体积的物体
Volumetric objects are used to simulate different kinds of volumes depending on their materials:Volumetric objects用于模拟不同类型的体量,具体取决于它们的材质:
  • Visible light volumes (they are not light sources, therefore, they don't illuminate the scene):可见光体积(它们不是光源,因此不会照亮场景):
  • Fog that obscures objects inside its volume Fog使其卷内的对象模糊不清
  • Clouds or shaped fog 或形状的雾
Types of Volumetric Objects
Volumetric Objects的类型#
There are four possible shapes for volumetric objects:体积对象有四种可能的形状:
To create various effects described above, you need to assign them different materials. Some materials can be assigned only to one type of volumetric objects.要创建上面描述的各种效果,您需要为它们分配不同的材质。某些材质只能分配给一种类型的体积对象。
Volumetric objects
Volumetric lights, fog and shafts体积灯,雾和轴
另请参阅#
最新更新: 2024-12-13
