landscape_terrain_base
The landscape_terrain_base material is a default material for Landscape Terrain objects. Via this material, you can manage different options for terrain optimization and control the post processing for terrains.
Terrain textures are assigned via the landscape_terrain_detail_base material used by Landscape Layer Maps.
To adjust the landscape_terrain_base material, open the Surfaces tab of the Parameters window:
Parameters window, Surfaces tab.
Surface Material Parameters#
Common#
Common material settings.
Base#
Material Mask is a bit mask used for decal projection onto the Landscape Terrain surface.
Post Processing#
- Material SSAO — enables Screen-Space Ambient Occlusion post for Landscape Terrain.
- Material SSR — enables Screen-Space Reflections post for Landscape Terrain.
- Material SSSSS — enables Screen-Space Sub-Surface Scattering post for Landscape Terrain.
- Material DOF — enables the Depth of Field post effect for Landscape Terrain.
- Material Motion Blur — enables the Motion Blur effect for Landscape Terrain.
- Material Screen-Space Shadows — enables the Screen-Space Shadows effect for Landscape Terrain.
Была ли эта статья полезной?
