A UNIGINE Build script is a one-touch solution to rebuild the engine tools with different options.
To invoke the build script, run <UnigineSDK>/source/build.py from a console (see examples below). Note that you need to properly set the development environment to get the script working.
Built files can be found in the target directory, in bin and lib folders.
Rebuilding the UNIGINE engine tools is available only in the full source version of SDK.
Command Line Options#
--help Display a help message and exit.
--type TYPE
Type of the build (multiple options are accepted). The default is release.
all Both debug and release versions of components are built at the same time
release Production version
debug Version with detailed debugging information
--csharp Build the C# libraries and the application.
--component COMPONENT
UNIGINE component to build.
all UNIGINE stand-alone tools, plugins and C++ samples. If the --csharp is passed, C# and samples will be built too.
plugins Plugins
tools Stand-alone tools
samples C++ samples. If the --csharp is passed, both the C++ and C# samples will be built.
qtapp Build Qt main application
build_tool Command-line Build Tool
runtimes_generator Runtimes Generator command-line tool
--precision PRECISION
Create a build with single or double precision coordinates support. The default is float.
float Use single precision coordinates
double Use double precision coordinates
--plugins PLUGIN
Build C++ plugins individually or in groups. The default is no. In the evaluation version of UNIGINE SDK, some plugins cannot be rebuilt.
no Do not build plugins
all Build all available plugins
EasyBlend EasyBlend plugin
Oculus Plugin for the Oculus Rift virtual display
Projection Projection plugin
Separate Separate plugin
Surround Surround plugin
OpenVR OpenVR plugin
Varjo Varjo plugin
Wall Plugin for multi-monitor support
FbxImporter FbxImporter plugin
CadImporter CadImporter plugin
GPUMonitor GPUMonitor plugin
Interface Interface plugin
LeapMotion LeapMotion plugin
OpenFlight Import plugin for OpenFlight
Steam Plugin for Steam integration
Syncker Plugin for Multi-channel rendering synchronization
Kinect Kinect2 plugin
VrpnClient VRPN plugin
ARTTracker ARTTRACK plugin
Geodetics Geodetics plugin
Plugins are specified in the following way:
Shell commands
--component plugins --plugin PluginName1 PluginName2 PluginName3
--tool TOOL
Build UNIGINE tools individually or in groups (--component parameter should be set to all or tools). The default is all.
all Build all available tools
Archiver Archiver tool
Interpreter Interpreter tool
Resource Resource tool
Tools are specified in the following way:
Shell commands
--component tools --tool ToolName1 ToolName2 ToolName3
--log LOGFILE Create a log file that contains a record of the compilation. By default, no name is specified and the log file is not created.
--simd SIMD
Perform parallel compilation using the SIMD operations. The default is sse2.
no Do not use
sse Use SSE technology
sse2 Use SSE2 technology
avx Use AVX technology
--vs VS
Version of Visual Studio build tools to be used. The default is v140.
v140 Use VS2015, build tools v140
v141 Use VS2017, build tools v141
--jobs JOBS
Perform parallel compilation. An argument specifies the number of parallel building jobs to be run. The default is all.
all Use all available CPU cores to run the building jobs
1 Use 1 thread
2 Use 2 threads
3 Use 3 threads
4 Use 4 threads
6 Use 6 threads
8 Use 8 threads
16 Use 16 threads
--clean_source Clean up the source directory before the compilation starts (i.e. remove pdb, ilk, exp files, etc.).
--clean_target Delete everything from the target directory before the compilation starts.
--clean_only Full clean up without compilation. The default is false.
--skip_errors Skip build errors (if any). When this option is set, the build.py script is run for all of the specified tools and plugins, even if errors occur. The build errors are displayed at the end.
This option allows skipping build errors only for tools and plugins.
This option allows you to check which plugins and tools have not been built successfully and speeds up error fixing.
--sample List of samples separated by spaces.
--verbose Enable verbose output.
--dry-run Print commands without building.
--batch Batch mode for msvc compiler.
--watermark Watermark type.
no Do not use any additional features.
evaluation Enable the TELNET terminal.
confidential Use the password. The <UnigineSDK>/source/engine/password.resource file should be created by using the Resource tool before rebuilding.
default Include microprofile - tiny third-party profiler with web integration.
--cmake_gen Cmake generators.
TARGET The last optional argument is a target directory to store builds, by default it's ../. Two additional directories in the target directory will be created: bin and lib to store the binary executable and libraries, respectively.
If no options are set, the script will be built with default values.
Usage Examples#
To build all C++ samples, type:
Shell commands
<UNIGINE_SDK>\source\build.py --component samples
To build all C# samples, type:
Shell commands
<UNIGINE_SDK>\source\build.py --component samples --sample cs_all
To build a specific sample, you need to indicate its name, as well. For example, for a C# sample:
Shell commands
<UNIGINE_SDK>\source\build.py --component samples --csharp --sample <sample_name>
To build the release version of the GPUMonitor plugin, use the following command:
Shell commands
<UNIGINE_SDK>\source\build.py --component plugins --plugin GPUMonitor
Last update: 2023-12-19
