Package Class
The Package class is a data provider for the internal FileSystem class. You can load all the resources via this class. This article describes the sample located in the <UnigineSDK>/source/csharp/samples/Api/Systems/Package/ directory.
- An example can be found in the <UnigineSDK>/source/csharp/samples/Api/Systems/Package/ directory.
- The C++ API Unigine::Package class and the Unigine::FileSystem class which have the same methods and behavior as in the C# API.
Package Class Usage Example#
C# Side#
To use the Unigine.Package class, you should create your own class and inherit it from the Unigine.Package class and override virtual methods.
using System;
using System.IO;
using File = System.IO.File;
using System.Runtime.InteropServices;
using Unigine;
class UnigineApp {
* Create a class and inherit if from Unigine.Package
class MyPackage : Package {
private FileStream file;
// list of files
public override int getNumFiles() {
Log.Warning("MyPackage.getNumFiles(): called\n");
return 2;
public override string getFileName(int num) {
Log.Warning("MyPackage.getFileName({0}): called\n",num);
if(num == 0) return "data/package.cpp";
if(num == 1) return "data/package.world";
return "";
// select file
public override int selectFile(string name,out int size) {
Log.Warning("MyPackage.selectFile(\"{0}\",): called\n",name);
try {
file = null;
if(name == "data/package.cpp") file = File.OpenRead("my_data/package.cpp");
if(name == "data/package.world") file = File.OpenRead("my_data/package.world");
catch(Exception e) {
Log.Error("MyPackage.selectFile(): {0}\n",e.Message);
size = 0;
return 0;
size = (int)file.Length;
// read file
public override int readFile(IntPtr data,int size) {
Log.Warning("MyPackage.readFile(,{0}): called\n",size);
try {
byte[] src = new byte[size];
int ret = file.Read(src,0,size);
Marshal.Copy(src,0,data,ret);
Log.Error("MyPackage.readFile(): {0}\n",e.Message);
return 0;
[STAThread]
static void Main(string[] args) {
// create an instance of the MyPackage class and add it to the FileSystem
MyPackage package = new MyPackage();
FileSystem.preloadExternPackage(package);
// initialize engine
Engine engine = Engine.Init(Engine.VERSION,args);
// enter main loop
engine.Main();
// shutdown engine
Engine.Shutdown();
The MyPackage class has overridden readFile(), selectFile(), getFileName() and getNumFiles() functions. The class operates with two files located in the my_data folder. In the Main() function we create an instance of the MyPackage class and add it to the FileSystem.
Unigine Script Side#
In the UnigineScript package.cpp file:
Output#
The following result will be shown:
In the console:
MyPackage.selectFile("data/package.cpp",): called
MyPackage.readFile(,866): called
Loading "data/package.cpp" 4ms
MyPackage.selectFile("data/package.world",): called
MyPackage.readFile(,62): called
Loading "data/package.world" 0ms
Hello from My C# Package
