Georeferenced Terrain Generation Asset Pack
The Georeferenced Terrain Generation add-on provides a set of ready-to-use assets required for accomplishing the Georeferenced Terrain Generation tutorial in Sandworm. The pack contains the following assets: Georeferenced Terrain Generation资源包提供了完成SandwormGeoreferenced Terrain Generation教程所需的一组准备使用的资源。加载项包含以下资源:
  • Elevation and Imagery data sources that are a part of the European Digital Elevation Model (EU-DEM), version 1.1, provided in the framework of the Copernicus programme funded by the European Union作为欧洲数字高程模型(EU-DEM)1.1版一部分的高程和图像(Elevation和Imagery)数据源是在由欧盟资助的哥白尼计划的框架中提供的
  • Landcover data prepared using data and information of the Corine Land Cover (CLC) 2006, version 18.5.1, provided in the framework of the Copernicus programme funded by the European Union土地覆盖(Landcover)数据是使用由欧洲联盟资助的哥白尼计划框架提供的2006年Corine土地覆盖(CLC)版本18.5.1的数据和信息准备的
  • Vector data sources provided by OpenStreetMap (www.openstreetmap.org)OpenStreetMap提供的向量(Vector)数据源(www.openstreetmap.org
  • Nodes (including 3D models and textures) required for generation of vegetation, roads, fence, and GSM towers生成植被,道路,栅栏和GSM塔所需的 节点(包括3D模型和纹理)
Using Assets from Add-On使用资源包中的资源#
To use the add-on:使用资源包:
  • 安装Georeferenced Terrain Generation资源包(可通过Assets部分中的UNIGINE SDK Browser获得)并将其添加到您的项目中(通过单击 Other Actions -> Configure Project -> Assets UNIGINE SDK BrowserProjects部分中)。
  • Follow instructions given in the tutorial and use assets stored in the sw_georeferenced folder. 请遵循教程中给出的说明,并使用存储在sw_georeferenced文件夹中的资源。
最新更新: 2023-12-19
