Time Node
This node outputs a float value of time in seconds since the moment of the application startup.
This node has parameters (see below) that define its behavior, to view and change them double-click somewhere inside the node.
Parameters
Mode |
Timer mode, defines how the time is calculated, when you put animations and particle simulation on pause. One of the following options::
Type |
Defines the output value, either current or previous frame time can be returned depending on the option selected. One of the following options::
