Customizing Mouse
Customizing Mouse
This example shows how to customize the mouse cursor appearance and change default mouse behavior in your application. It will help you to solve the following tasks:
  • Changing the default mouse cursor image.
  • Toggling mouse cursor's handling modes.
  • Customizing your application's icon and title.
Defining Mouse Behavior#
  • Grab - the mouse is grabbed when clicked (the cursor disappears and camera movement is controlled by the mouse). This mode is set by default.
  • Soft - the mouse cursor disappears after being idle for a short time period.
  • User - the mouse is not handled by the system (allows input handling by some custom module).
  • In the Editor, by selecting the corresponding option in the Controls Settings
  • Via code by adding the corresponding line to the logic (world or system logic, components, expressions, etc.)
Source code (C#)
ControlsApp.MouseHandle = Input.MOUSE_HANDLE.SOFT;
//or
ControlsApp.MouseHandle = Input.MOUSE_HANDLE.USER;
Customizing Mouse Cursor#
You can change the look of the mouse cursor in your application using any square RGBA8 image you want. This can be done by simply adding the following lines to your code (e.g. the world's init() method):
Source code (C#)
Image mouse_cursor = new Image("textures/cursor.png");
// resize the image to make it square
mouse_cursor.Resize(mouse_cursor.Width, mouse_cursor.Width);
if ((mouse_cursor.IsLoaded) && (mouse_cursor.Format == Image.FORMAT_RGBA8))
	// set the image for the OS mouse pointer
	Input.SetMouseCursorCustom(mouse_cursor);
	// show the OS mouse pointer
	Input.MouseCursorSystem = true;
Sample cursor image
Example Code#
  • Sets a custom icon and title for the application window.
  • Sets a custom mouse cursor.
  • Switches between the three handling modes on pressing the ENTER key.
You can use the following C# component:
AppMouseCustomizer.cs
Source code (C#)
using System;
using System.Collections;
using Unigine;
public class AppMouseCustomizer : Component
	// widgets
	WidgetLabel label1;
	WidgetLabel label2;
	WidgetButton button;
	private void Init()
			// preparing UI: creating a label and a button and adding them to the GUI
			label1 = new WidgetLabel(Gui.GetCurrent());
			label2 = new WidgetLabel(Gui.GetCurrent());
			button = new WidgetButton(Gui.GetCurrent(), "BUTTON");
			label1.SetPosition(10, 20);
			label2.SetPosition(10, 40);
			button.SetPosition(10, 80);
			Gui.GetCurrent().AddChild(label1, Gui.ALIGN_OVERLAP | Gui.ALIGN_TOP | Gui.ALIGN_LEFT);
			Gui.GetCurrent().AddChild(label2, Gui.ALIGN_OVERLAP | Gui.ALIGN_TOP | Gui.ALIGN_LEFT);
			Gui.GetCurrent().AddChild(button, Gui.ALIGN_OVERLAP | Gui.ALIGN_TOP | Gui.ALIGN_LEFT);
			EngineWindow MWindow = WindowManager.MainWindow;
			Image icon = new Image("textures/cursor.png");
			if ((icon.IsLoaded) && (icon.Format == Image.FORMAT_RGBA8))
				MWindow.SetIcon(icon);
			// set a custom title for the application window
			MWindow.Title = "Custom Window Title";
	private void Update()
		if (Game.Player.Controls.ClearState(Controls.STATE_USE) == 1)
			switch (ControlsApp.MouseHandle)
				case Input.MOUSE_HANDLE.GRAB:
					if (Input.MouseGrab)
						Input.MouseGrab = false;
						Gui.GetCurrent().MouseEnabled = true;
					Input.MouseHandle = Input.MOUSE_HANDLE.SOFT;
					Log.Message($"MOUSE_HANDLE switch from GRAB to SOFT\n");
					break;
				case Input.MOUSE_HANDLE.SOFT:
					Input.MouseHandle = Input.MOUSE_HANDLE.USER;
					Log.Message($"MOUSE_HANDLE switch from SOFT to USER\n");
					break;
				case Input.MOUSE_HANDLE.USER:
					Input.MouseHandle = Input.MOUSE_HANDLE.GRAB;
					Log.Message($"MOUSE_HANDLE switch from USER to GRAB\n");
					break;
				default:
					break;
			label1.Text = $"MOUSE COORDS: ({Input.MousePosition})";
			label2.Text = $"MOUSE MODE: {Input.MouseHandle}";
Last update: 2024-05-28
