Unigine::BucketHashMap Class
Header: | #include <UnigineHashMap.h> |
A hash map container template. The hash map stores items represented by key-value pairs in an unspecified order. Data are stored in the following way:
This approach to data storage may deem appropriate only in case you need the hashmap address to remain unchanged. For a more performance-friendly way to store hashmap data, use HashMap class.
Hash map can be used, for example, for searching among nodes by their names.
To create a new hash map, you can use the default constructor or one of the following ways:
- Create a hash map using an initializer list:
Source code (C++)The hash map that stores values of a custom type can be created as follows:
// create a hash map using an initializer list const BucketHashMap<String, int> hashMap_0{ { "a", 1 }, { "b", 2 }, { "c", 3 }, }; // check the result for (const auto &k : hashMap_0) Log::message("%s : %d \n", k.key.get(), k.data);
Source code (C++)// declare an enumeration enum class MyEnum { One, Two, Three, }; // create a hash map using an initializer list const BucketHashMap<String, MyEnum> hashMap_1 { { "One", MyEnum::One }, { "Two", MyEnum::Two }, { "Three", MyEnum::Three }, }; // check the result for (const auto &k : hashMap_1) Log::message("%s : %d \n", k.key.get(), k.data);
- Create a hash set using a copy constructor:
// create a hash map using an initializer list const BucketHashMap<String, int> initial{ { "a", 1 },{ "b", 2 },{ "c", 3 },{ "d", 4 }, }; // copy constructor BucketHashMap<String, int> copied(initial); //check the result for (const auto &k : copied) Log::message("%s : %d \n", k.key.get(), k.data);
You can change the created hash map by using the class member functions described in the article. Check some of the usage examples:
- To add items to the current hash map, you can use one of the append() or insert() functions:
// create hash maps using initializer lists BucketHashMap<String, int> initial{ { "a", 1 }, { "b", 2 }, { "c", 3 }, }; const BucketHashMap<String, int> to_append{ { "m", 7 }, { "n", 8 }, { "o", 9 }, }; // append items of one hash map to another initial.append(to_append); // insert an item into the "initial" hash map initial.insert("s", 10); // check the result for (const auto &k : initial) Log::message("%s : %d \n", k.key.get(), k.data);
- Get a value by the key from the hash map and insert an item if there is no such key:
// creare an empty hash map BucketHashMap<int, int> hashMap{ { 1, 10 } }; // try to get values by the specified keys Log::message("Value %d\n", hashMap[1]); // if there is no such key, it will be added to the hash map with the default value Log::message("Value %d\n", hashMap[2]); // check the result - the new item with the default value is added to the hash map for (const auto &k: hashMap) Log::message("%d : %d \n", k.key, k.data);
- Take an item from the hash map:
// create a hash map BucketHashMap<int, int> hashMap { {1, 1}, {2, 2}, {3, 3}, }; // declare a key and a value const int key = 0; const int value = 4; // append a new item to the hash map hashMap.append(key,value); // get an item iterator by its key auto it = hashMap.find(key); // take the item from the hash map int c = hashMap.take(it); // check the result - the taken item is removed from the hash map for (const auto &k : hashMap) Log::message("%d : %d \n", k.key, k.data);
- Remove an item from the hash map:
// create a hash map BucketHashMap<int, int> hashMap{ { 1, 1 },{ 2, 2 },{ 3, 3 }, }; // get an item iterator by its key auto it = hashMap.find(2); // remove the item from the hash map hashMap.remove(it); // check the result for (const auto &k: hashMap) Log::message("%d : %d \n", k.key, k.data);
- Get items by the values from the hash map:
- Get a value/values from the hash map:
// create a hash map BucketHashMap<String, int> hashMap{ { "a", 1 },{ "b", 2 },{ "c", 3 }, }; // get a key by its value Log::message("%d \n", hashMap.value("a")); // get a vector of all values of the hash map Vector<int> ret = hashMap.values(); for (int i = 0; i < ret.size(); i++) Log::message("%d \n",ret[i]);
BucketHashMap Class
Members
BucketHashMap ( ) #
Default constructor that produces an empty hash map.BucketHashMap ( std::initializer_list<Pair<Key,Value>> list ) #
Constructor. Creates a hash map from given key-value pairs.Arguments
- std::initializer_list<Pair<Key,Value>> list - List of pairs.
BucketHashMap ( const BucketHashMap& o ) #
Constructor. Creates a hash map by copying a source hash map.Arguments
- const BucketHashMap& o - Hash map.
BucketHashMap ( BucketHashMap&& o ) #
Constructor. Creates a hash map by moving a source hash map into it.Arguments
- BucketHashMap&& o - Hash map.
Iterator append ( const Key& key, const Value& value ) #
Appends an item with a given key and value to the hash map.Arguments
- const Key& key - Key.
- const Value& value - Value.
Return value
Item iterator.Iterator append ( const Key& key, Value&& value ) #
- const Key& key - Key to be copied to the hash map.
- Value&& value - Value to be moved to the hash map.
Return value
Item iterator.Iterator append ( Key&& key, const Value& value ) #
- Key&& key - Key to be moved to the hash map.
- const Value& value - Value to be copied to the hash map.
Return value
Item iterator.Iterator append ( Key&& key, Value&& value ) #
Return value
Item iterator.Value& append ( const Key& key ) #
Appends an item with a given key to the hash map.Arguments
Return value
Value.Value& append ( Key&& key ) #
Return value
Value.void append ( const BucketHashMap& o ) #
Appends items with all available keys from the argument hash to the hash map.Arguments
- const BucketHashMap& o - Hash map to be appended.
void append ( BucketHashMap&& o ) #
Appends items with all available keys by moving the argument hash to the hash map.Arguments
- BucketHashMap&& o - Hash map to be appended.
void append ( const Vector& vector ) #
Appends items with all available keys from the argument vector to the hash map.Arguments
- const Vector& vector - Vector containing the key (or keys) to be appended.
void append ( Vector&& vector ) #
Appends items with all available keys by moving the argument vector to the hash map.Arguments
- Vector&& vector - Vector containing the key (or keys) to be appended.
Iterator insert ( const Key& key, const Value& value ) #
Inserts an item with a given key and value into the hash map.Arguments
Return value
Item iterator.Iterator insert ( const Key& key, Value&& value ) #
Return value
Item iterator.Iterator insert ( Key&& key, const Value& value ) #
Return value
Item iterator.Iterator insert ( Key&& key, Value&& value ) #
Return value
Item iterator.Value& insert ( const Key& key ) #
Inserts an item with a given key into the hash map.Arguments
Return value
Value.Value& insert ( Key&& key ) #
Return value
Value.void insert ( const BucketHashMap& o ) #
Inserts items with all available keys by copying the argument hash to the hash map.Arguments
- const BucketHashMap& o - Hash map containing the key (or keys) to be inserted.
void insert ( BucketHashMap&& o ) #
Inserts items with all available keys by moving the argument hash to the hash map.Arguments
- BucketHashMap&& o - Hash map containing the key (or keys) to be inserted.
void insert ( const Vector& vector ) #
Inserts items with all available keys by copying the argument vector to the hash map.Arguments
- const Vector& vector - Vector containing the key (or keys) to be inserted.
void insert ( Vector&& vector ) #
Inserts items with all available keys by moving the argument vector to the hash map.Arguments
- Vector&& vector - Vector containing the key (or keys) to be inserted.
Value take ( const Key& key, const Value& def ) #
Removes an item from the hash map by its key and returns an item value. If there is no such item, the value set as default is returned.Arguments
- const Value& def
Return value
Removed item value.Value take ( const Key& key ) #
Removes an item from the hash map by its key and returns an item value. If there is no such item, a default-constructed value is returned.Arguments
Return value
Removed item value.Value take ( Iterator it ) #
Removes an item from the hash map by its iterator and returns an item value. If there is no such item, a default-constructed value is returned.Arguments
- Iterator it - Item iterator.
Return value
Removed item value.Value take ( ConstIterator it ) #
- ConstIterator it - Item iterator.
Return value
Removed item value.bool contains ( const Key& key, const Value& value ) const#
Checks if an item with a specified key and value exists in the hash map.Arguments
Return value
true if an item exists; otherwise, false.Iterator findData ( const Value& value ) #
Searches for an item with a specified value in the hash map.Arguments
Return value
Item iterator.ConstIterator findData ( const Value& value ) const#
Return value
Item iterator.void removeData ( const Value& value ) #
Removes the first occurrence of the specified value from the hash map.Arguments
Value& get ( Key&& key ) #
Returns a value by a specified key.Arguments
- Key&& key - Key.
Return value
Value.const Value& get ( const Key& key ) const#
Return value
Value.const Value& get ( const Key& key, const Value& value ) const#
Returns a value by a specified key. If there is no item with the key, the default value is returned.Arguments
- const Value& value - Default value.
Return value
Value.Value& operator[] ( Key&& key ) #
Hash map item access. The value is returned if it is available by the key; if the item is unavailable, a new (Key,Value) pair is added.Arguments
- Key&& key - Key.
Return value
Accessed item value, if available.Value& operator[] ( const Key& key ) const#
Hash map item access.Arguments
Return value
Accessed item value.Value value ( const Key& key ) const#
Returns a value with a specified key from the hash map. If there is no such key, returns a default-constructed value.Arguments
Return value
Accessed item value.Value value ( const Key& key, const Value& value ) const#
Returns a value with a specified key from the hash map. If there is no such key, returns the specified default value.Arguments
Return value
Accessed item value.const Value& valueRef ( const Key& key ) const#
Returns a reference to the value with a specified key from the hash map. If there is no such key, returns a default-constructed valuee.Arguments
Return value
Accessed item value.const Value& valueRef ( const Key& key, const Value& value ) const#
Returns a reference to the value with a specified key from the hash map. If there is no such key, returns a default value.Arguments
- const Key& key
Return value
Accessed item value.Vector<Value> values ( ) const#
Returns a vector of all values of the hash map.Return value
Vector of hash map values.void getValues ( Vector<Value>& values ) const#
Appends hash map values to a given vector.Arguments
- Vector<Value>& values - Vector of hash map values.
BucketHashMap & operator= ( const BucketHashMap & o ) #
Assigns the specified hash map by copying it.Arguments
- const BucketHashMap & o - Hash map.
Return value
Hash map.BucketHashMap & operator= ( BucketHashMap&& o ) #
Assigns the specified hash map by moving it.Arguments
Return value
Hash map.emplaceRange ( InputIt first, InputIt last ) #
Inserts the range of values specified by the argument iterators into the hash map.Arguments
- InputIt first - Iterator that identifies the beginning of the range.
- InputIt last - Iterator that identifies the end of the range.
bool contains ( const Key & k ) const#
Checks if the given key is present in the hash map.Arguments
- const Key & k - Key to be checked.
Return value
true if the hash map contains the specified key; otherwise, false.Iterator find ( const Key & k ) const#
Returns the iterator of the specified key.Arguments
Return value
Item iterator.ConstIterator find ( const Key & k ) const#
Return value
Item iterator.Item * findFast ( const Key & key ) const#
Finds an element with a specified key.Arguments
- const Key & key - Key to look for.
Return value
Pointer to the hash map item.Vector<Key> keys ( ) const#
Returns a vector containing all keys in the hash map.Return value
Vector of keys.void getKeys ( Vector<Key>& keys ) const#
Adds keys of the hash to the specified vector.Arguments
- Vector<Key>& keys - Vector to store the keys.
const Key & getKey ( size_t index ) const#
Returns the key by its index.Arguments
- size_t index - Index number of the key in the hash map.
Return value
Key.bool remove ( const Key& k ) #
Removes the specified key from the hash map.Arguments
- const Key& k - Key to be removed.
Return value
true if the key is removed successfully; otherwise, false.void remove ( Iterator it ) #
Removes an element currently pointed to by the iterator from the hash map.Arguments
- Iterator it - Iterator pointing to an element to be removed.
void remove ( ConstIterator it ) #
- ConstIterator it - Iterator pointing to an element to be removed.
void remove ( const BucketHashMap& o ) #
Removes the specified hash map from the current hash map.Arguments
void remove ( const Vector<Key>& v ) #
Removes the specified keys from the hash map.Arguments
- const Vector<Key>& v - Vector storing the keys.
bool erase ( const ConstIterator & it ) #
- const ConstIterator & it - Iterator pointing to the element to be removed.
Return value
true on success, otherwise false.bool erase ( const Iterator & it ) #
- const Iterator & it - Iterator pointing to the element to be removed.
Return value
true on success, otherwise false.bool erase ( const Key& k ) #
Removes an element having the specified key from the hash map.Arguments
- const Key& k - Key of the element to be removed.
Return value
true on success, otherwise false.void erase ( const BucketHashMap& o ) #
- const BucketHashMap& o - Hash map to be removed.
void erase ( const Vector<Key>& v ) #
void subtract ( const Vector<Key>& vector ) #
- const Vector<Key>& vector - Vector storing the keys.
void subtract ( const BucketHashMap & o ) #
- const BucketHashMap & o - Hash map to be removed.
void clear ( ) #
Removes all key-value pairs from the hash map.void destroy ( ) #
Removes all key-value pairs from the hash map and releases the memory.void reserve ( size_t size ) #
Reserves storage to avoid repeated reallocation.Arguments
- size_t size - Hash size to be reserved.
void shrink ( ) #
Removes unused capacity.Iterator begin ( ) const#
Returns an iterator that points to the first element in the hash map.Return value
Iterator pointing to the first element.Iterator end ( ) const#
Returns an iterator that points to the location succeeding the last element in the hash map.Return value
Iterator pointing to the last element.ConstIterator cbegin ( ) const#
Returns a const iterator that points to the first element in the hash map.Return value
ConstIterator pointing to the first element.ConstIterator cend ( ) const#
Returns a const iterator that points to the location succeeding the last element in the hash map.Return value
ConstIterator pointing to the last element.Counter size ( ) const#
Returns the number of key-value pairs in the hash map.Return value
Number of key-value pairs in the hash map.Counter space ( ) const#
Returns the current capacity (number of elements the hash can currently contain).Return value
Number of elements the hash can currently contain.size_t getMemoryUsage ( ) const#
Shows the amount of memory used by the hash map in bytes.Return value
Used memory in bytes.bool empty ( ) const#
Checks if the hash map is empty.Return value
true if the hash map is empty, otherwise falsevoid swap ( BucketHashMap & o ) #
Swaps this hash map with the hash map specified as the argument.Arguments
- BucketHashMap & o - Hash map.
