Unigine::Mesh Class
Header: #include <UnigineMesh.h>
Mesh class is a container and provides an interface for mesh loading, manipulating and saving.
By using this class, you can create a mesh, add geometry to it (e.g. box, plane, capsule or cylinder surface), add animations and bones (if you want to create a skinned mesh) and then use it to create the following objects:
Also you can get geometry of all of these objects via the Mesh class.
Features of the mesh are listed below:
  • Each surface of the mesh supports several morph targets.
  • Each surface has a quaternion-based tangent basis for the better loading speed.
  • 8-bit vertex colors are supported.
  • Each vertex of a surface has 2 sets of indices: coordinate and triangle indices. It improves the loading speed and reduces data duplication.
  • Each vertex of a surface has 2 UV sets.
  • A bind pose transformation is stored for each mesh (even if there are no animations and animation frames). See also the getBoneTransfroms() method.
    The 1st animation frame should not contain the bind pose.
Vertex Data and Indices#
Each surface of the mesh consists of triangles, and each triangle has 3 vertices. Thus, for each mesh surface we have:
Total number of vertices = 3 * number of triangles.
If a vertex belongs to several triangles, we have to store several copies of such vertex. Each of these copies would store information about position, normal, binormal, tangent and texture coordinates. In order to reduce data duplication and increase loading speed UNIGINE uses the optimization described below.
There are 2 separate vertex data buffers are used:
  • CVertices coordinate buffer, which stores only vertex coordinates.
  • TVertices triangle buffer, which stores vertex attributes such as normal, binormal, tangent, color, UV coordinates.
On the picture below, two examples are given (arrows are used to show normals):
Both surfaces contain 2 adjacent triangles. Here C0...C3 are coordinate vertices, T0...T5 are triangle vertices
The coordinate buffer is an array of coordinate vertices. Each coordinate vertex contains coordinates (float[3]) of the vertex. For example, the coordinate buffer for the surfaces presented on the picture above is the following:
Output
CB = [C0,C1,C2,C3]
The triangle buffer is an array of triangle vertices. For example, the triangle buffer for the surface presented on the left picture above is the following:
Output
TB = [T0,T1,T2,T3,T4,T5]
The coordinate and triangle buffers describe the same surface. Both of these buffers are required to describe the final surface. The actual amount of final vertices is the number of tvertices.
The surface presented on the right picture above consist of 2 triangles with 2 vertices (C1 and C3) which have the same normal attributes (T1 and T3) compared to the surface on the left (where C1 and C3 have more than one attribute). So the triangle buffer of vertices for the surface on the right is:
Output
TB = [T0,T1,T2,T3]
Each triangle vertex can store:
  • Normal
  • Binormal
  • Tangent
  • 1st UV map texture coordinates
  • 2nd UV map texture coordinates
  • Color
The number of coordinate vertices and triangle vertices can be different.
The number of triangle vertices depends on the number of triangles, to which the vertex belongs. For example, if 2 triangles have an adjacent vertex with different normals for each triangle, 2 triangle vertices will be stored (relevant for vertices C1 and C3 on the left picture above). However, if the attributes of the vertex are the same for all of the adjacent triangles, only 1 triangle vertex will be stored (relevant for vertices C1 and C3 on the right picture above).
Both the coordinate and triangle vertices have indices. There are 2 index buffers to get proper cvertex and tvertex data for each vertex of mesh surface:
  • CIndices buffer — coordinate indices, which are links to CVertices data.
  • TIndices buffer — triangle indices, which are links to TVertices data.
The number of elements in these index buffers is equal to the total number of vertices of a mesh surface.
Coordinate Indices#
Each vertex of a mesh surface has a coordinate index - a number of the corresponding element of the coordinate buffer, where the data is stored. For the given surface the array of the coordinate indices is as follows:
Output
CIndices = [Ci0,Ci1,Ci3,Ci1,Ci2,Ci3]
Here:
  • The first 3 elements are the coordinate indices of the first (bottom) triangle.
  • The second 3 elements are the coordinate indices of the second (top) triangle.
Triangle Indices#
Each vertex of a mesh surface also has a triangle index - a number of the corresponding element of the triangle buffer, where the data is stored. For the given surface on the left the array of the triangle indices is as follows:
Output
TIndices = [Ti0,Ti1,Ti5,Ti2,Ti3,Ti4]
Here:
  • The first 3 elements are the triangle indices of the first (bottom) triangle.
  • The second 3 elements are the triangle indices of the second (top) triangle.
For the surface on the right the array of the triangle indices is a bit different (both triangles share data for vertices C1 and C3):
Output
TIndices = [Ti0,Ti1,Ti3,Ti1,Ti2,Ti3]
The number of the coordinate and triangle indices is the same.
Serialization#
You can save your created mesh to a file to be used later via the save() method. Later on, you can create a new mesh from this file using the constructor, or load a mesh via the load() method.
Normals of mesh are not serializable. The whole tangent basis is serialized instead.
So, to get your normals from a saved mesh you should do the following:
// adding a surface and vertices to the mesh
MeshPtr mesh = Unigine::Mesh::create();
mesh->addSurface("0");
mesh->addVertex(Unigine::Math::vec3(1.f, 1.f, 0.f), 0);
mesh->addVertex(Unigine::Math::vec3(1.f, 0.f, 1.f), 0);
mesh->addVertex(Unigine::Math::vec3(0.f, 1.f, 1.f), 0);
// create normals
mesh->addNormal(Unigine::Math::vec3(0.f, 0.f, 1.f), 0);
// adding vertex indices
mesh->addIndex(0, 0);
mesh->addIndex(1, 0);
mesh->addIndex(2, 0);
// creating serializable tangent basis
mesh->createTangents();
// saving a mesh to a file
mesh->save("hello.mesh");
Now to get your normals after creating a mesh from a file:
// creating a mesh from a previously saved file
MeshPtr mesh = Unigine::Mesh::create("hello.mesh");
// getting the total number of vertex tangent entries for the first surface of the mesh
auto numTangents = mesh->getNumTangents(0);
// retrieving normals from the tangent basis for the first point of the first surface of the mesh
auto normal = mesh->getTangent(0, 0).getNormal();
Mesh Class
Enums
LIGHTMAP_RESOLUTION#
Resolution of lightmaps to be generated for a surface.
NameDescription
LIGHTMAP_RESOLUTION_MODE_32 = 0Lightmap resolution 32 x 32.
LIGHTMAP_RESOLUTION_MODE_64 = 1Lightmap resolution 64 x 64.
LIGHTMAP_RESOLUTION_MODE_128 = 2Lightmap resolution 128 x 128.
LIGHTMAP_RESOLUTION_MODE_256 = 3Lightmap resolution 256 x 256.
LIGHTMAP_RESOLUTION_MODE_512 = 4Lightmap resolution 512 x 512.
LIGHTMAP_RESOLUTION_MODE_1024 = 5Lightmap resolution 1024 x 1024.
LIGHTMAP_RESOLUTION_MODE_2048 = 6Lightmap resolution 2048 x 2048.
LIGHTMAP_RESOLUTION_MODE_4096 = 7Lightmap resolution 4096 x 4096.
Members
static MeshPtr create ( ) #
Constructor. Creates an empty mesh.
static MeshPtr create ( const char * name ) #
Constructor. Creates a mesh using the specified file.
Arguments
  • const char * name - Path to the mesh file.
static MeshPtr create ( const Ptr<Mesh> & mesh ) #
Constructor.
Arguments
  • const Ptr<Mesh> & mesh - Mesh instance.
void assignFrom ( const Ptr<Mesh> & mesh ) #
Copies the data including bones, surfaces, and animations from the specified source mesh.
Arguments
  • const Ptr<Mesh> & mesh - Source mesh instance.
void setAnimationBones ( int animation, const Vector< short > & bones ) #
Copies bones from the given array to the current array of animation bones.
Arguments
  • int animation - Animation number.
  • const Vector< short > & bones - Array of bones taking part in the animation to be set.
void getAnimationBones ( int animation, Vector< short > & bones ) const#
Adds all bones of the given animation to the given array of bones.
Arguments
  • Vector< short > & bones - Array with indices of bones taking part in the animation.
void setAnimationFrame ( int animation, int num, const Vector< Math::vec3 > & xyz, const Vector< Math::quat > & rot, const Vector< Math::vec3 > & scale ) #
Updates the animation frame coordinates, rotation quaternions and scaling vectors.
Arguments
  • int num - Frame number in the array of the animation frames.
  • const Vector< Math::vec3 > & xyz - Array with coordinates of the animation frame.
  • const Vector< Math::quat > & rot - Array with rotation quaternions of the animation frame.
  • const Vector< Math::vec3 > & scale - Array with scaling vectors of the animation frame.
void setAnimationFrame ( int animation, int num, const Vector< Math::mat4 > & frames ) #
Arguments
  • const Vector< Math::mat4 > & frames - Matrix that includes coordinates, rotation quaternions and scaling vectors of the animation frame.
void getAnimationFrame ( int animation, int num, Vector< Math::vec3 > & xyz, Vector< Math::quat > & rot, Vector< Math::vec3 > & scale ) const#
Adds the animation frame coordinates, rotation quaternions and scaling vectors to the given matrix passed to the function as the third argument. The matrix can be set by using the setAnimationFrame() method.
Arguments
  • Vector< Math::vec3 > & xyz - Array with coordinates of the animation frame.
  • Vector< Math::quat > & rot - Array with rotation quaternions of the animation frame.
  • Vector< Math::vec3 > & scale - Array with scaling vectors of the animation frame.
void getAnimationFrame ( int animation, int num, Vector< Math::mat4 > & frames ) const#
Arguments
  • Vector< Math::mat4 > & frames - Matrix that includes coordinates, rotation quaternions and scaling vectors of the animation frame.
void setAnimationName ( int animation, const char * name ) #
Sets a name for the given animation.
Arguments
  • const char * name - Animation name to be set.
const char * getAnimationName ( int animation ) const#
Returns the name of the given animation.
Arguments
Return value
Animation name.
void setBoneName ( int bone, const char * name ) #
Sets a name for the given bone.
Arguments
  • int bone - Bone number.
  • const char * name - Bone name to be set.
const char * getBoneName ( int bone ) const#
Returns the name of the given bone.
Arguments
Return value
Bone name.
void setBoneParent ( int bone, int parent ) #
Sets the parent bone for the given one.
Arguments
  • int bone - Bone number, for which the parent bone should be set.
  • int parent - Bone to be set as a parent.
int getBoneParent ( int bone ) const#
Returns the number of the parent bone of the given one.
Arguments
  • int bone - Bone number, for which the parent bone will be returned.
Return value
Parent bone number.
void setBoneTransform ( int bone, const Math::mat4 & transform ) #
Sets the transformation matrix for the given bone.
Arguments
  • const Math::mat4 & transform - Transformation matrix to be set.
Math::mat4 getBoneTransform ( int bone ) const#
Returns the transformation matrix for the given bone.
Arguments
Return value
Transformation matrix.
int setBoneTransforms ( const Vector< Math::mat4 > & transforms, int animation = -1, int frame = 0 ) #
Updates the array of the world-space transformation matrices for bones of the given animation frame.
If the passed animation number is -1, the bind pose will be updated to the given array.
Arguments
  • const Vector< Math::mat4 > & transforms - Array of transformation matrices to be set. Its size must be equal to the number of animation bones.
  • int animation - Animation number. The default value is -1.
  • int frame - Animation frame number. The default value is 0.
Return value
Returns 1 if the array of bones' transformations is updated successfully; otherwise, 0.
int getBoneTransforms ( Vector< Math::mat4 > & transforms, int animation = -1, int frame = 0 ) const#
Appends the world-space transformation matrices for bones of the given animation frame to the given array.
If the passed animation number is -1, the bind pose will be added to the given array.
The number of array elements must be equal to the number of animation bones.
Arguments
  • Vector< Math::mat4 > & transforms - Array of transformation matrices.
Return value
Returns 1 if the array of bones' transformations is filled successfully; otherwise, 0.
void setBoundBox ( const BoundBox & bb, int surface ) #
Sets the bounding box for the given mesh surface.
Arguments
  • const BoundBox & bb - Bounding box to be set.
  • int surface - Mesh surface number.
void setBoundBox ( const BoundBox & bb ) #
Arguments
BoundBox getBoundBox ( int surface ) const#
Returns the bounding box of the given mesh surface.
Arguments
Return value
Bounding box.
BoundBox getBoundBox ( ) const#
Return value
Bounding box.
void setBoundSphere ( const BoundSphere & bs ) #
Sets the bounding sphere for the given mesh surface.
Arguments
void setBoundSphere ( const BoundSphere & bs, int surface ) #
Arguments
  • const BoundSphere & bs - Bounding sphere to be set.
BoundSphere getBoundSphere ( ) const#
Returns the bounding sphere of the given surface.
Return value
Bounding sphere.
BoundSphere getBoundSphere ( int surface ) const#
Returns the bounding sphere of the given mesh surface.
Arguments
Return value
Bounding sphere.
void setCIndex ( int num, int index, int surface ) #
Sets the new coordinate index for the given vertex of the given surface.
Arguments
  • int num - Vertex number in the range from 0 to the total number of coordinate indices for the given surface.
    To get the total number of coordinate indices for the given surface, use the getNumCIndices() method.
  • int index - Coordinate index to be set in the range from 0 to the total number of coordinate vertices for the given surface.
    To get the total number of coordinate vertices for the given surface, use the getNumCVertex() method.
int getCIndex ( int num, int surface ) const#
Returns the coordinate index for the given vertex of the given surface.
Arguments
Return value
Coordinate index.
void setColor ( int num, const Math::vec4 & color, int surface ) #
Sets the color for the given triangle vertex of the given surface.
Arguments
  • int num - Triangle vertex number in the range from 0 to the total number of vertex color entries of the given surface.
    To get the total number of vertex color entries for the surface, call the getNumColors() method.
  • const Math::vec4 & color - Vertex color to be set.
Math::vec4 getColor ( int num, int surface ) const#
Returns the color of the given triangle vertex of the given surface.
Arguments
Return value
Vertex color.
void setIndex ( int num, int index, int surface ) #
Sets both coordinate and triangle indices for the given vertex of the given surface equal to the specified index.
Arguments
  • int num - Vertex number in the range from 0 to the total number of coordinate indices of the given surface.
    To get the total number of coordinate indices for the surface, use the getNumCIndices() method.
  • int index - Index to be set in the range from 0 to the total number of coordinate vertices.
    To get the total number of coordinate vertices, use the getNumVertex() method.
int getIndex ( int num, int surface ) const#
Returns the coordinate index of the given vertex of the given surface if the coordinate index is equal to the triangle index.
Arguments
Return value
Coordinate index.
int getIntersection ( const Math::vec3 & p0, const Math::vec3 & p1, Math::vec3 * ret_point, Math::vec3 * ret_normal, int * ret_index, int surface, int target = 0 ) #
Performs the search for the intersection of the given surface target with the given traced line.
Mesh local space coordinates are used for this method.
Arguments
  • const Math::vec3 & p0 - Start point coordinates.
  • const Math::vec3 & p1 - End point coordinates.
  • Math::vec3 * ret_point - Return array to write the intersection point coordinates into.
  • Math::vec3 * ret_normal - Return array to write the intersection point normal into.
  • int * ret_index - Return array to write the intersection point indices into.
  • int target - Surface target number. The default value is 0.
Return value
1 if the intersection is found; otherwise, 0.
void setNormal ( int num, const Math::vec3 & normal, int surface, int target = 0 ) #
Sets the normal for the given triangle vertex of the given surface target.
The normal of the vertex won't be written to the *.mesh file. It will be stored only in memory.
Arguments
  • int num - Triangle vertex number in the range from 0 to the total number of vertex normal entries of the given surface target.
    To get the total number of vertex normal entries for the surface target, call the getNumNormals() method.
  • const Math::vec3 & normal - Normal to be set.
Math::vec3 getNormal ( int num, int surface, int target = 0 ) const#
Returns the normal for the given triangle vertex of the given surface target.
Arguments
Return value
Vertex normal.
void setNumAnimationFrames ( int animation, int num ) #
Sets the number of animation frames for the given animation.
Arguments
  • int animation - Animation number in the range from 0 to the total number of mesh animations.
    To get the total number of mesh animations, call the getNumAnimations() method.
  • int num - Number of the animation frames to be set.
int getNumAnimationFrames ( int animation ) const#
Returns the number of animation frames for the given animation.
Arguments
Return value
Number of the animation frames.
int getNumAnimations ( ) const#
Returns the total number of mesh animations.
Return value
Number of the mesh animations.
int getNumBones ( ) const#
Returns the total number of mesh bones.
Return value
Number of the mesh bones.
void setNumCIndices ( int size, int surface ) #
Sets the total number of coordinate indices for the given surface.
Arguments
  • int size - Number of the coordinate indices to be set.
int getNumCIndices ( int surface ) const#
Returns the total number of coordinate indices for the given surface.
Arguments
Return value
Number of coordinate indices.
void setNumColors ( int size, int surface ) #
Sets the total number of vertex color entries for the given surface.
Colors are specified for triangle vertices.
Arguments
  • int size - Number of vertex color entries to be set.
int getNumColors ( int surface ) const#
Returns the total number of vertex color entries for the given surface.
Arguments
Return value
Number of vertex color entries.
int getNumCVertex ( int surface ) const#
Returns the number of coordinate vertices of the given surface.
Arguments
Return value
Number of coordinate vertices.
void setNumIndices ( int size, int surface ) #
Sets the number of indices for the given surface: updates the number of coordinate and triangle indices. For example, if you pass 5 as the first argument, the number of the coordinate indices and the number of triangle indices will be set to 5.
Arguments
  • int size - Number of indices to be set.
int getNumIndices ( int surface ) const#
Returns the number of coordinate indices of the given surface if the number of the coordinate indices is equal to the number of triangle indices.
Arguments
Return value
void setNumNormals ( int size, int surface, int target = 0 ) #
Sets the total number of vertex normal entries for the given surface target.
Normals are specified for triangle vertices.
Arguments
  • int size - Number of vertex normal entries to be set.
int getNumNormals ( int surface, int target = 0 ) const#
Returns the total number of vertex normal entries for the given surface target.
Arguments
Return value
Number of vertex normal entries.
int getNumSurfaces ( ) const#
Returns the total number of mesh surfaces.
Return value
Number of mesh surfaces.
void setNumSurfaceTargets ( int surface, int num ) #
Sets the number of targets for the given mesh surface.
Arguments
  • int num - Number of surface targets to be set.
int getNumSurfaceTargets ( int surface ) const#
Returns the number of surface targets for the given surface.
Arguments
Return value
Number of surface targets.
void setNumTangents ( int size, int surface, int target = 0 ) #
Sets the total number of vertex tangent entries for the given surface target.
Tangents are specified for triangle vertices.
Arguments
  • int size - Number of vertex tangent entries to be set.
int getNumTangents ( int surface, int tangent = 0 ) const#
Returns the total number of vertex tangent entries for the given surface target.
Arguments
  • int tangent - Surface target number. The default value is 0.
Return value
Number of vertex tangent entries.
void setNumTexCoords0 ( int size, int surface ) #
Sets the total number of the first UV map texture coordinate entries for the given mesh surface.
First UV map texture coordinates are specified for triangle vertices.
Arguments
  • int size - Number of the first UV map texture coordinate entries to be set.
int getNumTexCoords0 ( int surface ) const#
Returns the total number of the first UV map texture coordinate entries for the given mesh surface.
Arguments
Return value
Total number of the first UV map texture coordinate entries.
void setNumTexCoords1 ( int size, int surface ) #
Sets the total number of the second UV map texture coordinate entries for the given mesh surface.
Second UV map texture coordinates are specified for triangle vertices.
Arguments
  • int size - Number of the second UV map texture coordinates to be set.
int getNumTexCoords1 ( int surface ) const#
Returns the total number of the second UV map texture coordinate entries for the given mesh surface.
Arguments
Return value
Total number of the second UV map texture coordinate entries.
void setNumTIndices ( int size, int surface ) #
Sets the total number of triangle indices for the given surface.
Arguments
  • int size - Number of triangle indices to be set.
int getNumTIndices ( int surface ) const#
Returns the total number of triangle indices for the given surface.
Arguments
Return value
Number of triangle indices.
int getNumTVertex ( int surface ) const#
Returns the number of triangle vertices for the given mesh surface.
Arguments
Return value
Number of the triangle vertices.
void setNumVertex ( int size, int surface, int target = 0 ) #
Sets the total number of vertices for the given surface target.
The numbers of vertices and coordinate vertices are equal.
Arguments
  • int size - Number of the vertices to be set.
int getNumVertex ( int surface, int target = 0 ) const#
Returns the total number of vertices for the given surface target.
Arguments
Return value
Number of the vertices.
void setNumWeights ( int size, int surface ) #
Sets the number of weights set for vertices of the given surface.
Weights are specified for coordinate vertices.
Arguments
  • int size - Number of weights to be set.
int getNumWeights ( int surface ) const#
Returns the number of weights set for vertices of the given surface.
Arguments
Return value
Number of the weights.
void setSurfaceName ( int surface, const char * name ) #
Sets the name for the given mesh surface.
Arguments
  • const char * name - Surface name to be set.
const char * getSurfaceName ( int surface ) const#
Returns the name of the given surface.
Arguments
Return value
Surface name.
void setSurfaceTargetName ( int surface, int target, const char * name ) #
Sets the name for the given surface target.
Arguments
  • const char * name - Surface target name to be set.
const char * getSurfaceTargetName ( int surface, int target ) const#
Returns the name of the given surface target.
Arguments
Return value
Surface target name.
int setSurfaceTransform ( const Math::mat4 & transform, int surface = -1, int target = -1 ) #
Sets the transformation matrix for the given surface target.
Arguments
  • int surface - Mesh surface number. The default value is -1 (apply to all of the mesh surfaces).
    If all surfaces are chosen, the transformations of bones and animations will also be recalculated.
  • int target - Surface target number. The default value is -1 (apply to all of the surface targets).
Return value
1 if the transformation matrix is set successfully; otherwise, 0.
void setSurfaceLightmapUVChannel ( int surface, char uv_channel ) #
Sets a new UV channel to be used for lightmaps of the surface with the specified number.
Arguments
  • char uv_channel - UV channel to be used for lightmaps of the surface with the specified number.
char getSurfaceLightmapUVChannel ( int surface ) const#
Returns the current UV channel used for lightmaps of the surface with the specified number.
Arguments
Return value
UV channel currently used for lightmaps of the surface with the specified number.
void setSurfaceLightmapResolution ( int surface, Mesh::LIGHTMAP_RESOLUTION resolution ) #
Sets a new lightmap resolution for the surface with the specified number.
Arguments
  • Mesh::LIGHTMAP_RESOLUTION resolution - Lightmap resolution to be used for the surface with the specified number.
Mesh::LIGHTMAP_RESOLUTION getSurfaceLightmapResolution ( int surface ) const#
Returns the current lightmap resolution for the surface with the specified number.
Arguments
Return value
Current lightmap resolution for the surface with the specified number.
void setTangent ( int num, const Math::quat & tangent, int surface, int target = 0 ) #
Sets the new tangent for the given triangle vertex of the given surface target.
Arguments
  • int num - Triangle vertex number in the range from 0 to the total number of vertex tangent entries of the given surface target.
    To get the total number of vertex tangent entries for the surface target, call the getNumTangents() method.
  • const Math::quat & tangent - Tangent to be set.
Math::quat getTangent ( int num, int surface, int target = 0 ) const#
Returns the tangent for the given triangle vertex of the given surface target.
Arguments
Return value
Vertex tangent.
void setTexCoord0 ( int num, const Math::vec2 & texcoord, int surface ) #
Sets first UV map texture coordinates for the given triangle vertex of the given surface.
Arguments
  • int num - Triangle vertex number in the range from 0 to the total number of first UV map texture coordinate entries of the given surface.
    To get the total number of first UV map texture coordinate entries for the surface, call the getNumTexCoords0() method.
  • const Math::vec2 & texcoord - First UV map texture coordinates to be set.
Math::vec2 getTexCoord0 ( int num, int surface ) const#
Returns first UV map texture coordinates for the given triangle vertex of the given surface.
Arguments
Return value
First UV map texture coordinates.
void setTexCoord1 ( int num, const Math::vec2 & texcoord, int surface ) #
Sets second UV map texture coordinates for the given triangle vertex of the given surface.
Arguments
  • int num - Triangle vertex number in the range from 0 to the total number of second UV map texture coordinate entries of the given surface.
    To get the total number of second UV map texture coordinate entries for the surface, call the getNumTexCoords1() method.
  • const Math::vec2 & texcoord - Second UV map texture coordinates to be set.
Math::vec2 getTexCoord1 ( int num, int surface ) const#
Returns second UV map texture coordinates for the given triangle vertex of the given surface.
Arguments
Return value
Second UV map texture coordinates.
void setTIndex ( int num, int index, int surface ) #
Sets the new triangle index for the given vertex of the given surface.
Arguments
  • int num - Vertex number in the range from 0 to the total number of triangle indices for the given surface.
    To get the total number of triangle indices, use the getNumTIndices() method.
  • int index - Triangle index to be set in the range from 0 to the total number of triangle vertices for the given surface.
    To get the total number of triangle vertices for the given surface, use the getNumTVertex() method.
int getTIndex ( int num, int surface ) const#
Returns the triangle index for the given surface by using the index number.
Arguments
    To get the total number of triangle indices for the given surface, use the getNumTIndices() method.
Return value
Triangle index.
void setVertex ( int num, const Math::vec3 & vertex, int surface, int target = 0 ) #
Sets the coordinates of the given coordinate vertex of the given surface target.
Arguments
  • int num - Coordinate vertex number in the range from 0 to the total number of coordinate vertices for the given surface.
  • const Math::vec3 & vertex - Vertex coordinates to be set.
Math::vec3 getVertex ( int num, int surface, int target = 0 ) const#
Returns coordinates of the given coordinate vertex of the given surface target.
Arguments
Return value
Vertex coordinates.
void setWeightBones ( int num, const Math::ivec4 & bones, int surface ) #
Sets the vector of bone indices that affect the vertex with the given weight.
Vertex weight is characterized by the following values:
Arguments
  • int num - Coordinate vertex number in the range from 0 to the total number of vertex weight entries for the given surface.
    To get the total number of of vertex weight entries for the given surface, use the getNumWeights() method.
  • const Math::ivec4 & bones - Vector of the bone indices to be set.
Math::ivec4 getWeightBones ( int num, int surface ) const#
Returns a vector of bone indices that affect the vertex with the given weight.
Arguments
Return value
Vector of the bone indices associated with the given weight.
void setWeightCount ( int num, int count, int surface ) #
Sets the number of weights that affect the vertex with the given weight.
Arguments
  • int count - Number of weights to be set.
int getWeightCount ( int num, int surface ) const#
Returns the number of weights that affect the vertex with the given weight.
Arguments
Return value
Number of weights.
void setWeightWeights ( int num, const Math::vec4 & weights, int surface ) #
Sets the vector of bone weights that affect the vertex with the given weight.
Arguments
  • const Math::vec4 & weights - Vector of bone weights to be set.
Math::vec4 getWeightWeights ( int num, int surface ) const#
Returns a vector of bone weights that affect the vertex with the given weight.
Arguments
Return value
Bone weights associated with the given weight.
int addAnimation ( const char * name = 0 ) #
Appends an animation with a given name to the current mesh.
Arguments
  • const char * name - Name of the animation. This argument is empty by default.
Return value
Number of mesh animations.
int addBone ( const char * name = 0, int parent = -1 ) #
Appends a new mesh bone.
Arguments
  • const char * name - Bone name. This argument is empty by default.
  • int parent - Parent bone number. The default value is -1 (the new bone has no parent bone).
Return value
Number of mesh bones.
int addBoxSurface ( const char * name, const Math::vec3 & size ) #
Appends a box surface to the current mesh.
// create a mesh instance
// add box surface with the name "box_surface" and the size of the surface is Vec3(1.0, 1.0, 1.0)
mesh->addBoxSurface("box_surface", Math::Vec3(1.0f));
// create the ObjectMeshDynamic from the Mesh object
ObjectMeshDynamicPtr dynamicMesh = ObjectMeshDynamic::create(mesh);
// set the position of the mesh
dynamicMesh->setWorldTransform(translate(Math::Vec3(10.0f,10.0f,10.0f)));
// set the name of the mesh
dynamicMesh->setName("Dynamic Mesh");
The mesh will appear.
Arguments
  • const char * name - Surface name.
  • const Math::vec3 & size - Box size along the X, Y and Z axes.
Return value
Added surface number.
int addCapsuleSurface ( const char * name, float radius, float height, int stacks, int slices ) #
Appends a capsule surface to the current mesh. The stacks and slices specify the surface's subdivision.
// add capsule surface with the name "capsule_surface".
// the radius of the capsule is 1.0, the height is 2.0,
// stacks and slices are equals to 200 and 100, respectively
mesh->addCapsuleSurface("box_surface", 1.0f, 2.0f, 200, 100);
Arguments
  • float radius - Capsule radius.
  • float height - Capsule height.
  • int stacks - Number of stacks that divide the capsule radially.
  • int slices - Number of slices that divide the capsule horizontally.
Return value
The added surface number.
void addCIndex ( int index, int surface ) #
Appends a new Coordinate index the array of coordinate indices for the given surface.
Arguments
  • int index - Coordinate index to be added in the range from 0 to the total number of coordinate vertices.
void addColor ( const Math::vec4 & color, int surface ) #
Appends the given color to the vertex color array of the given surface.
Arguments
  • const Math::vec4 & color - Color to be added.
int addCylinderSurface ( const char * name, float radius, float height, int stacks, int slices ) #
Appends a cylinder surface to the current mesh. The stacks and slices specify the surface's subdivision.
// add cylinder surface with the name "cylinder_surface".
// the radius of the cylinder is 1.0, the height is 2.0,
mesh->addCylinderSurface("cylinder_surface", 1.0f, 2.0f, 200, 100);
Arguments
  • float radius - Cylinder radius.
  • float height - Cylinder height.
  • int stacks - Number of stacks that divide the cylinder radially.
  • int slices - Number of slices that divide the cylinder horizontally.
Return value
int addDodecahedronSurface ( const char * name, float radius ) #
Appends a dodecahedron surface to the current mesh.
// add dodecahedron surface with the name "dodecahedron_surface".
// the radius of the dodecahedron is 1.0
mesh->addDodecahedronSurface("dodecahedron_surface", 1.0f);
Arguments
  • float radius - Dodecahedron radius.
Return value
int addEmptySurface ( const char * name, int num_vertex, int num_indices ) #
Appends a new empty surface to the current mesh.
This function allocates only vertex and index arrays. Texture coordinates, tangent basis, weights and color arrays must be allocated manually.
Arguments
  • int num_vertex - Number of surface vertices.
  • int num_indices - Number of surface indices.
Return value
Number of the mesh surfaces.
int addIcosahedronSurface ( const char * name, float radius ) #
Appends a icosahedron surface to the current mesh.
// add icosahedron surface with the name "icosahedron_surface".
// the radius of the icosahedron is 1.0
mesh->addIcosahedronSurface("icosahedron_surface", 1.0f);
Arguments
  • float radius - Icosahedron radius.
Return value
void addIndex ( int index, int surface ) #
Appends a given index to the arrays of coordinate and triangle indices for the given surface.
Arguments
  • int index - Index to be added in the range from 0 to the total number of coordinate vertices for the surface.
    To get the total number of coordinate vertices for the surface, use the getNumCVertex() method.
int addMeshSurface ( const char * v, const Ptr<Mesh> & mesh, int surface, int target = -1 ) #
Appends a surface of the source mesh to the current mesh as a new surface.
The following example shows how to add a surface from the one mesh to another.
// create mesh instances
MeshPtr mesh_1 = Mesh::create();
MeshPtr mesh_2 = Mesh::create();
// add Surfaces for the added meshes
mesh_1->addCapsuleSurface("capsule_surface", 1.0f, 2.0f, 200, 100);
mesh_2->addBoxSurface("box_surface", Math::vec3(2.2));
// add the surface from the mesh_2 to the mesh_1 as a new surface
// with the name "new_box_surface"
mesh_1->addMeshSurface("new_box_surface", mesh_2, 0);
// create the ObjectMeshDynamic from the mesh_1 object
ObjectMeshDynamicPtr dynamicMesh = ObjectMeshDynamic::create(mesh_1);
Arguments
  • const char * v - Name of the new surface added to the current mesh.
  • const Ptr<Mesh> & mesh - Source mesh to copy a surface from.
  • int surface - Number of the source mesh surface to copy.
  • int target - Number of the target of the source mesh surface. The default value is -1 (all of the surface targets).
Return value
Number of the last added surface.
int addMeshSurface ( int v, const Ptr<Mesh> & mesh, int surface, int target = -1 ) #
Appends a surface of the source mesh to the existing surface of the current mesh.
mesh_1->addMeshSurface(0, mesh_2, 0);
dynamicMesh>setWorldTransform(translate(Math::Vec3(10.0f,10.0f,10.0f)));
dynamicMesh>setName("Dynamic Mesh");
Arguments
  • int v - Number of the existing surface of the current mesh, to which the geometry is added.
Return value
void addNormal ( const Math::vec3 & normal, int surface, int target = 0 ) #
Appends a given normal to the array of normals of the given surface target.
Arguments
  • const Math::vec3 & normal - Normal to be added.
int addPlaneSurface ( const char * name, float width, float height, float step ) #
Appends a plane surface to the current mesh. The plane is divided into equal squares whose size is defined by the given step.
// add the plane surface with the name "plane_surface".
// the width is 2 and the height is 3
mesh->addPlaneSurface("plane_surface", 2.0f, 3.0f, 1.0f);
The mesh will appear. You could see that the plane divided each 1 unit to equal squares.
Arguments
  • float width - Plane width.
  • float height - Plane height.
  • float step - Step of surface subdivision (vertical and horizontal).
Return value
int addPrismSurface ( const char * name, float size_0, float size_1, float height, int sides ) #
Appends a prism surface to the current mesh.
// add the prism surface with the name "prism_surface".
// the radius of the top is 1.0f, of the bottom is 2.0f
// the height of the prism is 3.0f, and it has 4 sides
mesh->addPrismSurface("prism_surface", 1.0f, 2.0f, 3.0f, 4);
Arguments
  • float size_0 - Radius of the circle circumscribed about the top prism base.
  • float size_1 - Radius of the circle circumscribed about the bottom prism base.
  • float height - Height of the prism.
  • int sides - Number of the prism faces.
Return value
int addSphereSurface ( const char * name, float radius, int stacks, int slices ) #
Appends a sphere surface to the current mesh. The stacks and slices specify the surface's subdivision.
// add the sphere surface with the name "sphere_surface".
// the radius of the sphere is 1.0f
// and it has 200 stacks and 100 slices
mesh->addSphereSurface("sphere_surface", 1.0f, 200, 100);
Arguments
  • float radius - Sphere radius.
  • int stacks - Number of stacks that divide the sphere radially.
  • int slices - Number of slices that divide the sphere horizontally.
Return value
int addSurface ( const char * name = 0 ) #
Append a new surface with the given name to the current mesh.
In the following example, we create a new surface and add vertices and indices to create a plane.
// add a new surface
mesh->addSurface("surface_0");
// add vertices of the plane
mesh->addVertex(Math::vec3(0.0f,0.0f,0.0f),0);
mesh->addVertex(Math::vec3(0.0f,0.0f,1.0f),0);
mesh->addVertex(Math::vec3(0.0f,1.0f,0.0f),0);
mesh->addVertex(Math::vec3(0.0f,1.0f,1.0f),0);
// add indices
mesh->addIndex(0,0);
mesh->addIndex(1,0);
mesh->addIndex(2,0);
mesh->addIndex(3,0);
// create tangents
// create mesh bounds
mesh->createBounds(0);
dynamicMesh->setName("new_mesh");
Arguments
  • const char * name - Surface name. This argument is empty by default.
Return value
int addSurfaceTarget ( int surface, const char * name = 0 ) #
Appends a target with the given name to the given surface.
Arguments
  • const char * name - Name of the surface target. This argument is empty by default.
Return value
void addTangent ( const Math::quat & tangent, int surface, int target = 0 ) #
Appends the given tangent to the array of tangents of the specified surface target.
Arguments
  • const Math::quat & tangent - Tangent to be added.
  • int surface - Surface number.
void addTexCoord0 ( const Math::vec2 & texcoord, int surface ) #
Appends texture coordinates to the array of the first UV map coordinates of the given mesh surface.
Arguments
  • const Math::vec2 & texcoord - Coordinates of the first UV map to be added.
void addTexCoord1 ( const Math::vec2 & texcoord, int surface ) #
Appends texture coordinates to the array of the second UV map coordinates of the given mesh surface.
Arguments
  • const Math::vec2 & texcoord - Coordinates of the second UV map to be added.
void addTIndex ( int index, int surface ) #
Appends an index of a triangle vertex to the array of triangle indices for the given surface.
Arguments
  • int index - Index number of the vertex in the triangle buffer in the range from 0 to the total number of triangle vertices.
  • int surface - Number of the surface to which the triangle index is added.
void addVertex ( const Math::vec3 & vertex, int surface, int target = 0 ) #
Appends a new coordinate vertex with the given coordinates to the mesh surface.
In the following example, we create a new surface and add 4 vertices to it. We use local coordinates to define a vertex and specify the surface. After that we specify 6 indices to create a plane by using defined vertices.
// add indices
// create tangents
Arguments
  • const Math::vec3 & vertex - Coordinates of the vertex to be added.
void clear ( ) #
Clears the mesh (including its bones, animation, surfaces and bounds).
int createBounds ( int surface = -1 ) #
Creates bounds (a bounding box and a bounding sphere) for the given surface. If the default value is used as an argument, the bounds will be created for all of the mesh surfaces.
Arguments
  • int surface - Mesh surface number. The default value is -1 (all of the mesh surfaces).
Return value
1 if bounds are created successfully; otherwise, 0.
int createIndices ( int surface = -1 ) #
Creates indices for the given surface. If the default value is used as an argument, the indices will be created for all of the mesh surfaces.
Arguments
Return value
1 if indices are created successfully; otherwise, 0.
int createIntersection ( int surface = -1 ) #
Calculates a potentially visible set for the given surface. This function prepares the mesh for working with getIntersection() method.
Arguments
Return value
1 if the potentially visible set is calculated successfully; otherwise, 0.
int createNormals ( int surface = -1, int target = -1 ) #
Creates normals for the given surface target.
Arguments
  • int target - Surface target number. The default value is -1 (all of the surface targets).
Return value
1 if the normals are created successfully; otherwise, 0.
int createNormals ( float angle, int surface = -1, int target = -1 ) #
Arguments
  • float angle - Angle between normals used to calculate the mean vertex normal.
  • int surface - Mesh surface number. -1 means all of the mesh surfaces.
  • int target - Surface target number. -1 means all of the surface targets.
Return value
int createTangents ( int surface = -1, int target = -1 ) #
Creates tangents for the given surface target.
Arguments
Return value
1 if the tangents are created successfully; otherwise, 0.
int createTangents ( float angle, const Vector< int > & surfaces ) #
Creates tangents for all of the surfaces in the list.
Arguments
  • const Vector< int > & surfaces - List of surface numbers, for which tangents are to be created.
Return value
int findAnimation ( const char * name ) const#
Searches for the animation by the name and returns its number.
Arguments
Return value
int findBone ( const char * name ) const#
Searches for a bone with a given name and returns its number.
Arguments
  • const char * name - Name of the bone.
Return value
Bone number.
int findSurface ( const char * name ) const#
Searches for the surface number by its name.
Arguments
  • const char * name - Mesh surface name.
Return value
Mesh surface number, if it is found; otherwise, -1.
int findSurfaceTarget ( int surface, const char * name ) const#
Searches for the surface target number by the morph target name.
Arguments
  • const char * name
Return value
Target number, if exists; otherwise, -1.
int flipTangent ( int surface = -1 ) #
Flips the sign of the binormal component of the surface tangent space.
Arguments
Return value
1 if the sign of the binormal component is flipped successfully; otherwise, 0.
int flipYZ ( int surface = -1 ) #
Flips the Y and Z axes for the given surface:
  • Y axis becomes equal to -Z
  • Z axis becomes equal to Y
Arguments
Return value
1 if the axes are flipped successfully; otherwise, 0.
int info ( const char * name ) const#
Returns an information about the given mesh or animation.
Arguments
  • const char * name - Mesh or animation name.
Return value
int load ( const char * name ) #
Loads the mesh with the given name for the current mesh.
Arguments
  • const char * name - Mesh name.
Return value
1 if the mesh is loaded successfully; otherwise, 0.
int optimizeIndices ( int flags, int surface = -1 ) #
Optimizes indices of the given mesh surface. As polygons are added to a surface, vertices of the adjacent polygons are duplicated (you can get the number of such the vertices by using the getNumTVertex()), because normals, texture coordinates and tangents of such the vertices differ depending on the polygons, to which this vertices belongs. The optimizeIndices() function serves to decrease the number of such vertices and create indices for them that will be stored in the corresponding normals, tangents and texture coordinates.
Arguments
Return value
1 if the indices are optimized successfully; otherwise, 0.
int remapCVertex ( int surface ) #
Sets the size of the array of coordinate indices to be equal to the size of the array of triangle indices and increases the size of the vertex buffer to the size of the array of triangle vertices by using the coordinate vertex duplicating.
Arguments
Return value
1 if indices are copied successfully; otherwise, 0.
int removeIndices ( int surface = -1 ) #
Clears the coordinate and triangle indices of the given surface.
Arguments
  • int surface - The mesh surface number. -1 means all of the mesh surfaces.
Return value
1 if the indices were cleared successfully; otherwise, 0.
int save ( const char * name ) const#
Saves the given mesh in either MESH or ANIM file format. Creates the given mesh path if it doesn’t exist yet (including subdirectories).
Arguments
  • const char * name - Path to the mesh including the file name and extension — *.mesh or *.anim.
Return value
1 if the mesh is saved successfully; otherwise, 0.
void sortAnimations ( ) #
Sort all animations by their names.
void sortSurfaces ( ) #
Sort all surfaces by their names.
void addVertex ( const Vector< Math::vec3 > & vertices, int surface, int target = 0 ) #
Adds coordinates of the given coordinate vertex to the given surface target.
Arguments
  • const Vector< Math::vec3 > & vertices - Vertex coordinates.
void addTexCoords0 ( const Vector< Math::vec2 > & texcoords, int surface ) #
Adds the first UV map texture coordinates to the given surface.
Arguments
  • const Vector< Math::vec2 > & texcoords - First UV map texture coordinates.
void addTexCoords1 ( const Vector< Math::vec2 > & texcoords, int surface ) #
Adds the second UV map texture coordinates to the given surface.
Arguments
  • const Vector< Math::vec2 > & texcoords - Second UV map texture coordinates.
void addNormals ( const Vector< Math::vec3 > & normals, int surface, int target = 0 ) #
Add normals to the given surface target.
Arguments
  • const Vector< Math::vec3 > & normals - Normals of the surface target.
void addTangents ( const Vector< Math::quat > & tangents, int surface, int target = 0 ) #
Add tangents to the given surface target.
Arguments
  • const Vector< Math::quat > & tangents
void addColors ( const Vector< Math::vec4 > & colors, int surface ) #
Adds the vertex colors to the given surface.
Arguments
  • const Vector< Math::vec4 > & colors - Vertex colors.
void addCIndices ( const Vector< int > & indices, int surface ) #
Adds the coordinate indices of all vertices to the given surface.
Arguments
  • const Vector< int > & indices - Coordinate indices.
void addTIndices ( const Vector< int > & indices, int surface ) #
Adds the triangle indices to the given surface.
Arguments
  • const Vector< int > & indices - Triangle indices.
void addIndices ( const Vector< int > & indices, int surface ) #
Adds the indices to the given surface.
Arguments
  • const Vector< int > & indices - Index coordinates of the mesh.
Vector< Math::vec3 > & getVertices ( int surface, int target = 0 ) #
Arguments
Return value
Vertex coordinates.
Vector< Math::vec3 > & getNormals ( int surface, int target = 0 ) #
Returns normals for the given surface target.
Arguments
Return value
Vector< Math::quat > & getTangents ( int surface, int target = 0 ) #
Returns tangents for the given surface target.
Arguments
Return value
Tangents of the surface target.
Vector< Math::vec2 > & getTexCoords0 ( int surface ) #
Returns the first UV map texture coordinates of the given surface.
Arguments
Return value
Vector< Math::vec2 > & getTexCoords1 ( int surface ) #
Returns the second UV map texture coordinates of the given surface.
Arguments
Return value
Vector< Math::bvec4 > & getColors ( int surface ) #
Returns the vertex colors of the given surface.
Arguments
Return value
Vertex colors.
Vector< int > & getCIndices ( int surface ) #
Returns the coordinate indices of all vertices of the given surface.
Arguments
Return value
Coordinate indices.
Vector< int > getTIndices ( int surface ) #
Returns the triangle indices of the given surface.
Arguments
Return value
Triangle indices.
Last update: 10.03.2022
