Настройка параметров узла
Generating Physical Objects
We need some geometric primitives that the player can move around the Play Area and shoot at. Let's generate them via code.
A primitive should have a body and a shape to collide with the Player Character and be affected by gravity. We have implemented interaction with bullets via Intersections at the previous step, so we should set the BulletIntersection bit for the object's Intersection mask.
When the robot moves fast and the application framerate is low, the character will be teleported each frame and may go through physical objects due to discrete collision detection. To avoid this we are going to use continuous collision detection.
Continuous collision detection is available for sphere and capsule shapes only.
  1. Create a new C++ component in your IDE and call it ObjectGenerator. Copy the following code to the corresponding files and save the solution. This component generates the physical objects and places them in the world.
    ObjectGenerator.h (C++)
    #include <UnigineGame.h>
    #pragma once
    class ObjectGenerator : public Unigine::ComponentBase
    	COMPONENT_DEFINE(ObjectGenerator, ComponentBase);
    	COMPONENT_INIT(init, 1); // 1st initialization order
    protected:
    	void init();
    ObjectGenerator.cpp (C++)
    #include "ObjectGenerator.h"
    REGISTER_COMPONENT(ObjectGenerator);
    void ObjectGenerator::init()
    	// cube
    	MeshPtr meshBox = Mesh::create();
    	meshBox->addBoxSurface("box_surface", Math::vec3(1.0f));
    	ObjectMeshStaticPtr box = ObjectMeshStatic::create(meshBox);
    	box->setTriggerInteractionEnabled(1);
    	box->setIntersectionMask(0x00000080, meshBox->findSurface("box_surface")); // check the BulletIntersection bit
    	box->setWorldTransform(translate(Math::Vec3(0.5f, 7.5f, 1.0f)));
    	box->setMaterial("mesh_base_0", "*");
    	box->setName("box");
    	Unigine::BodyRigidPtr bodyBox = BodyRigid::create(box);
    	ShapeBoxPtr shapeBox = ShapeBox::create(bodyBox, Math::vec3(1.0f));
    	ShapeSphere::create(bodyBox, 0.5f);
    	bodyBox->setShapeBased(0);
    	bodyBox->setMass(2.0f);
    	// sphere
    	MeshPtr meshShpere = Mesh::create();
    	meshShpere->addSphereSurface("sphere_surface", 0.5f, 9, 32);
    	ObjectMeshStaticPtr sphere = ObjectMeshStatic::create(meshShpere);
    	sphere->setTriggerInteractionEnabled(1);
    	sphere->setIntersectionMask(0x00000080, meshShpere->findSurface("sphere_surface")); // check the BulletIntersection bit
    	sphere->setWorldTransform(translate(Math::Vec3(4.5f, 5.5f, 1.0f)));
    	sphere->setMaterial("mesh_base_1", "*");
    	sphere->setName("sphere");
    	BodyRigidPtr bodySphere = BodyRigid::create(sphere);
    	ShapeSphere::create(bodySphere, 0.5f);
    	bodySphere->setShapeBased(0);
    	bodySphere->setMass(2.0f);
    	// capsule
    	MeshPtr meshCapsule = Mesh::create();
    	meshCapsule->addCapsuleSurface("capsule_surface", 0.5f, 1.0f, 9, 32);
    	ObjectMeshStaticPtr capsule = ObjectMeshStatic::create(meshCapsule);
    	capsule->setTriggerInteractionEnabled(1);
    	capsule->setIntersectionMask(0x00000080, meshCapsule->findSurface("capsule_surface")); // check the BulletIntersection bit
    	capsule->setWorldTransform(translate(Math::Vec3(4.5f, 0.5f, 3.0f)));
    	capsule->setMaterial("mesh_base_2", "*");
    	capsule->setName("capsule");
    	BodyRigidPtr bodyCapsule = BodyRigid::create(capsule);
    	ShapeCapsule::create(bodyCapsule, 0.5f, 1.0f);
    	bodyCapsule->setShapeBased(0);
    	bodyCapsule->setMass(2.0f);
    Do not change the size of an object after the creation. The physics doesn't support scaling nodes with Body attached.
  2. Build and run the solution in your IDE to generate a property file for the component.
  3. Switch back to the UnigineEditor and create a new Dummy Node, rename it to "object_generator", and place it somewhere in the world.
  4. Attach the created ObjectGenerator component to the "object_generator" node to make it generate physical objects on the initialization.
  5. Create 3 new materials in the UnigineEditor by choosing Create->Create Material in the Asset Browser. Make them children of the mesh_base material and give them names as specified in the previous code snippet (mesh_base_*).
  6. Select materials one by one in the Materials window and in the Parameters window switch to the Parameters tab and click on the color field near Albedo to choose different colors for the objects via the color picker.
  7. Save changes to the world via Ctrl + S.
  8. Run the project in your IDE to see the spawned physical objects in the world.
Last update: 09.07.2021
