Package Class
The Package class is a data provider for the internal FileSystem class. You can load all resources via this class. This article describes the sample located in the <UnigineSDK>/source/csharp/samples/Api/Systems/Package/ directory.
- An example can be found in the <UnigineSDK>/source/csharp/samples/Api/Systems/Package/ directory.
- The C++ API Unigine::Package class and the Unigine::FileSystem class which have the same methods and behavior as in the C# API.
Package Class Usage Example#
C# Side#
To use the Unigine.Package class, you should create your own class and inherit it from the Unigine.Package class and override virtual methods.
using System;
using System.IO;
using File = System.IO.File;
using System.Runtime.InteropServices;
using Unigine;
class UnigineApp
class MyPackage : Package
private FileStream file;
public MyPackage()
Log.Message("MyPackage.ctor(): called\n");
~MyPackage()
Log.Message("MyPackage.dtor(): called\n");
// list of files
public override int GetNumFiles()
Log.Message("MyPackage.GetNumFiles(): called\n");
return 2;
public override string GetFileName(int num)
Log.Message("MyPackage.GetFileName({0}): called\n", num);
if (num == 0)
return "data/package.usc";
if (num == 1)
return "data/package.world";
return "";
// select file
public override bool SelectFile(string name, out int size)
Log.Message("MyPackage.SelectFile(\"{0}\",): called\n", name);
try
file = null;
if (name == "data/package.usc")
file = File.OpenRead("my_data/package.usc");
if (name == "data/package.world")
file = File.OpenRead("my_data/package.world");
catch (Exception e)
Log.Error("MyPackage.SelectFile(): {0}\n", e.Message);
size = 0;
return false;
size = (int)file.Length;
return true;
// read file
public override bool ReadFile(IntPtr data, int size)
Log.Message("MyPackage.ReadFile(,{0}): called\n", size);
try
byte[] src = new byte[size];
int ret = file.Read(src, 0, size);
Marshal.Copy(src, 0, data, ret);
catch (Exception e)
Log.Error("MyPackage.ReadFile(): {0}\n", e.Message);
return false;
return true;
[STAThread]
static void Main(string[] args)
// add package
MyPackage package = new MyPackage();
FileSystem.PreloadExternPackage(package);
// initialize engine
Engine.Init(args);
// enter main loop
Engine.Main();
// shutdown engine
Engine.Shutdown();
The MyPackage class has overridden ReadFile(), SelectFile(), GetFileName() and GetNumFiles() functions. The class operates with two files located in the my_data folder.
In the Main() function we create an instance of the MyPackage class and add it to the FileSystem before initializing the engine using the PreloadExternPackage() method.
Output#
The following result will be shown in the console:
