C# Third Person Platformer
C# Third Person Platformer showcases the capabilities of the C# Component System. A simple third-person shooter game demonstrates performance and flexibility of the logic system using familiar concepts. C# Third Person Platformer展示了 C#组件系统的功能。一个简单的第三人称射击游戏使用熟悉的概念演示了逻辑系统的性能和灵活性。
Programming is easy: application logic is implemented in components that can be assigned to any nodes in the virtual world to extend their functionality.编程很容易:应用程序逻辑在可以分配给虚拟世界中任何节点的组件中实现,以扩展其功能。
To launch this demo:启动此演示:
  1. Install one of the following IDEs to work with the source code: Visual Studio Code, recommended (C# extension is required)安装以下IDE之一以使用源代码:
  2. Download and install .NET 5. 下载并安装.NET Core 3.1
  3. Open SDK Browser, go to the Samples tab, and click Copy as Project under this Demo. If the option is not available, you should install the C# Third Person Platformer demo.
    打开SDK Browser,转到Samples标签,然后单击Copy as Project在此演示下。如果该选项不可用,则应安装C# Third Person Platformer演示
  4. Then go to the My Projects tab and click Open Editor under the created project to open it in UnigineEditor.
    然后去My Projects标签并点击Open Editor在创建的项目下将其打开UnigineEditor.
  5. In UnigineEditor run the project via the Play button.
    UnigineEditor通过运行项目Play按钮。
Features特征#
最新更新: 2021-04-29
