + rotation
		transform = transform * rotation;
		// set the resulting transformation
void MovementControls::forward() {
void MovementControls::position_var_1() {
void MovementControls::position_var_2() {
void MovementControls::rotation_var_1() {
void MovementControls::rotation_var_2() {
Last update: 19.12.2023
