系统选单
The System Menu window is displayed only when Syncker plugin is loaded. It can be opened by pressing Esc.System Menu 窗口仅在加载 Syncker 插件时显示。可以按 Esc 键打开。
The System Menu is available only when the UnigineEditor isn't loaded.只有未加载UnigineEditor时,系统菜单才可用。
Syncker
Syncker#
System Menu window for Syncker pluginSyncker 插件的 System Menu 窗口
This window is available if the Syncker plugin is used.如果使用 Syncker 插件,则此窗口可用。
  • Show debug info — shows debug information on the master and slaves. It includes the number of synchronized nodes and materials, a name of the view, the number of connected slaves (on the master computer), and others.Show debug info——显示有关主站和从站的调试信息。它包括同步节点和资料的数量,视图的名称,已连接的从属设备(在主计算机上)的数量等。
  • Show debug window — opens the debug window that allows monitoring the objects hierarchy at run time.Show debug window——打开允许在运行时监视对象层次结构的调试窗口
最新更新: 2024-12-13
