Mesh Class
The Mesh class provides an interface for mesh loading, manipulating and saving.
By using this class, you can create a mesh, add geometry to it (e.g. box, plane, capsule or cylinder surface), add animations and bones (if you want to create a skinned mesh) and then use it to create the following objects:
Also you can get geometry of all of these objects via the Mesh class.
Features of the mesh are listed below:
- Each surface of the mesh supports several morph targets.
- Each surface has a quaternion-based tangent basis for the better loading speed.
- 8-bit vertex colors are supported.
- Each vertex of a surface has 2 sets of indices: coordinate and triangle indices. It improves the loading speed and reduces data duplication.
- Each vertex of a surface has 2 UV sets.
A bind pose transformation is stored for each mesh (even if there are no animations and animation frames). See also the getBoneTransforms() function.
NoticeThe 1st animation frame should not contain the bind pose.
Vertex Data and Indices#
Each surface of the mesh consists of triangles, and each triangle has 3 vertices. Thus, for each mesh surface we have:
Total number of vertices = 3 * number of triangles.
If a vertex belongs to several triangles, we have to store several copies of such vertex. Each of these copies would store information about position, normal, binormal, tangent and texture coordinates. In order to reduce data duplication and increase loading speed UNIGINE uses the optimization described below.
There are 2 separate vertex data buffers:
- CVertices coordinate buffer, which stores only vertex coordinates.
- TVertices triangle buffer, which stores vertex attributes such as normal, binormal, tangent, color, UV coordinates.
On the picture below, arrows are used to show normals:
The coordinate buffer is an array of coordinate vertices. In order to reduce data duplication, vertices of surface which have the same coordinates are saved only once in the buffer. For example, the coordinate buffer for the surface presented on the picture above is the following:
CB = [C0,C1,C2,C3]
Each polygon of the surface has 3 coordinates. We have 2 polygons, thus, we have 6 vertices, but we save in the CVertices buffer only 4, because 2 of them have the same coordinates. Each coordinate vertex contains coordinates (float[3]) of the vertex.
The triangle buffer is an array of triangle vertices. For example, the triangle buffer for the surface presented on the picture above is the following:
TB = [T0,T1,T2,T3,T4,T5]
Each triangle vertex can store:
- Normal
- Binormal
- Tangent
- 1st UV map texture coordinates
- 2nd UV map texture coordinates
- Color
The number of triangle vertices depends on the number of triangles, to which the vertex belongs. For example, if 2 triangles have 1 adjacent vertex with different normals for each triangle, 2 triangle vertices will be stored (the 1st and the 3rd vertices on the picture above). However, if the components are the same for all of the adjacent triangles, only 1 triangle vertex will be stored.
Both the coordinate and triangle vertices have indices. There are 2 index buffers to get proper cvertex and tvertex data for each vertex of each triangle of the mesh:
- CIndices buffer — coordinate indices, which are links to CVertices data.
- TIndices buffer — triangle indices, which are links to TVertices data.
The number of elements in these index buffers is equal to the total number of vertices of a mesh surface.
Coordinate Indices#
Each vertex of a mesh surface has a coordinate index - a number of the corresponding element of the coordinate buffer, where the data is stored. For the given surface the array of the coordinate indices is as follows:
CIndices = [Ci0,Ci1,Ci3,Ci1,Ci2,Ci3]
Here:
- The first 3 elements are the coordinate indices of the first (bottom) triangle.
- The second 3 elements are the coordinate indices of the second (top) triangle.
Triangle Indices#
Each vertex of a mesh surface also has a triangle index - a number of the corresponding element of the triangle buffer, where the data is stored. For the given surface the array of the triangle indices is as follows:
TIndices = [Ti0,Ti1,Ti5,Ti2,Ti3,Ti4]
Here:
- The first 3 elements are the triangle indices of the first (bottom) triangle.
- The second 3 elements are the triangle indices of the second (top) triangle.
- Article on Mesh File Formats.
- Description of the Mesh class functions.
Accessing a Mesh of a Mesh-Based Object#
You can access a Mesh of a mesh-based object (e.g. a static mesh, a skinned mesh and so on) via the getMesh() method of the corresponding object class.
For example, to access the Mesh of the ObjectMeshStatic, you can do the following:
MeshClass.cs
using System;
using System.Collections;
using Unigine;
public class MeshClass : Component
private void Init()
// a mesh-based object from which geometry will be obtained
ObjectMeshStatic box = new ObjectMeshStatic("core/meshes/box.mesh");
// create a mesh
Mesh boxMesh = new Mesh();
// copy the mesh of the ObjectMeshStatic into the created mesh
box.GetMesh(boxMesh);
The accessed mesh can be used at your discretion.
Copying a Mesh#
You may need to copy a Mesh in the following cases:
- When you have a mesh-based object that should be copied into another mesh-based object (new or existing one).
- When you have a Mesh that should be copied into another Mesh.
From One Mesh-Based Object to Another#
You can copy a mesh of a mesh-based object into another object in one of the following ways:
- By passing a Mesh to a new mesh-based object:
- Get a source mesh-based object.
- Create a Mesh class instance as a container.
- Copy the mesh of the source mesh-based object by using the getMesh() function.
- Create a new mesh-based object from the Mesh instance.
MeshClass.cs
Source code (C#)using System; using System.Collections; using System.Collections.Generic; using Unigine; [Component(PropertyGuid = "AUTOGENERATED_GUID")] // <-- this line is generated automatically for a new component public class MeshClass : Component { private void Init() { // create an instance of the ObjectMeshDynamic class ObjectMeshDynamic dynamic_0 = new ObjectMeshDynamic(); // create a Mesh class instance Mesh mesh = new Mesh(); // copy geometry of the dynamic mesh to the Mesh class instance dynamic_0.GetMesh(mesh); // create a new ObjectMeshDynamic instance from the obtained mesh ObjectMeshDynamic dynamic_1 = new ObjectMeshDynamic(mesh); } }
- By passing a Mesh to an existing mesh-based object:
- Get two mesh-based objects.
- Set the copied mesh to the second mesh-based object by using the setMesh() function.
MeshClass.cs
Source code (C#)using System; using System.Collections; using System.Collections.Generic; using Unigine; [Component(PropertyGuid = "AUTOGENERATED_GUID")] // <-- this line is generated automatically for a new component public class MeshClass : Component { private void Init() { // create ObjectMeshDynamic instances ObjectMeshDynamic dynamic_0 = new ObjectMeshDynamic(); ObjectMeshDynamic dynamic_1 = new ObjectMeshDynamic(); // create a Mesh class instance Mesh mesh = new Mesh(); // copy geometry of the dynamic mesh to the Mesh class instance dynamic_0.GetMesh(mesh); // put the obtained mesh to the second dynamic mesh dynamic_1.SetMesh(mesh); } }
From One Mesh to Another#
You can easily copy the existing mesh instance to a new one: pass the mesh instance as an argument to the constructor as follows:
MeshClass.cs
using System;
using Unigine;
private void Init()
// create a source Mesh instance
Mesh mesh_0 = new Mesh("core/meshes/box.mesh");
// pass the source mesh to the constructor of the second mesh
Mesh mesh_1 = new Mesh(mesh_0);
Accessing Mesh Surfaces#
By using the Mesh class, you can add new surfaces to a mesh or copy surfaces from one mesh to another.
Adding a New Surface to a Mesh#
You can add a new surface to a mesh in one of the following ways:
- Create a surface from scratch and then add verties and indices to it.
- Create a surface using one of the existing predefined surfaces: a plane, a prism, a sphere, a box, a capsule, a cylinder, a dodecahedron, an icosahedron.
Creating a Surface from Scratch#
The Mesh class allows creating a surface and adding vertices to it.
In the following example, we create a plane by adding vertices to the mesh:
- Create a Mesh class instance, add a surface and 4 vertices to it.
- Add 6 indices to create a plane.
NoticeYou can add indices explicitly as in the example below, or you can create indices for recently added vertices by using the createIndices() function.
- Create tangents and normals by using the createTangents() and createNormals() functions.
- Update bounds of the mesh to include all new vertices via the createBounds() function.
- Create an ObjectMeshDynamic instance using the mesh to check the result.
MeshClass.cs
using System;
using Unigine;
private void Init()
// create a mesh instance
// add a new surface
mesh.AddSurface("surface_0");
// add vertices of the plane
mesh.AddVertex(new vec3(0.0f, 0.0f, 0.0f), 0);
mesh.AddVertex(new vec3(0.0f, 0.0f, 1.0f), 0);
mesh.AddVertex(new vec3(0.0f, 1.0f, 0.0f), 0);
mesh.AddVertex(new vec3(0.0f, 1.0f, 1.0f), 0);
// add indices
mesh.AddIndex(0, 0);
mesh.AddIndex(1, 0);
mesh.AddIndex(2, 0);
mesh.AddIndex(3, 0);
// create tangents
mesh.CreateTangents(0);
// create mesh bounds
mesh.CreateBounds(0);
// create normals
mesh.CreateNormals(0);
// create an ObjectMeshDynamic from the Mesh instance
ObjectMeshDynamic dynamicMesh = new ObjectMeshDynamic(mesh);
Adding a Predefined Surface#
To add a predefined surface to a Mesh instance, use the required function. For example, to add a new capsule surface to a mesh, do the following:
- Create a Mesh class instance.
- Add a capsule surface via the addCapsuleSurface() function.
MeshClass.cs
using System;
using Unigine;
private void Init()
Mesh mesh_0 = new Mesh();
// add a capsule surface to the mesh
mesh_0.AddCapsuleSurface("capsule_surface", 1.0f, 2.0f, 200, 100);
ObjectMeshDynamic dynamicMesh = new ObjectMeshDynamic(mesh_0);
Copying Surfaces from One Mesh to Another#
In the following example, we create two meshes with different surfaces. The first mesh has the capsule surface, the second has the box surface. We copy the box surface from the second mesh to the first. The execution sequence is:
- Create 2 instances of the Mesh class and add the capsule and box surfaces to them.
- Add the box surface from the second mesh (mesh_1) to the first mesh (mesh_0) by using the addMeshSurface() function.
- Create a new ObjectMeshDynamic mesh from the mesh_0 instance.
MeshClass.cs
using System;
using Unigine;
private void Init()
// create mesh instances
Mesh mesh_1 = new Mesh();
// add surfaces for the added meshes
mesh_1.AddBoxSurface("box_surface", new vec3(2.2f));
// add the surface from the mesh_1 to the mesh_0 as a new surface
// with the name "new_box_surface"
mesh_0.AddMeshSurface("new_box_surface", mesh_1, 0);
// set the position of the dynamic mesh
dynamicMesh.WorldTransform = MathLib.Translate(new vec3(10.0f, 10.0f, 10.0f));
In the result, the Mesh will have 2 surfaces.
The ObjectMeshDynamic mesh will appear in the editor:
Adding a Surface to the Existing Mesh#
In the following example, we add a surface to the existing mesh and then add necessary vertices and indices for the surface:
- Create a new mesh instance from the file.
- Add a new surface to the mesh.
- Add vertices for the mesh surface.
- Create indices for recently created vertices by using the createIndices() function.
- Update bounds of the mesh to include the created surface by using the createBounds() function.
- Change the surface color.
MeshClass.cs
using System;
using Unigine;
private void Init()
// load a mesh from the file
Mesh mesh = new Mesh("core/meshes/box.mesh");
int surface_index = mesh.AddSurface("surface_triangle");
// add 3 vertices to the new surface
mesh.AddVertex(new vec3(-0.5f, 0.5f, 0.5f), 1);
mesh.AddVertex(new vec3(-0.5f, -0.5f, 0.5f), 1);
mesh.AddVertex(new vec3(-0.5f, -0.5f, 1.5f), 1);
// create indices for the new surface
mesh.CreateIndices(surface_index);
// create a new boundbox for the mesh including new surface
mesh.CreateBounds();
// create an ObjectMeshStatic from the Mesh instance
ObjectMeshStatic staticMesh = new ObjectMeshStatic(mesh);
// change the material color
staticMesh.SetMaterialParameterFloat4("albedo_color", new vec4(255, 255, 0, 255), 1);
The triangle surface added to the mesh:
Changing Vertex Attributes#
The Mesh class allows changing vertex attributes.
In the following example, we take a plane and change attributes of its vertices:
- Create a Mesh and add a new surface to it.
- Print the current normal values of 2 vertices to the console.
- Set new values for the normals and print the updated values to the console.
- Print the current tangent values of 2 vertices to the console.
- Set new values for the tangents and print the updated values to the console.
- Create a new ObjectMeshDynamic from the Mesh instance to check the result.
MeshClass.cs
using System;
using Unigine;
private void Init()
// add indices
// create normals
mesh.CreateNormals();
// create tangents
mesh.CreateTangents();
// get the normal vectors of the 1st and the 2nd normal before changing
vec3 normal_0 = mesh.GetNormal(0, 0, 0);
vec3 normal_1 = mesh.GetNormal(1, 0, 0);
// print values of the normals to the console
Log.Message("the 1st normal: {0}\n", normal_0.ToString());
Log.Message("the 2nd normal: {0}\n", normal_1.ToString());
// set new values for the normals
mesh.SetNormal(0, new vec3(1.0f, 1.0f, 0.0f), 0, 0);
mesh.SetNormal(1, new vec3(1.0f, 1.0f, 1.0f), 0, 0);
// get the new normal vectors of the 1st and the 2nd normal
vec3 new_normal_0 = mesh.GetNormal(0, 0, 0);
vec3 new_normal_1 = mesh.GetNormal(1, 0, 0);
Log.Message("the 1st normal: {0}\n", new_normal_0.ToString());
Log.Message("the 2nd normal: {0}\n", new_normal_1.ToString());
// get the tangent value
quat tangent = mesh.GetTangent(0, 0, 0);
// show the tangent value in the console
Log.Message("tangent: {0}\n", tangent.ToString());
// set a new value of the tangent
mesh.SetTangent(0, new quat(new vec3(1.0f, 0.0f, 0.0f), 20), 0, 0);
// get the new tangent value
quat new_tangent = mesh.GetTangent(0, 0, 0);
// show the tangent value after changing
Log.Message("tangent: {0}\n", new_tangent.ToString());
ObjectMeshDynamic newDynamicMesh = new ObjectMeshDynamic(mesh);
// set the dynamic mesh position
newDynamicMesh.WorldTransform = MathLib.Translate(new vec3(1.0f, 1.0f, 1.0f)) * (mat4)MathLib.RotateZ(90.0f);
When you launch the project, in the console you'll see the following:
the first normal is: -1 0 0 and the second is: -1 0 0
the first normal is: 1 1 0 and the second is: 1 1 1
tangent is: : 0,5 -0,5 -0,5 0,5
tangent is: : 0,1736 0 0 0,9848
When setTangent() and setNormal() functions were called, the normal and the tangent changed their values.
Let's comment this part of the code:
MeshClass.cs
The result will be different. You can see what influence the tangent has on the vertex:
Plane with changed tangent |
Plane with unchanged tangent |
Creating a Primitive#
The following example shows the manual creation of a box primitive by specifying its vertices, normals and texture coordinates:
MeshClass.cs
using System;
using Unigine;
private void Init()
// add a manually created box surface
AddManualBoxSurface(mesh, new vec3(2.0f, 2.0f, 2.0f), "box");
// clear the mesh pointer
mesh.Clear();
dynamicMesh.WorldTransform = MathLib.Translate(vec3.ZERO);
// set the texture
dynamicMesh.SetMaterialTexture("albedo", "core/textures/common/checker_d.dds", 0);
private void AddManualBoxSurface(Mesh mesh, vec3 size, string name) {
int surface_index = mesh.AddSurface(name);
// array of vertices
vec3[] vertex = {
new vec3(-0.5f, -0.5f, -0.5f), new vec3(0.5f, -0.5f, -0.5f), new vec3(-0.5f, 0.5f, -0.5f), new vec3(0.5f, 0.5f, -0.5f),
new vec3(-0.5f, -0.5f, 0.5f), new vec3(0.5f, -0.5f, 0.5f), new vec3(-0.5f, 0.5f, 0.5f), new vec3(0.5f, 0.5f, 0.5f) };
// array of face normals
vec3[] normals = {
vec3.RIGHT, vec3.LEFT,
vec3.FORWARD, vec3.BACK,
vec3.UP, vec3.DOWN };
// array of texture coordinates
vec2[] texcoords = {
new vec2(1.0f, 1.0f), new vec2(0.0f, 1.0f),
new vec2(0.0f, 0.0f), new vec2(1.0f, 0.0f) };
// list of indices for 6 polygons
int[,] cindices = {
{ 3, 1, 5, 7 },{ 0, 2, 6, 4 },
{ 2, 3, 7, 6 },{ 1, 0, 4, 5 },
{ 6, 7, 5, 4 },{ 0, 1, 3, 2 } };
// list of indices for a single quad made of 2 triangles
int[] indices = {
0, 3, 2, 2, 1, 0 };
// cycle through all quads
for (int i = 0; i < 6; i++)
// cycle through all indices of a single quad
for (int j = 0; j < 6; j++)
int index = indices[j];
mesh.AddVertex(vertex[cindices[i,index]] * size, surface_index);
mesh.AddNormal(normals[i], surface_index);
if (i == 4)
mesh.AddTexCoord0((vec2.ONE - texcoords[index]), surface_index);
else
mesh.AddTexCoord0(texcoords[index], surface_index);
// create indices per each 3 added vertices
// create tangents
mesh.CreateTangents(surface_index);
mesh.CreateBounds(surface_index);
