Function Node
This node is used to write your own custom functions, you can have multiple functions inside a single node and even call one function from another.
When to use the Function node:
  • to implement large functions via code;
  • to copy some functions from external sources;
  • if you are a programmer you got used to write code and feel uncomfortable with node-based workflow;
Please keep in mind that some functionality might be unavailable as graph nodes yet, but via code you have access to everything in Unigine's graphics API.
Last update: 2023-12-19
