Fundamentials
Core Library
Engine Classes
Bounds-Related Classes
Utility Classes
Physical Force
A physical force is a spherical object with a force that is applied to its center and attenuates as follows:
Here:
Name Description
distance Distance between the sphere center and the object.
radius Radius of the sphere in which the force is applied.
attenuation Force attenuation factor.
All physical bodies and particles that are within the radius of the force are pulled up to or away from the center of the physical force node. Also the bodies and particles can be rotated around the center of the physical force node.
The physical force will affect particles only if their physical mass is nonzero. The physical mass for the particles can be set on the Params tab of the Nodes panel.
The physical force can affect only a cloth, a rope or a rigid body. If the rigid body is used, a shape should be also assigned.
  • A PhysicalForce class to edit physical force nodes via UnigineScript
    1. force_00
    2. force_01
Adding Physical Force
To add a physical force to the scene via UnigineEditor:
  1. Run UnigineEditor.
  2. On the Menu bar, click Create -> Effect -> Physical Force.
  3. Click somewhere in the world to place the physical force.
The new physical force node will be added to UnigineEditor and you will be able to edit it via the Nodes panel. By default, the radius of the node is 1.
Editing Physical Force
On the Force tab of the Nodes panel, you can adjust the following parameters of the physical force:
Physical Physical mask. The physical mask of the physical force must match the physical mask of the physical object. Otherwise, the physical force won't affect the object.
Radius Radius for applying the physical force in units.
Atten Attenuation factor indicating how much the physical force decreases when the objects move away from the force center.
Attractor Attraction force applied to objects in the physical force radius. If a positive value is provided, objects will be pulled away from the force point. If a negative value is provided, objects will be pulled up to the force point.
Rotator Rotation force that is applied to objects in the physical force radius. If a positive value is provided, objects will be rotated clockwise. If a negative value is provided, objects will be rotated counter-clockwise.
