A Car with Wheel Joints
Car with wheel joints
This example shows how to:
  1. Prepare visual geometry of the car (frame and wheels) and add it to the scene.
  2. Set up a third-person camera that follows the car and orbits around it.
  3. Assign rigid bodies and collision shapes to the wheels and the frame.
  4. Set up parameters of the bodies and shapes (mass, rotation, radius, hegiht, etc.).
  5. Connect the wheels to the frame using wheel joints. Set up parameters of the joints.
    Do not use real masses (e.g. 2000 kg for the frame and 10 kg for the wheels), as joints may become unstable! It might be better to use 64 kg for the body and 25 kg for each wheel to provide realistic behavior.
  6. Enable the car movement using joint motors by setting up the movement controls with the corresponding keyboard keys.
Step 1. Importing Vehicle Geometry#
The first thing we are going to address in this tutorial is the geometry of our car. It is possible to use any other custom made model for the vehicle appearance. Every wheel and the frame will be individual independent nodes in the world, so make sure that your vehicle model includes separate meshes for the wheels and the frame.
Right now we are going to take the vehicle model from the content addon included in the SDK and then add some physical parameters to the geometry to achieve a viable driving simulation.
  1. Let's create an empty C++ project.
  2. Download the Eastern European Countryside add-on from Add-On Store at https://store.unigine.com/ and add it to the project by dragging into the project data/ folder in the Asset Browser. In the Import Package window that opens, click the Import Package button and wait until the add-on contents are imported.
  3. Launch the Editor via the Open Editor button. For your vehicle you can choose any of the minibus nodes located in data/countryside/minibus or import your own model in any supported file format.
    A minibus vehicle model has the body frame as the parent node and its wheels as child nodes.
  4. In the Asset Browser, right-click on a minibus node you like the most and choose Place as Node Content. Place the vehicle on the ground in the world. As we don't plan to use multiple instances of the car, we simply put all its parts directly to the scene, without the NodeReference container.
Step 2. Setting Up Camera#
Let’s create a camera for a third-person view. While the camera follows the car, the player can control the viewing direction (rotate the camera) with the mouse. To achieve this, perform the following:
  1. In the World Nodes window, delete the first_person_controller containing the default camera.
  2. Create a custom Persecutor Camera to follow the car. Go to Create -> Camera -> Persecutor and then place it near the vehicle.
  3. Check the Main Player option in the Parameters tab of the PlayerPersecutor to make it the default camera in the world.
  4. Delete the default Persecutor_Target node from the World Nodes window hierarchy and set our minibus as the target node for the PlayerPersecutor camera instead.
  5. To put the camera closer to the vehicle, set the Max Distance parameter for the PlayerPersecutor to 8.
Step 3. Setting Up Physical Bodies and Shapes#
In order to give our car some physical properties, we must assign physical bodies and approximating volumetric shapes to its frame and wheels. To achieve this, do the following:
Do not change the scale of the frame or wheel nodes, since the physics simulation does not support it. The scale of all nodes should be equal to 1 along all axes, to ensure correct physics simulation.
  1. Go to the Parameters tab of the minibus frame (the minibus_ambulance node) and, in the Physics tab, assign a physical rigid body by selecting Body -> Rigid. Also, add a box shape to the body (Shape -> Box).
  2. Set the mass of ShapeBox to 100.
  3. Disable the Shape-Based option for the frame’s rigid body to turn off automatic calculation and customize mass distribution of the vehicle. Set the third component of the CMass parameter to 0.25 effectively lowering the center of mass.
  4. For each wheel (child nodes of minibus_ambulance), go to the Parameters tab and, in the Physics section, assign a rigid body with a cylinder shape that roughly approximates the shape of the wheel mesh. You may need to rotate ShapeCylinder and adjust its radius and height to position it properly (see the image below).
    In the World Nodes window, you can select multiple wheel nodes at the same time by holding Shift key and selecting the first and the last one. This way you will be able to add bodies and shapes to all wheels simultaneously.
Step 4. Setting Up Joints#
For the wheels to be connected to the frame and behave realistically, we must connect them using wheel joints. These joints not only remove degrees of freedom providing motion constraints, but also simulate vehicle suspension and motor torque for wheels.
We need to connect the body of every wheel to the frame’s body using wheel joints.
  1. To do so, select the frame of the minibus (the minibus_ambulance node) in the World Nodes hierarchy window and go to the Joints section of the Physics tab. There you must specify the Wheel type for the joint and click the Add button.
  2. You shall see the following dialog window. Connect the frame body to every wheel’s body by selecting every wheel one by one. The specified rigid body will be connected to the rigid body of the car using a wheel joint.
You will end up with four wheel joints connecting corresponding wheels’ bodies to the frame’s body (you may name them accordingly).
To configure the setup, do the following for every wheel joint (select them one by one and tweak settings below):
  1. Press Fix 0 button to fix Anchor 0 point to the wheel position. This will place the joint in the correct position for this wheel.
  2. Set the number of joint solving Iterations to 16 making the physical simulation more stable.
    You can select multiple joints at the same time by holding Shift key and selecting the first and the last one. This way you will be able to set the same settings to all joints simultaneously.
  3. Next, set the following values to the joint’s parameters to achieve a plausible simulation behavior.
  4. Wheel joints are based on physics raycasting. To make them interact with the ground properly, enable Physics Intersection for the surface of the ground_plane node in the Parameters tab.
Step 5. Applying Velocity to Wheels#
Now let’s create a C++ component to implement driving and steering functionality for the car. To achieve this, do the following:
  1. To start writing code we should open our project in an IDE. Go to SDK Browser and choose the Open Code IDE button.
  2. In an IDE create a new C++ class (*.h and *.cpp files) and call it Car. Make sure it inherits from the Unigine::ComponentBase class.
  3. Get references to joints from the wheel nodes and define variables for the velocity, acceleration and torque values.
    Car.h
    Car.h
    #pragma once
    #include <UniginePhysics.h>
    #include <UniginePlayers.h>
    #include <UnigineControls.h>
    #include <UnigineGame.h>
    #include <UnigineMathLib.h>
    class Car : public Unigine::ComponentBase
    	// declare constructor and destructor for our class and define a property name
    	COMPONENT_DEFINE(Car, ComponentBase)
    	COMPONENT_INIT(init);
    	COMPONENT_UPDATE(update);
    	COMPONENT_UPDATE_PHYSICS(updatePhysics);
    	// driving parameters
    	PROP_PARAM(Float, acceleration, 50.0f);
    	PROP_PARAM(Float, max_velocity, 90.0f);
    	PROP_PARAM(Float, default_torque, 5.0f);
    	// wheel joints
    	PROP_PARAM(Node, wheel_bl);
    	PROP_PARAM(Node, wheel_br);
    	PROP_PARAM(Node, wheel_fl);
    	PROP_PARAM(Node, wheel_fr);
    protected:
    	void init();
    	void update();
    	void updatePhysics();
    	// wheel joints
    	Unigine::JointWheelPtr joint_wheel_bl;
    	Unigine::JointWheelPtr joint_wheel_br;
    	Unigine::JointWheelPtr joint_wheel_fl;
    	Unigine::JointWheelPtr joint_wheel_fr;
    	// settings of input controls
    	Unigine::ControlsPtr controls;
    	// current driving parameters
    	float current_velocity = 0.0f;
    	float current_torque = 0.0f;
    Car.cpp
    Car.cpp
    #include "Car.h"
    REGISTER_COMPONENT(Car);
    void Car::init()
    	// get the wheel joints from the nodes
    	if (wheel_bl)
    		joint_wheel_bl = checked_ptr_cast<JointWheel>(wheel_bl->getObjectBody()->getJoint(0));
    	if (wheel_br)
    		joint_wheel_br = checked_ptr_cast<JointWheel>(wheel_br->getObjectBody()->getJoint(0));
    	if (wheel_fl)
    		joint_wheel_fl = checked_ptr_cast<JointWheel>(wheel_fl->getObjectBody()->getJoint(0));
    	if (wheel_fr)
    		joint_wheel_fr = checked_ptr_cast<JointWheel>(wheel_fr->getObjectBody()->getJoint(0));
    	// get the settings of input controls relevant to the player (camera)
  4. Then add control inputs processing to determine the current torque and velocity to be applied to wheel joints.
    Car.cpp
    Car.cpp
    void Car::update()
    	// get the time it took to render the previous frame
    	float deltaTime = Game::getIFps();
    	// process control inputs
    	if (controls)
    		// set the torque and increase the current velocity if the forward button is pressed
    		if (controls->getState(Controls::STATE_FORWARD) != 0)
    			current_torque = default_torque;
    			current_velocity = Math::max(current_velocity, 0.0f);
    			current_velocity += deltaTime * acceleration;
    		// set the torque and decrease the current velocity if the backward button is pressed
    		else if (controls->getState(Controls::STATE_BACKWARD) != 0)
    			current_velocity = Math::min(current_velocity, 0.0f);
    			current_velocity -= deltaTime * acceleration;
    		// exponentially decrease the current velocity when neither throttle nor brakes are applied
    		else
    			current_velocity *= Math::exp(-deltaTime);
  5. To move the car forward or backward, we are going to use joint motors of the front wheels:
    • Setting a positive velocity value will move our car forward.
    • Setting a negative velocity value will move our car backward.
    Each physics frame, we apply current angular velocity and torque to the wheel joints based on the user input.
    Car.cpp
    Car.cpp
    // actually apply the torque and velocity to the front wheel joints
    void Car::updatePhysics()
    	joint_wheel_fl->setAngularVelocity(current_velocity);
    	joint_wheel_fr->setAngularVelocity(current_velocity);
    	joint_wheel_fl->setAngularTorque(current_torque);
    	joint_wheel_fr->setAngularTorque(current_torque);
Step 6. Implementing Steering and Braking#
To provide the ability to turn left or right as well as the ability to slow down with brakes, we shall implement some additional logic that turns the front wheels and stops the rear ones. To achieve this, do the following:
  1. Add the following code to the Car component to add the front wheels turning and braking support.
    Car.h
    Car.cpp
    PROP_PARAM(Float, turn_speed, 50.0f);
    PROP_PARAM(Float, car_base, 3.0f);
    PROP_PARAM(Float, car_width, 2.0f);
    float current_turn_angle = 0.0f;
    float max_turn_angle = 30.0f;
    Car.cpp
    Car.cpp
    void Car::update()
    	if (controls)
    		// turn the front wheels based on the direction input
    		if (controls->getState(Controls::STATE_MOVE_LEFT) != 0)
    			current_turn_angle += deltaTime * turn_speed;
    		else if (controls->getState(Controls::STATE_MOVE_RIGHT) != 0)
    			current_turn_angle -= deltaTime * turn_speed;
    		else
    			// get rid of the front wheel wiggle
    			if (Math::abs(current_turn_angle) < 0.25f)
    			// align the front wheels if there are no more direction input
    			current_turn_angle -= Math::sign(current_turn_angle) * turn_speed * deltaTime;
    		// apply braking by maxing out the angular damping if the brake button is pressed
    		if (controls->getState(Controls::STATE_USE) != 0)
    			joint_wheel_bl->setAngularDamping(10000.0f);
    			joint_wheel_br->setAngularDamping(10000.0f);
    		else
    			joint_wheel_bl->setAngularDamping(0.0f);
    			joint_wheel_br->setAngularDamping(0.0f);
    	// clamp the velocity and the front wheels turn angle
    	current_velocity = Math::clamp(current_velocity, -max_velocity, max_velocity);
    	current_turn_angle = Math::clamp(current_turn_angle, -max_turn_angle, max_turn_angle);
    	// figure out the correct turn angle for the front wheels
    	float angle_0 = current_turn_angle;
    	float angle_1 = current_turn_angle;
    	if (Math::abs(current_turn_angle) > Math::Consts::EPS)
    		float radius = car_base / Math::tan(current_turn_angle * Math::Consts::DEG2RAD);
    		float radius_0 = radius - car_width * 0.5f;
    		float radius_1 = radius + car_width * 0.5f;
    		angle_0 = Math::atan(car_base / radius_0) * Math::Consts::RAD2DEG;
    		angle_1 = Math::atan(car_base / radius_1) * Math::Consts::RAD2DEG;
    	joint_wheel_fr->setAxis10(Math::rotateZ(angle_1).getColumn3(0));
    	joint_wheel_fl->setAxis10(Math::rotateZ(angle_0).getColumn3(0));
  2. Before you can use the C++ component you should initialize the Component System. Modify the init() method of the AppSystemLogic class as shown below (AppSystemLogic.cpp file).
    AppSystemLogic.cpp
    AppSystemLogic.cpp
    int AppSystemLogic::init()
  3. Build and run the project via your IDE (press Ctrl + F5 in Visual Studio), the Component System will generate a property-file for the Car component.
  4. Switch back to UnigineEditor and select the root minibus node in the World Nodes window. Then click Add New Property in the Parameters window and assign the newly generated Car property.
  5. Next, assign wheels (ObjectMeshStatic nodes) to the corresponding fields of the Car property as specified below.
Congratulations! Now you can finally drive the car around the world. If the current physics of the car is not suitable for your needs, you can always fine tune the parameters of the wheel joints and achieve the results you need. Also, see the Basic Programming How-To Livestream for the hands-on vehicle implementation and discussions. The full source code of the Car component is given below.
Car.h
Car.h
#pragma once
	// wheel joints
protected:
	void init();
	void update();
	// wheel joints
Car.cpp
Car.cpp
#include "Car.h"
void Car::init()
	if (wheel_bl)
	if (wheel_br)
	if (wheel_fl)
	if (wheel_fr)
void Car::update()
	if (controls)
		else
		else
		else
Last update: 2024-08-16
