Fundamentials
Core Library
Engine Classes
Bounds-Related Classes
Utility Classes
Static Mesh
A  static mesh is an object that represents a collection of vertices, edges and triangular faces (organized in polygons) defining the object's geometry. The static mesh can be moved, rotated and scaled, but cannot be modified: vertices of the static mesh are immutable.
Static meshes are usually used to add non-animated geometry: buildings, furniture, vehicles, and so on.
Static meshes consist of groups of polygons that called surfaces. Each surface requires a separate draw call to the GPU. To render a surface, the material should be assigned to it. Each surface has 2 UV channels. Read more about surfaces and materials here.
Static meshes are created in the third-party graphics programs (such as 3ds Max, Maya, Softimage, etc.) and and can be converted to the Unigine native format (.mesh). In Unigine meshes have a float precision. That is why it is highly recommended to export meshes from third-party graphic programs near the origin and then place the mesh in UnigineEditor.
The max number of surfaces organized in hierarchy for static mesh is 32768.
Adding a Static Mesh
To add a static mesh to the scene via UnigineEditor do the following:
  1. Run UnigineEditor.
  2. On the Menu bar, click Create -> Object -> Mesh Static.
  3. In the dialog window that opens, choose the path to the .mesh file.
  4. Place the mesh somewhere in the world.
You can change the path to the mesh at any time in the MeshStatic tab.
