Unigine::ObjectMeshSplineCluster Class
Inherits from: Object
Members
static int type ( ) #
Returns the type of the node.
Return value
Node type identifier.
const char * getMeshName ( ) const#
Returns the name of the mesh handled by a mesh spline cluster.
Return value
Mesh name.
int getNumMeshes ( ) const#
Returns the total number of meshes handled by the mesh spline cluster.
Return value
Number of meshes.
Math::mat4 getMeshTransform ( int num ) const#
Returns the transformation of the given mesh instance.
Arguments
  • int num - Mesh instance number.
Return value
Mesh transformation matrix.
bool getClusterTransforms ( const Math::WorldBoundBox & bounds, Vector< Math::mat4 > & transforms ) #
Collects transformations (local coordinates) for all spline cluster meshes within the area specified by the given bounding box and puts them to the specified buffer.
Arguments
  • const Math::WorldBoundBox & bounds - Bounding box, defining the area, for which the transformations of spline cluster meshes are to be collected.
  • Vector< Math::mat4 > & transforms - Buffer to store transformations of spline cluster meshes.
Return value
true, if there are transformations of spline cluster meshes; or false, if there are no transformations of spline cluster meshes found.
bool getClusterWorldTransforms ( const Math::WorldBoundBox & bounds, Vector< Math::Mat4 > & transforms ) #
Collects transformations (world coordinates) for all spline cluster meshes within the area specified by the given bounding box and puts them to the specified buffer.
Arguments
  • Vector< Math::Mat4 > & transforms - Buffer to store transformations of spline cluster meshes.
Return value
int getNumSurfaceTargets ( int surface ) const#
Returns the total number of surface targets.
Arguments
  • int surface - Surface number.
Return value
Total number of surface targets.
const char * getSurfaceTargetName ( int surface, int target ) const#
Returns the name of a given surface target.
Arguments
  • int target - Target number.
Return value
Target name.
int findSurfaceTarget ( const char * name, int surface ) const#
Searches for a surface target with a given name.
Arguments
  • const char * name - Target name.
Return value
Target number if it exists; otherwise, -1.
Last update: 07.04.2022
