使用C++组件系统
The C++ Component System enables you to implement your application's logic via a set of building blocks - components, and assign these blocks to nodes. A logic component integrates a node, a property, and a C++ class containing logic implementation.C++ 组件系统 使您能够通过一组构建块,组件,实现应用程序的逻辑,并分配这些块 到节点。逻辑组件集成了节点、属性和包含逻辑实现的 C++ 类。
This example demonstrates how to:此示例演示如何:
- Decompose application logic into building blocks.将应用程序逻辑分解为构建块
- Create your own logic components.创建自己的逻辑组件
- Implement interaction between your components.实现组件之间的交互
Let's make a simple game to demonstrate how the whole system works.让我们做一个简单的游戏来演示整个系统是如何工作的。
See Also请参阅#
This case is also provided as an SDK sample.此案例也作为SDK示例提供。
Game Description游戏介绍#
In the center of the play area, we are going to have an object (Pawn) controlled by the player via the keyboard. It has certain amount of HP and movement parameters (movement and rotation speed).在游戏区域的中心,我们将有一个由玩家通过键盘控制的对象,棋子(Pawn)。 它具有一定数量的HP和运动参数(运动和旋转速度)。
Four corners of the play area are occupied by rotating objects (Spinner) that throw other small objects (Projectile) in all directions while rotating.游戏区域的四个角被旋转对象,旋转器(Spinner)占据,这些旋转器在旋转时向所有方向投掷其他小对象,弹丸(Projectile)。
Each Projectile moves along a straight line in the directon it has been initially thrown by the Spinner. If a Projectile hits a Pawn, the latter takes damage according to the value set for the hitting Projectile (each of them has a random speed and damage value). The pawn is destroyed if the amount of HP drops below zero.每个弹丸在它最初被旋转器抛出的方向上沿着一条直线移动。 如果一个弹丸击中棋子,后者根据为击中的弹丸设置的值(它们中的每一个都有一个随机的速度和伤害值)受到伤害。 如果HP量降至零以下,则棋子将被销毁。
We use boxes for simplicity, but you can easily replace them with any other objects.为了简单起见,我们使用立方体,但您可以将它们替换为任何其他对象。
The basic workflow for implementing application logic using the C++ Component System is given below.下面给出了使用C++组件系统实现应用程序逻辑的基本工作流程。
1. Prepare a Project1. 准备项目#
Before we can start creating components and implementing our game logic, we should create a new C++ project.在开始创建组件和实现游戏逻辑之前,我们应该创建一个新的C++项目。
2. Decompose Application Logic into Building Blocks2. 将应用程序逻辑分解为构建块#
First of all, we should decompose our application logic in terms of building blocks - components. So, we should define parameters for each component (all these parameters will be stored in a corresponding *.prop file) and decide in which functions of the execution sequence the component's logic will be implemented.首先,我们应该根据构建块(组件)来分解应用程序逻辑。因此,我们应该为每个组件定义参数(所有这些参数将存储在相应的*.prop文件中),并决定在执行序列的哪些函数中实现组件的逻辑。
For our small game, we are going to use one component for each type of object. Thus, we need 3 components:对于我们的小游戏,我们将为每种类型的对象使用一个组件。 因此,我们需要3组件:
Pawn with the following parameters:具有以下参数的Pawn:
- name - name of the Pawnname 棋子的名称
- moving speed - how fast the Pawn movesmoving speed 棋子移动的速度有多快
- rotation speed - how fast the Pawn rotatesrotation speed 棋子旋转的速度有多快
- health - HP count for the Pawnhealth 棋子的HP计数
We are going to initialize the Pawn, do something with it each frame, and report a message, when the Pawn dies. Therefore, this logic will be implemented inside the init(), update(), and shutdown() methods.我们将初始化棋子,每帧对它做一些事情,并在棋子死亡时报告一条消息。 因此,该逻辑将在 init(), update() 和 shutdown() 方法内部实现。
Spinner with the following parameters:具有以下参数的Spinner:
- rotation speed - how fast the Spinner rotatesrotation speed 旋转器旋转的速度有多快
- acceleration - how fast Spinner's rotation rate increasesacceleration 旋转器旋转速率增加的速度有多快
- node to be used as a projectile要用作弹丸的节点
- minimum spawn delay最小生成延迟
- maximum spawn delay最大生成延迟
We are going to initialize a Spinner and do something with it each frame. Therefore, this logic will go to the init() and update().我们将初始化旋转器,并在每个帧中使用它做一些事情。 因此,该逻辑将转到init()和update()。
Projectile with the following parameters:具有以下参数的Projectile:
- speed - how fast the Projectile movesspeed 弹丸移动的速度有多快
- lifetime - how long the Projectile liveslifetime 弹丸寿命多长
- damage - how much damage the Projectile causes to the Pawn it hitsdamage 弹丸对其击中的棋子造成多少伤害
As for the projectile, it will be spawned and initialized by the Spinner. The only thing we are going to do with it, is checking for a hit and controlling the life time left every frame. All of this goes to update().至于弹丸,它将由旋转器产生和初始化。 我们要用它做的唯一的事情就是检查一个命中并控制每一帧留下的生命时间。 所有这些都转到update()。
3. Create a C++ Class for Each Component3. 为每个组件创建一个C++类#
For each of our components, we should derive a new C++ class from the ComponentBase class. Therefore, we should do the following in the header file:对于我们的每个组件,我们应该从ComponentBase类派生一个新的C++类。 因此,我们应该在头文件中执行以下操作:
Declare a component class. The name of the class is used as the name of the property (the corresponding *.prop file is automatically saved in your project's data folder).声明一个组件类。 类的名称用作属性的名称(相应的*.prop文件会自动保存在项目的data文件夹中)。
To declare a class, use the following:要声明类,请使用以下内容:
源代码 (C++)COMPONENT_DEFINE(my_property_name, Unigine::ComponentBase);
Declare all parameters defined above with their default values (if any).声明上面定义的所有参数及其默认值(如果有的话)。
To declare a parameter we can use the following macros (optional parameters are enclosed in square brackets []):要声明参数,我们可以使用以下宏(可选参数用方括号[]括起来):
源代码 (C++)PROP_PARAM(type, name[, default_value, title, tooltip, group]); PROP_STRUCT(type, name); PROP_ARRAY(type, name); PROP_ARRAY_STRUCT(type, name);
Declare which methods we are going to use to implement our logic, and during which stages of the execution sequence to call them:声明我们将使用哪些方法来实现我们的逻辑,以及在执行序列的哪些阶段调用它们:
源代码 (C++)public: COMPONENT_INIT(my_init); COMPONENT_UPDATE(my_update); COMPONENT_SHUTDOWN(my_shutdown); // ... protected: void my_init(); void my_update(); void my_shutdown();
- Declare all necessary auxiliary parameters and functions.声明所有必要的辅助参数和函数。
Thus, for our Pawn, Spinner, and Projectile classes, we will have the following declarations:因此,对于我们的Pawn, Spinner和Projectile类,我们将有以下声明:
Pawn.h
#pragma once
#include <UnigineGame.h>
#include <UnigineControls.h>
// include the header file of the Component System
// derive our class from the ComponentBase
class Pawn : public ComponentBase
// declare constructor and destructor for our class and define a property name. The Pawn.prop file containing all parameters listed below will be saved in your project's data folder
COMPONENT_DEFINE(Pawn, ComponentBase)
COMPONENT_INIT(init);
COMPONENT_UPDATE(update);
COMPONENT_SHUTDOWN(shutdown);
// parameters
PROP_PARAM(String, name, "Pawn1"); // Pawn's name
PROP_PARAM(Int, health, 200); // health points
PROP_PARAM(Float, move_speed, 4.0f); // move speed (meters/s)
PROP_PARAM(Float, turn_speed, 90.0f); // turn speed (deg/s)
// methods
void hit(int damage); // decrease Pawn's HP
protected:
// world main loop overrides
void init();
void update();
void shutdown();
// auxiliary parameters and functions
ControlsPtr controls;
PlayerPtr player;
float damage_effect_timer = 0;
Mat4 default_model_view;
void show_damage_effect();
Spinner.h
#pragma once
#include <UnigineMaterial.h>
class Spinner : public ComponentBase
// declare constructor and destructor for the Spinner class
COMPONENT_DEFINE(Spinner, ComponentBase);
// parameters
PROP_PARAM(Float, turn_speed, 30.0f);
PROP_PARAM(Float, acceleration, 5.0f);
PROP_PARAM(Node, spawn_node);
PROP_PARAM(Float, min_spawn_delay, 1.0f);
PROP_PARAM(Float, max_spawn_delay, 4.0f);
protected:
// world main loop
void init();
void update();
float start_turn_speed = 0;
float color_offset = 0;
float time_to_spawn = 0;
MaterialPtr material;
// converter from HSV to RGB color model
vec3 hsv2rgb(float h, float s, float v);
Projectile.h
#pragma once
class Projectile : public ComponentBase
// declare constructor and destructor for the Projectile class
COMPONENT(Projectile, ComponentBase);
PROP_NAME("Projectile");
// parameters
PROP_PARAM(Float, speed, 5.0f);
PROP_PARAM(Float, lifetime, 5.0f); // life time of the projectile (declaration with a default value)
PROP_PARAM(Int, damage); // damage caused by the projectile (declaration with no default value)
// methods
void setMaterial(const MaterialPtr &mat);
protected:
// world main loop
void update();
4. Implement Each Component's Logic4. 实现每个组件的逻辑#
After making necessary declarations, we should implement logic for all our components. Let's do it in the corresponding *.cpp files.在进行必要的声明后,我们应该为所有组件实现逻辑。 让我们在相应的*.cpp文件中进行。
In each of these files, we should add the following macro to ensure automatic registration of the corresponding component by the Component System:在每个文件中,我们应该添加以下宏,以确保组件系统自动注册相应的组件:
REGISTER_COMPONENT ( your_component_name );
Pawn's Logic典当的逻辑#
The Pawn's logic is divided into the following elements:Pawn的逻辑分为以下元素:
Initialization - here we set necessary parameters, and the Pawn reports its name:初始化:这里我们设置必要的参数,Pawn报告其名称:
源代码 (C++)Log::message("PAWN: INIT \"%s\"\n", name.get());
注意You can access parameters of your component via: <parameter_name>.get()您可以通过 <parameter_name>.get() 访问组件的参数 -
Main loop - here we implement the player's keyboard control.主循环:这里我们实现玩家的键盘控制。
注意To access the node from the component, we can simply use node, e.g. to get the current node's direction we can write:要从组件访问节点,我们就可以使用node,例如获取我们可以写入的当前节点的方向:
源代码 (C++)Vec3 direction = node->getWorldTransform().getColumn3(1);
- Shutdown - here we implement actions to be performed when a Pawn dies. We'll just print a message to the console.关闭:这里我们实现当棋子死亡时要执行的操作。 我们只需打印一条消息到控制台。
- Auxiliary - a method to be called when the pawn is hit, and some visual effects.辅助:当棋子被击中时调用的方法,以及一些视觉效果。
Implementation of the Pawn's logic is given below:Pawn逻辑的实现如下:
Pawn.cpp
#include "Pawn.h"
#include <UnigineConsole.h>
#include <UnigineRender.h>
REGISTER_COMPONENT(Pawn); // macro for component registration by the Component System
#define DAMAGE_EFFECT_TIME 0.5f
void Pawn::init()
player = Game::getPlayer();
default_model_view = player->getCamera()->getModelview();
void Pawn::update()
// get delta time between frames
float ifps = Game::getIFps();
// show damage effect
if (damage_effect_timer > 0)
damage_effect_timer = Math::clamp(damage_effect_timer - ifps, 0.0f, DAMAGE_EFFECT_TIME);
// if console is opened we disable any controls
if (Console::isActive())
return;
// get the direction vector of the mesh from the second column (y axis) of the transformation matrix
// checking controls states and changing pawn position and rotation
node->setWorldPosition(node->getWorldPosition() + direction * move_speed * ifps);
if (controls->getState(Controls::STATE_BACKWARD) || controls->getState(Controls::STATE_TURN_DOWN))
node->setWorldPosition(node->getWorldPosition() - direction * move_speed * ifps);
node->setWorldRotation(node->getWorldRotation() * quat(0.0f, 0.0f, turn_speed * ifps));
if (controls->getState(Controls::STATE_MOVE_RIGHT) || controls->getState(Controls::STATE_TURN_RIGHT))
node->setWorldRotation(node->getWorldRotation() * quat(0.0f, 0.0f, -turn_speed * ifps));
void Pawn::shutdown()
Log::message("PAWN: DEAD!\n");
// method to be called when the Pawn is hit by a Projectile
void Pawn::hit(int damage)
// take damage
health = health - damage;
// show effect
damage_effect_timer = DAMAGE_EFFECT_TIME;
// destroy
if (health <= 0)
node.deleteLater();
Log::message("PAWN: damage taken (%d) - HP left (%d)\n", damage, health.get());
// auxiliary method implementing visual damage effect
void Pawn::show_damage_effect()
float strength = damage_effect_timer / DAMAGE_EFFECT_TIME;
Render::setFadeColor(vec4(0.5f, 0, 0, saturate(strength - 0.5f)));
player->getCamera()->setModelview(default_model_view * Mat4(
rotateX(Game::getRandomFloat(-5, 5) * strength) *
rotateY(Game::getRandomFloat(-5, 5) * strength)));
Projectile's Logic弹丸的逻辑#
The Projectile's logic is simpler - we just have to perform a check each frame whether we hit the Pawn or not. This means that we have to access the Pawn component from the Projectile component.弹丸的逻辑更简单-我们只需要每帧执行一个检查是否击中棋子。 这意味着我们必须从Projectile组件访问Pawn组件。
To access certain component on a certain node (e.g. the one that was intersected in our case) we can write the following:要访问某个节点上的某个组件(例如在我们的例子中相交的那个),我们可以编写以下内容:
MyComponent *my_component = getComponent<MyComponent>(some_node);
// access some method of MyComponent
my_component->someMyComponentMethod();
The Projectile has a limited life time, so we should destroy the node when its life time is expired.弹丸的生命周期是有限的,所以我们应该在弹丸生命周期结束时销毁该节点。
Implementation of the Projectile's logic is given below:下文给出了弹丸逻辑的实现:
Projectile.cppProjectile.cpp
#include "Projectile.h"
#include "Pawn.h"
#include "Spinner.h"
#include <UnigineWorld.h>
REGISTER_COMPONENT(Projectile); // macro for component registration by the Component System
void Projectile::update()
// move forward
node->setWorldPosition(node->getWorldPosition() + direction * speed * ifps);
// lifetime
lifetime = lifetime - ifps;
if (lifetime < 0)
// destroy current node with its properties and components
node.deleteLater();
return;
// check the intersection with nodes
VectorStack<NodePtr> nodes; // VectorStack is much faster than Vector, but has some limits
World::getIntersection(node->getWorldBoundBox(), nodes);
if (nodes.size() > 1) // (because the current node is also in this list)
for (int i = 0; i < nodes.size(); i++)
Pawn *pawn = getComponent<Pawn>(nodes[i]);
if (pawn)
// hit the player!
pawn->hit(damage);
// ...and destroy current node
node.deleteLater();
return;
void Projectile::setMaterial(const MaterialPtr &mat)
checked_ptr_cast<Object>(node)->setMaterial(mat, "*");
Spinner's Logic旋转器的逻辑#
The Spinner's logic is divided into the following elements:旋转器的逻辑分为以下元素:
- Initialization - here we set necessary parameters to be used in the main loop.初始化:这里我们设置必要的参数在主循环中使用。
Main loop - here we rotate our Spinner and spawn nodes with Projectile components. We also set some parameters of the Projectile.主循环:在这里,我们旋转我们的旋转器并生成分配了弹丸组件的节点。 我们还设置了弹丸的一些参数。
There are 3 ways to change variables of another component:有三种方法可以更改另一个组件的变量:
Directly via component (fast, easy)直接通过组件(快速,简单)
源代码 (C++)component->int_parameter = component->int_parameter + 1;
Via node's property (slower, more awkward)通过节点的属性(比较慢,比较不方便的)
源代码 (C++)for (int i = 0; i < node->getNumProperties(); i++) { PropertyPtr prop = node->getProperty(i); if (prop && (!strcmp(prop->getName(), "my_prop_name") || prop->isParent("my_prop_name"))) prop->setParameterInt(prop->findParameter("int_parameter"), 5); }
Via component's property通过组件的属性
源代码 (C++)PropertyPtr prop = component->getProperty(); prop->setParameterInt(prop->findParameter("int_parameter"), 5);
- Auxiliary - color conversion function.辅助:颜色转换功能。
Implementation of the Spinner's logic is given below:下面给出了旋转器逻辑的实现:
Spinner.cpp
#include <UnigineEditor.h>
REGISTER_COMPONENT(Spinner); // macro for component registration by the Component System
void Spinner::init()
// get current material (from the first surface)
ObjectPtr obj = checked_ptr_cast<Object>(node);
if (obj && obj->getNumSurfaces())
material = obj->getMaterialInherit(0);
// init randoms
time_to_spawn = Game::getRandomFloat(min_spawn_delay, max_spawn_delay);
color_offset = Game::getRandomFloat(0, 360.0f);
start_turn_speed = turn_speed;
void Spinner::update()
// rotate spinner
turn_speed = turn_speed + acceleration * ifps;
node->setRotation(node->getRotation() * quat(0, 0, turn_speed * ifps));
// change color
int id = material->findParameter("albedo_color");
if (id != -1)
float hue = Math::mod(Game::getTime() * 60.0f + color_offset, 360.0f);
material->setParameterFloat4(id, vec4(hsv2rgb(hue, 1, 1), 1.0f));
// spawn projectiles
time_to_spawn -= ifps;
if (time_to_spawn < 0 && spawn_node)
// reset timer and increase difficulty
time_to_spawn = Game::getRandomFloat(min_spawn_delay, max_spawn_delay) / (turn_speed / start_turn_speed);
// create node
NodePtr spawned = spawn_node->clone();
spawned->setEnabled(1);
spawned->setWorldTransform(node->getWorldTransform());
// don't destroy it on quitting the current scope
// note: if you plan to add some components to this object
// you have to use release() method and transfer ownership of this
// object to the Editor
// create component
Projectile *proj_component = addComponent<Projectile>(spawned);
// there are three ways to change variables inside another component:
// 1) direct change via component (fast, easy)
proj_component->speed = Game::getRandomFloat(proj_component->speed * 0.5f, proj_component->speed * 1.5f);
// 2) change via property of the node (more slow, more awkward)
for (int i = 0; i < spawned->getNumProperties(); i++)
PropertyPtr prop = spawned->getProperty(i);
if (prop && (!strcmp(prop->getName(), "Projectile") || prop->isParent("Projectile")))
prop->getParameterPtr("damage")->setValueInt(Game::getRandomInt(75, 100));
// 3) change via property of the component
PropertyPtr proj_property = proj_component->getProperty();
proj_property->getParameterPtr("lifetime")->setValueFloat(Game::getRandomFloat(5.0f, 10.0f));
// call public method of another component
proj_component->setMaterial(material);
// color conversion H - [0, 360), S,V - [0, 1]
vec3 Spinner::hsv2rgb(float h, float s, float v)
float p, q, t, fract;
h /= 60.0f;
fract = h - Math::floor(h);
p = v * (1.0f - s);
q = v * (1.0f - s * fract);
t = v * (1.0f - s * (1.0f - fract));
if (0.0f <= h && h < 1.0f) return vec3(v, t, p);
else if (1.0f <= h && h < 2.0f) return vec3(q, v, p);
else if (2.0f <= h && h < 3.0f) return vec3(p, v, t);
else if (3.0f <= h && h < 4.0f) return vec3(p, q, v);
else if (4.0f <= h && h < 5.0f) return vec3(t, p, v);
else if (5.0f <= h && h < 6.0f) return vec3(v, p, q);
else return vec3(0, 0, 0);
5. Register Components in the Component System5. 在组件系统中注册组件#
Now we have all our game logic implemented in the corresponding components: Pawn, Spinner, and Projectile. There is one more thing to be done before we can start using them. We should register our components in the Component System.现在我们已经在相应的组件中:Pawn, Spinner和Projectile,实现了所有的游戏逻辑。 在我们开始使用它们之前,还有一件事要做。 我们应该在组件系统中注册我们的组件。
All components having the REGISTER_COMPONENT macro declared in their implementation files (*.cpp), are registered automatically by the Component System upon its initialization, just add a single line to the AppSystemLogic::init() method:所有在其实现文件(*.cpp)中声明REGISTER_COMPONENT宏的组件,在初始化时由组件系统自动注册,只需在AppSystemLogic::init()方法中添加一行即可:
int AppSystemLogic::init()
Voila! All our components are registered at once!瞧!我们所有的组件都是一次性注册的!
6. Add Components to Nodes6. 向节点添加组件#
As we implemented our game logic in the components and registered them in the System, we can actually start using them. There are two ways to add a logic component to a node:当我们在组件中实现我们的游戏逻辑并在系统中注册它们时,我们实际上可以开始使用它们。 有两种方法可以将逻辑组件添加到节点:
By simply assigning the corresponding property to it via UnigineEditor or code:通过 UnigineEditor 或代码为其分配相应的属性:
源代码 (C++)object1->addProperty("MyComponentProperty"); object2->setProperty(0, "MyComponentProperty");
By calling the corresponding method of the Component System:调用组件系统的相应方法:
源代码 (C++)ComponentSystem::get()->addComponent<MyComponent>(object);
Here is the resulting code for our game including registration of components as well as adding them to nodes:这是我们游戏的总代码,包括组件的注册以及将它们添加到节点:
game.cpp
#include <UnigineEngine.h>
#include <UnigineLights.h>
#include <UnigineWidgets.h>
#include "Pawn.h"
// System logic class
class AppSystemLogic : public SystemLogic
AppSystemLogic() {}
virtual ~AppSystemLogic() {}
virtual int init()
// run in background
Engine::get()->setBackgroundUpdate(Engine::BACKGROUND_UPDATE_RENDER_NON_MINIMIZED);
// load world
World::loadWorld("cs");
// World logic class
class AppWorldLogic : public WorldLogic
AppWorldLogic() {}
virtual ~AppWorldLogic() {}
virtual int init()
// create static camera
player = PlayerDummy::create();
player->setPosition(Vec3(17.0f));
player->setDirection(vec3(-1.0f), vec3(0.0f, 0.0f, 1.0f));
Game::setPlayer(player);
// create light
sun = LightWorld::create(vec4_one);
sun->setName("Sun");
sun->setWorldRotation(Math::quat(45.0f, 30.0f, 300.0f));
// Note: objects are added to the world when created
// create objects
ObjectMeshDynamicPtr obj[4];
obj[0] = create_box(translate(Vec3(-16.0f, 0.0f, 0.0f)), vec3(1.0f));
obj[1] = create_box(translate(Vec3(16.0f, 0.0f, 0.0f)), vec3(1.0f));
obj[2] = create_box(translate(Vec3(0.0f, -16.0f, 0.0f)), vec3(1.0f));
obj[3] = create_box(translate(Vec3(0.0f, 16.0f, 0.0f)), vec3(1.0f));
// there are two ways to create components on nodes:
// 1) via component system
ComponentSystem::get()->addComponent<Spinner>(obj[0]);
ComponentSystem::get()->addComponent<Spinner>(obj[1]);
// 2) via property
obj[2]->addProperty("Spinner");
obj[3]->setProperty(0, "Spinner");
// set up spinners (set "spawn_node" variable)
ObjectMeshDynamicPtr projectile_obj = create_box(Mat4_identity, vec3(0.15f));
projectile_obj->setEnabled(0);
for (int i = 0; i < 4; i++)
ComponentSystem::get()->getComponent<Spinner>(obj[i])->spawn_node = projectile_obj;
// create player
ObjectMeshDynamicPtr my_pawn_object = create_box(translate(Vec3(1.0f, 1.0f, 0.0f)), vec3(1.3f, 1.3f, 0.3f));
my_pawn = ComponentSystem::get()->addComponent<Pawn>(my_pawn_object);
my_pawn->setDestroyCallback(MakeCallback(this, &AppWorldLogic::my_pawn_destroyed));
time = 0;
// create info label
label = WidgetLabel::create(Gui::getCurrent());
label->setPosition(10, 10);
label->setFontSize(24);
label->setFontOutline(1);
Gui::getCurrent()->addChild(label, Gui::ALIGN_OVERLAP);
virtual int update()
// increase time while player is alive
if (my_pawn)
time += Game::getIFps();
// show game info
label->setText(String::format(
"Player:\n"
"Health Points: %d\n"
"Time: %.1f sec\n"
"\n"
"Statisics:\n"
"Components: %d",
(my_pawn ? my_pawn->health.get() : 0),
time,
ComponentSystem::get()->getNumComponents()).get());
Pawn* my_pawn{ nullptr }; // Pawn player
float time = 0;
WidgetLabelPtr label;
PlayerDummyPtr player;
LightWorldPtr sun;
void my_pawn_destroyed()
my_pawn = nullptr;
// method creating a box
ObjectMeshDynamicPtr create_box(const Mat4 &transform, const vec3 &size)
mesh->addBoxSurface("box", size);
ObjectMeshDynamicPtr object = ObjectMeshDynamic::create(1);
object->setMesh(mesh);
object->setWorldTransform(transform);
return object;
// Main
int main(int argc, char **argv)
// init engine
Unigine::Engine::InitParameters init_params;
init_params.window_title = "UNIGINE Engine: Component System Usage Example (C++)";
Unigine::EnginePtr engine(init_params, argc, argv);
// enter main loop
AppWorldLogic world_logic;
AppSystemLogic system_logic;
engine->main(&system_logic, &world_logic, NULL);
return 0;
