API Samples
Unigine::TerrainGlobalDetail Class
This class is used to manage details of the global terrain object.
Members
void setAlbedoColor ( const Math::vec4 & color ) #
Sets the albedo color multiplier for the detail.
Arguments
  • const Math::vec4 & color - Albedo color multiplier.
Math::vec4 getAlbedoColor ( ) #
Returns the current albedo color multiplier for the detail.
Return value
void setAlbedoScale ( float scale ) #
Sets the intensity scale of the detail albedo texture.
Arguments
  • float scale - Albedo texture intensity scale value within the [0.0f; 1.0f] range.
float getAlbedoScale ( ) #
Returns the intensity scale of the detail albedo texture.
Return value
void setAlbedoTextureName ( const char * name ) #
Sets the path to the albedo texture of the detail.
Arguments
  • const char * name - Path to the albedo texture.
const char * getAlbedoTextureName ( ) #
Returns the path to the albedo texture of the detail.
Return value
void setBlendTriplanar ( float triplanar ) #
Sets the threshold value that controls smoothness of blending between the different projections of triplanar texture mapping.
This parameter is used only when triplanar texture mapping is enabled for the detail.
Arguments
  • float triplanar - Triplanar blending value within the [0.0f; 1.0f] range. Lower values produce sharper transitions between projections, while higher values make it smoother.
float getBlendTriplanar ( ) #
Returns the threshold value that controls smoothness of blending between the different projections of triplanar texture mapping.
Return value
void setDetail ( int detail ) #
Sets the value indicating if the detail uses the mask of the parent detail.
Arguments
  • int detail - 1 to use the mask of the parent detail or the one generated on its basis; 0 to use own mask.
int isDetail ( ) #
Returns the value indicating if the detail uses the mask of the parent detail.
Return value
1 if the detail uses the mask of the parent detail or the one generated on its basis; otherwise, 0.
void setDisplacement ( float displacement ) #
Sets the scale of displacement mapping according to the height texture.
Arguments
  • float displacement - Displacement scale value within the [0.0f; 1.0f] range. Higher values produce a greater displacement effect.
float getDisplacement ( ) #
Returns the scale of displacement mapping according to the height texture.
Return value
void setDisplacementOffset ( float offset ) #
Sets the displacement offset. This parameter controls the direction of displacement (inward or outward).
Arguments
  • float offset - Displacement offset value within the [-1.0f; 1.0f] range.
    • positive value - outward displacement.
    • 0 - points corresponding to height texture values less than 0.5 are displaced inwards, others are displaced outwards.
    • negative value - inward displacement.
float getDisplacementOffset ( ) #
Returns the displacement offset. This parameter controls the direction of displacement (inward or outward).
Return value
  • 0 - points corresponding to height texture values less than 0.5 are displaced inwards, others ar edisplaced outwards.
void setEnabled ( int enabled ) #
Enables or disables the detail.
Arguments
  • int enabled - 1 to enable the detail; 0 to disable it.
int isEnabled ( ) #
Returns a value indicating if the detail is enabled.
Return value
1 if the detail is enabled; otherwise, 0.
void setHeightTextureName ( const char * name ) #
Sets the path to the height texture of the detail.
Arguments
  • const char * name - Path to the height texture.
const char * getHeightTextureName ( ) #
Returns the path to the height texture of the detail.
Return value
void setMaskColor ( const Math::vec4 & color ) #
Sets the color of the detail mask.
Arguments
  • const Math::vec4 & color - Detail mask color.
Math::vec4 getMaskColor ( ) #
Returns the color of the detail mask.
Return value
Detail mask color.
void setMaskContrast ( float contrast ) #
Sets the contrast of the detail mask.
Arguments
  • float contrast - Detail mask contrast value within the [0.0f; 1.0f] range.
float getMaskContrast ( ) #
Returns the contrast of the detail mask.
Return value
void setMaskNumber ( int number ) #
Sets the index of the mask used by the detail.
Arguments
  • int number - Mask number.
int getMaskNumber ( ) #
Returns the index of the mask used by the detail.
Return value
Mask number.
void setMaskThreshold ( float threshold ) #
Sets the threshold that controls smoothness of blending of detail's height texture. Higher values provide smoother results. Blending is performed according to the detail's mask.
Arguments
  • float threshold - Blending threshold value within the [0.0f; 1.0f] range.
float getMaskThreshold ( ) #
Returns the threshold that controls smoothness of blending of detail's height texture. Higher values provide smoother results. Blending is performed according to the detail's mask.
Return value
void setMaskWidth ( float width ) #
Sets the width of blending of detail's height texture. Higher values provide wider areas. Blending is performed according to the detail's mask.
Arguments
  • float width - Blending width value within the [0.0f; 1.0f] range.
float getMaskWidth ( ) #
Returns the width of blending of detail's height texture. Higher values provide wider areas. Blending is performed according to the detail's mask.
Return value
void setMaxFadeDistance ( float distance ) #
Sets the maximum fade-out distance of the detail. Over this distance the detail smoothly becomes invisible due to alpha fading. It is counted starting from the maximum visibility distance.
Arguments
  • float distance - Maximum fade-out distance, in units. If a negative value is provided, 0 will be used instead. The default value is 0.
float getMaxFadeDistance ( ) #
Returns the maximum fade-out distance of the detail. Over this distance the detail smoothly becomes invisible due to alpha fading. It is counted starting from the maximum visibility distance.
Return value
void setMaxFadeHeight ( float height ) #
Sets the fade out height range for the detail mask. Over this height range above the maximum height value the detail mask will fade out until it is completely invisible. This parameter is used to modulate the detail mask by height.
Arguments
  • float height - Fade out height range value for the mask, in units. The default value is 0. Higher values provide smoother fade out.
float getMaxFadeHeight ( ) #
Returns the fade out height range for the detail mask. Over this height range above the maximum height value the detail mask will fade out until it is completely invisible. This parameter is used to modulate the detail mask by height.
Return value
void setMaxVisibleDistance ( float distance ) #
Sets the maximum visibility distance of the detail. It is the distance, starting from which the detail begins to fade out until it becomes completely invisible.
This parameter can be used to improve performance and reduce the tiling effect when looking at the terrain from a large distance.
Arguments
  • float distance - Maximum visibility distance, in units. If a negative value is provided, 0 will be used instead. The default value is inf.
float getMaxVisibleDistance ( ) #
Returns the maximum visibility distance of the detail. It is the distance, starting from which the detail begins to fade out until it becomes completely invisible.
Return value
void setMaxVisibleHeight ( float height ) #
Sets the maximum height value for the detail mask, starting from which the detail begins to fade out until it becomes completely invisible. This parameter is used to modulate the detail mask by height.
Arguments
  • float height - Maximum height value for the mask, in units. The default value is inf.
float getMaxVisibleHeight ( ) #
Return value
void setMinFadeDistance ( float distance ) #
Sets the minimum fade-in distance of the detail. Over this distance the detail smoothly becomes visible due to alpha fading. It is counted starting from the minimum visibility distance.
Arguments
  • float distance - Minimum fade-in distance, in units. If a negative value is provided, 0 will be used instead. The default value is 0.
float getMinFadeDistance ( ) #
Returns the minimum fade-in distance of the detail. Over this distance the detail smoothly becomes visible due to alpha fading. It is counted starting from the minimum visibility distance.
Return value
void setMinFadeHeight ( float height ) #
Sets the fade in height range for the detail mask. Over this height range below the minimum height value the detail mask will fade in until it is completely visible. This parameter is used to modulate the detail mask by height.
Arguments
  • float height - Fade in height range value for the mask, in units. The default value is 0. Higher values provide smoother fade in.
float getMinFadeHeight ( ) #
Returns the fade in height range for the detail mask. Over this height range below the minimum height value the detail mask will fade in until it is completely visible. This parameter is used to modulate the detail mask by height.
Return value
void setMinVisibleDistance ( float distance ) #
Sets the minimum visibility distance of the detail. It is the distance, starting from which the detail begins to fade in until it becomes completely visible.
Arguments
  • float distance - Minimum visibility distance, in units. If a negative value is provided, 0 will be used instead. The default value is -inf.
float getMinVisibleDistance ( ) #
Returns the minimum visibility distance of the detail. It is the distance, starting from which the detail begins to fade in until it becomes completely visible.
Return value
void setMinVisibleHeight ( float height ) #
Sets the minimum height value for the detail mask, starting from which the detail begins to fade in until it becomes completely visible. This parameter is used to modulate the detail mask by height.
Arguments
  • float height - Minimum height value for the mask, in units. The default value is -inf.
float getMinVisibleHeight ( ) #
Returns the minimum height value for the detail mask, starting from which the detail begins to fade in until it becomes completely visible. This parameter is used to modulate the detail mask by height.
Return value
void setName ( const char * name ) #
Sets the name of the detail.
Arguments
  • const char * name - Detail name.
const char * getName ( ) #
Returns the name of the detail.
Return value
Detail name.
void setNormalScale ( float scale ) #
Sets the intensity scale of the detail normal texture.
Arguments
  • float scale - Normal texture intensity scale value within the [0.0f; 1.0f] range.
float getNormalScale ( ) #
Returns the intensity scale of the detail normal texture.
Return value
void setNormalTextureName ( const char * name ) #
Sets the path to the normal texture of the detail.
Arguments
  • const char * name - Path to the normal texture.
const char * getNormalTextureName ( ) #
Returns the path to the normal texture of the detail.
Return value
void setOverlap ( int overlap ) #
Enables or disables overlap mode for the detail.
Arguments
  • int overlap - 1 to enable overlap mode for the detail; 0 to use overlay mode instead.
int isOverlap ( ) #
Returns a value indicating if overlap mode is enabled for the detail.
Return value
1 if overlap mode is enabled for the detail; otherwise, 0 (overlay mode is used).
void setRoughness ( float roughness ) #
Sets the roughness value multiplier for the detail.
Arguments
  • float roughness - Roughness value multiplier within the [0.0f; 1.0f] range.
float getRoughness ( ) #
Returns the roughness value multiplier for the detail.
Return value
void setRoughnessScale ( float scale ) #
Sets the intensity scale of the detail roughness texture.
Arguments
  • float scale - Roughness texture intensity scale value within the [0.0f; 1.0f] range.
float getRoughnessScale ( ) #
Returns the intensity scale of the detail roughness texture.
Return value
void setRoughnessTextureName ( const char * name ) #
Sets the path to the roughness texture of the detail.
Arguments
  • const char * name - Path to the roughness texture.
const char * getRoughnessTextureName ( ) #
Returns the path to the roughness texture of the detail.
Return value
void setTransform ( const Math::vec4 & transform ) #
Sets the transformation parameters of the detail.
Arguments
  • const Math::vec4 & transform - Vec4 transformation vector with the following components:
    • X - Tile size X - texture tile size along the X axis, in units.
    • Y - Tile size Y - texture tile size along the Y axis, in units.
    • Z - Offset X - texture offset along the X axis.
    • W - Offset Y - texture offset along the Y axis.
Math::vec4 getTransform ( ) #
Returns the current transformation parameters of the detail.
Return value
void setTriplanar ( int triplanar ) #
Enables or disables triplanar texture mapping for the detail.
Arguments
  • int triplanar - 1 to enable triplanar texture mapping for the detail; 0 to use planar UV mapping instead.
int isTriplanar ( ) #
Returns a value indicating if triplanar texture mapping is enabled for the detail.
Return value
1 if triplanar texture mapping is enabled for the detail; otherwise, 0 (planar UV mapping is used).
Last update: 13.12.2024
