Portal
A portal is a rectangular opening between two adjacent sectors, through which one sector can be partially seen if looking from another.
A Portal between Sectors
- WorldPortal class to edit portals via UnigineScript
Creating a Portal
To create a portal, choose the Add World Portal option in the list of nodes of Editor panel. In the opened creation dialog window specify initial parameters:
A Creation Window
Width | The width of the portal's rectangular, in units. |
Height | The height of the portal's rectangular, in units. |
After the initial parameters are set, click Ok and place the portal somewhere in the world.
Editing a Portal
In the Portal tab you can adjust the following parameters of the portal:
A Portal tab
Bounding Box Parameters
