Rotate Space Node
This node is used to transform a DIRECTION vector from one space (World, Object, Tangent, View) to another space. Suppose you have a vector in Object space and you want to use it where the same vector is required but in a different space - Tangent, for example. You can use this node to switch to the required space.
Double-click somewhere within a node to change initial (From) and target (To) space.
