Unigine::ObjectMeshSplineCluster Class
Inherits from: Object
Members
static int type ( ) #
Returns the type of the node.
Return value
Node type identifier.
const char * getMeshPath ( ) const#
Returns the path to the current base mesh file for the object.
Return value
Path to the base mesh file.
int getNumMeshes ( ) const#
Returns the total number of meshes handled by the mesh spline cluster.
Return value
Number of meshes.
Math::mat4 getMeshTransform ( int num ) const#
Returns the transformation of the given mesh instance.
Arguments
  • int num - Mesh instance number.
Return value
Mesh transformation matrix.
bool getClusterTransforms ( const Math::WorldBoundBox & bounds, Vector< Math::mat4> & OUT_transforms ) #
Collects transformations (local coordinates) for all spline cluster meshes within the area specified by the given bounding box and puts them to the specified buffer.
Arguments
  • const Math::WorldBoundBox & bounds - Bounding box, defining the area, for which the transformations of spline cluster meshes are to be collected.
  • Vector< Math::mat4> & OUT_transforms - Buffer to store transformations of spline cluster meshes.
Return value
true, if there are transformations of spline cluster meshes; or false, if there are no transformations of spline cluster meshes found.
bool getClusterWorldTransforms ( const Math::WorldBoundBox & bounds, Vector< Math::Mat4> & OUT_transforms ) #
Collects transformations (world coordinates) for all spline cluster meshes within the area specified by the given bounding box and puts them to the specified buffer.
Arguments
  • Vector< Math::Mat4> & OUT_transforms - Buffer to store transformations of spline cluster meshes.
Return value
Last update: 19.04.2024
