WebStream Plugin
The functionality described in this article is experimental.
The WebStream plugin allows broadcasting audio data and video frames rendered by a UNIGINE-based application to an unlimited number of devices via WebRTC (Web Real-Time Communication).
In general, the process is as follows:
  1. You run the UNIGINE application on a remote computer, a desktop inside your organization, a container, or a virtual machine provided by a cloud hosting service.
  2. UNIGINE uses the resources available to that computer (like CPU, GPU, memory, etc.) to run the application logic and render frames.
  3. The rendered output is continuously encoded into a media stream and passed through a lightweight stack of web services.
  4. Users view this stream in standard web browsers running on other computers and mobile devices and control the experience from their browsers, sending keyboard, mouse, and touch events, as well as custom events emitted from the client's web page, back to UNIGINE.
Launching Plugin#
To use the WebStream plugin with your project, do the following:
  1. Add it via UNIGINE SDK Browser on the project creation: click Plugins, check the WebStream plugin option, and click Add.
    For the existing project, choose Other Actions -> Configure Project, add the plugin as described above, and click Update Configuration.
  2. Launch the plugin: specify the extern_plugin command line option on the application start-up.
    Source code
    main_x64 -extern_plugin "UnigineWebStream"
    In addition, you can enable the Offscreen mode by specifying the -video_offscreen command-line option. It will allow you to run the application in the headless mode without displaying a visible window.
    Source code
    main_x64 -extern_plugin "UnigineWebStream" -video_offscreen 1
    • If you skip this parameter, the application window will be rendered alongside the video and input streams. However, in this case, inputs from remote clients may be processed incorrectly.
    • For cases where user input is not allowed in a remote client application, there is no need to enable Offscreen mode.
Viewing Output#
To render the output from the main viewport in a web browser, use the http address data specified in the web configuration file in the address bar as follows:
localhost:8000 if the application runs on the same PC.
[device-IP-address]:8000
if the application runs on another PC in the network.
To make the application accessible from other PCs in the network, specify the IP address of the host PC in the web configuration file.
If the player name is not set in the address at all, i.e. the link looks like:
  • localhost:8000/index.html?video=
    or
  • localhost:8000
the image is streamed as rendered by Main Player.
Engine image: Streamed image:
To render from the specific camera, add /index.html?video=PlayerName to the address:
  • localhost:8000/index.html?video=PlayerName
    or
  • [device-IP-address]:8000/index.html?video=PlayerName
If the player with the specified name does not exist in the current world on the streaming server computer, you'll see a fallback view from the current camera on the streaming server, but without any post-effects and GUI.
Image streamed without GUI because the specified player has not been found
Web Configuration File#
The plugin comes with the webconfig.json file, which contains settings allowing you to configure the broadcasting process. You can change the server settings (for example, specify a custom HTTP address to view the output in a browser) and enable or disable the user input.
Here is an example of the default configuration file:
Source code
	"server":{
		"document_root":"./plugins/Unigine/WebStream/html",
		"http_address":"0.0.0.0:8000",
		"enable_directory_listing" : false,
		"num_threads" : 4,
		"disable_xframe_options" : false,
		"access_control_allow_origin" : "*",
		"enable_keep_alive" : true,
		"keep_alive_timeout_ms" : 1000,
		"decode_url" : false,
		"ssl_certificate" : "",
		"global_auth_file" : "",
		"authentication_domain" : "",
		"extra_options" : []
	"input":{
		"enabled" : true
The server settings are the following:
document_root Directory from which the web server serves pages.
http_address
HTTP address and port for the web server.
  • The default address 0.0.0.0 makes the application accessible only on the local machine. To allow access from other PCs in the network, specify the IP address of the host PC within the local network.
  • Port 8000 is set by default. You can specify any other available port.
enable_directory_listing Flag indicating whether users can browse the contents of the folder specified in the document_root through the web browser or only access the predefined pages.
num_threads Number of threads for the web server. It is not recommended to set this to fewer than 2.
disable_xframe_options Flag indicating whether the X-Frame-Option response header is enabled.
access_control_allow_origin Access-Control-Allow-Origin response header. By default, it is set to *, allowing a web browser to request code from any origin.
enable_keep_alive Value indicating whether the Keep-Alive header is enabled.
keep_alive_timeout_ms Time, in milliseconds, that the host will keep an idle connection open.
decode_url Flag indicating whether URL decoding is enabled.
ssl_certificate Path to the certificate required for HTTPS.
global_auth_file Path to a global authentication file.
authentication_domain Authentication domain.
extra_options List of additional server settings.
There is also a section with settings of the user input:
enabled
Allows or forbids processing of the user input from the web browser by the server.
When the input is not allowed, the plugin can be used without the Offscreen mode without any issues.
