Unigine::TerrainGlobalLodHeight Class
Header: | #include <UnigineObjects.h> |
Inherits from: | TerrainGlobalLod |
This class is inherited from the TerrainGlobalLod class and used to manage a single height LOD (level of detail) of the global terrain object. Height LODs are used for collision and intersection detection.
Members
void setCastShadows ( int shadows ) #
Enables or disables casting shadows from non-world lights for the height LOD.Arguments
- int shadows - 1 to enable casting shadows, 0 to disable it.
int isCastShadows ( ) #
Returns a value indicating if shadow casting for the height LOD is enabled.Return value
1 if shadow casting for the height LOD is enabled; otherwise, 0.void setCollision ( int collision ) #
Enables or disables collision detection for the height LOD.Arguments
- int collision - 1 to enable collision detection, 0 to disable it.
int isCollision ( ) #
Returns a value indicating if collision detection for the height LOD is enabled.Return value
1 if collision detection for the height LOD is enabled; otherwise, 0.void setCollisionMask ( int mask ) #
Sets the collision mask for the height LOD. A collision of an object with the height LOD will be detected, if they both have matching masks.Arguments
- int mask - Collision mask, an integer value each bit of which is a mask.
int getCollisionMask ( ) #
Returns the current collision mask for the height LOD. A collision of an object with the height LOD will be detected, if they both have matching masks.Return value
Collision mask, an integer value each bit of which is a mask.void setIntersection ( int intersection ) #
Enables or disables intersection detection for the height LOD.Arguments
- int intersection - 1 to enable intersection detection, 0 to disable it.
int isIntersection ( ) #
Returns a value indicating if intersection detection for the height LOD is enabled.Return value
1 if intersection detection for the height LOD is enabled; otherwise, 0.void setIntersectionMask ( int mask ) #
Sets the intersection mask for the height LOD. An intersection of an object with the height LOD will be detected, if they both have matching masks.Arguments
- int mask - Intersection mask, an integer value each bit of which is a mask.
int getIntersectionMask ( ) #
Returns the current intersection mask for the height LOD. An intersection of an object with the height LOD will be detected, if they both have matching masks.Return value
Intersection mask, an integer value each bit of which is a mask.The information on this page is valid for UNIGINE 2.19.1 SDK.
