Настройка параметров узла
Creating Your First Editor Plugin
This article describes how to create an Editor plugin and get the first impression of what a plugin consists of and what its general structure is.
This feature is an experimental one and is not recommended for production use.
UnigineEditor is an application written entirely in C++ relying a lot on the Qt5 framework infrastructure. So, in order to extend its functionality not only C++ programming skills are required, but you should also be familiar with the Qt5 framework, CMake build system.
Qt Framework version 5.12+ is required to develop plugins for UnigineEditor.
As an example we shall create a simple plugin implementing the basic functionality of the Editor's Materials Hierarchy window (see the picture below).
Materials Plugin
Materials Plugin
Basically the plugin's architecture looks as follows: Materials Plugin Architecture
Materials Plugin
The MaterialsPlugin class is an initialization point and complete representation of the plugin. It creates necessary data model and via the base interface associates it with the widget, which displays the hierarchy. The model directly interacts with the Materials Manager and transforms information on materials to the required structure.
The plugin interacts will all Editor's external subsystems:
  • Adds a widget to the WindowManager;
  • Adds a new item to the main menu bar;
  • Updates the state of materials widget when the global selection is changed;
  • Updates the global selection when the local selection is changed by sending a SelectionAction to the Undo stack.
File Structure#
The typical structure of a plugin project should look as follows:
  • project
    • bin - Engine and Editor binaries
      • Unigine_x64.dll/so - Engine library (release).
      • Unigine_x64d.dll/so - Engine library (debug).
      • EditorCore_x64.dll/so - Editor library (release).
      • EditorCore_x64d.dll/so - Editor library (debug).
    • lib - import libraries (Windows only)
      • Unigine_x64.lib - Engine (release).
      • Unigine_x64d.lib - Engine (debug).
      • EditorCore_x64.lib - Editor (release).
      • EditorCore_x64d.lib - Editor (debug).
    • include - public API
      • unigine - Engine's public API.
      • editor - Editor's public API.
    • cmake
    • src - plugin source files
      • Plugin.h
      • Plugin.cpp
      • Plugin.json.in
      • CMakeList.txt
    • CMakeList.txt
The basic components are:
  • Engine and Editor binary files;
  • Engine and Editor public API header files;
  • Plugin source files;
  • Meta-json file;
  • Template CMake-scripts;
Using Plugin Template#
UNIGINE offers you a template to simplify creation of Editor plugins. The template can be found in the following folder: <UNIGINE_SDK>/utils/project/template/editor-plugin
First, we should create a folder for our new Editor plugin project. Then, simply copy all necessary files from the SDK installation directory to this new created folder as shown in the figure below:
If you're creating a project with double precision, the corresponding files to be copied to bin and lib folders must be with the _double suffix.
Copying Files and Folders
Implementing Plugin's Logic#
Now we can implement our plugin's logic (you can simply copy source code listed below to the corresponding header and implementation files).
Put all header and implementation files of your plugin to the src folder. In our example we can delete template Plugin.h and Plugin.cpp files, as we're going to use other sources.
Plugin Class#
The files MaterialsPlugin.h and MaterialsPlugin.cpp define the implementation of our plugin. Let's highlight some important points here.
Header File#
The header file MaterialsPlugin.h defines the interface of the plugin class.
namespace Materials {
The plugin is defined in a Materials namespace, which conforms to the coding rules for namespacing in sources.
class MaterialsPlugin : public QObject, public ::Editor::Plugin
	Q_OBJECT
	Q_PLUGIN_METADATA(IID "com.unigine.EditorPlugin" FILE "Materials.json")
	Q_INTERFACES(Editor::Plugin)
All Editor plugins must be derived from Editor::Plugin class and are QObjects. The Q_PLUGIN_METADATA macro is necessary to create a valid Editor plugin. The IID given in the macro must be com.unigine.EditorPlugin, to identify it as an Editor plugin, and FILE must point to the plugin's meta data file as described in Plugin Meta Data.
bool init() override;
void shutdown() override;
The base class defines basic functions that are called during the life cycle of a plugin (on initialization and shutdown), which are here implemented for your new plugin.
Our plugin has three additional custom slots, that are used show the view, set global selection and update the local one when the global is changed.
public slots:
	void showView();
	void setGlobalSelection(const QModelIndexList &indexes);
	void globalSelectionChanged();
MaterialsPlugin.h
#pragma once
#include <editor/Plugin.h>
#include <QObject>
#include <QModelIndex>
class MaterialsModel;
class MaterialsView;
	Q_OBJECT
	MaterialsPlugin();
	~MaterialsPlugin() override;
public slots:
	void showView();
	MaterialsModel *model_;
	MaterialsView *view_;
} // namespace Materials
Implementation File#
This file contains the actual implementation of our plugin and its logic. For more information about implementing the plugin interface, see the Editor::Plugin API documentation and Plugin Life Cycle.
MaterialsPlugin.cpp
#include "MaterialsPlugin.h"
#include "MaterialsView.h"
#include "MaterialsModel.h"
#include "QtMetaTypes.h"
#include <Actions.h>
#include <Undo.h>
#include <Constants.h>
#include <WindowManager.h>
#include <Selection.h>
#include <Selector.h>
#include <QObject>
#include <QMenu>
#include <algorithm>
#include <iterator>
using Editor::Selection;
using Editor::SelectionAction;
using Editor::WindowManager;
using Editor::SelectorGUIDs;
namespace Materials
MaterialsPlugin::MaterialsPlugin()
	: model_ (nullptr)
	, view_ (nullptr)
MaterialsPlugin::~MaterialsPlugin() = default;
bool MaterialsPlugin::init()
	model_ = new MaterialsModel(this);
	view_ = new MaterialsView(model_);
	view_->setWindowTitle("Plugin - Material List");
	view_->setObjectName("PluginMaterialsView");
	WindowManager::add(view_, WindowManager::ROOT_AREA_LEFT);
	connect(view_, &MaterialsView::selected, this, &MaterialsPlugin::setGlobalSelection);
	QMenu *menu = WindowManager::findMenu(Constants::MM_WINDOWS);
	menu->addAction("Plugin - Material List", this, &MaterialsPlugin::showView);
	connect(Selection::instance(), &Selection::changed,
			this, &MaterialsPlugin::globalSelectionChanged);
	return true;
void MaterialsPlugin::shutdown()
void MaterialsPlugin::showView()
	WindowManager::show(view_);
void MaterialsPlugin::setGlobalSelection(const QModelIndexList &indexes)
	disconnect(Selection::instance(), &Selection::changed,
	QVector<Unigine::UGUID> guids;
	guids.reserve(indexes.size());
	std::transform(std::begin(indexes), std::end(indexes), std::back_inserter(guids),
			[](const QModelIndex &idx)
			{ return idx.data(MaterialsModel::GUID_ROLE).value<Unigine::UGUID>(); });
	SelectionAction::applySelection(SelectorGUIDs::createMaterialsSelector(guids));
void MaterialsPlugin::globalSelectionChanged()
	using namespace std;
	if (auto selector = Selection::getSelectorMaterials())
		const QVector<Unigine::UGUID> guids = selector->guids();
		QModelIndexList indexes;
		indexes.reserve(guids.size());
		transform(begin(guids), end(guids), back_inserter(indexes),
				[this](const Unigine::UGUID &guid) { return model_->index(guid); });
		auto it = remove(begin(indexes), end(indexes), QModelIndex());
		indexes.erase(it, end(indexes));
		QSignalBlocker blocker(view_);
		view_->globalSelectionChanged(indexes);
	else if(auto selector = Selection::getSelectorRuntimes())
	else
		view_->clearSelection();
Model Class#
Header File#
MaterialsModel.h
#pragma once
#include <QAbstractItemModel>
namespace Unigine { class UGUID; };
namespace Materials
class MaterialsModel : public QAbstractItemModel
	class Item;
	enum Role
		GUID_ROLE = Qt::UserRole + 1
	MaterialsModel(QObject *parent = nullptr);
	~MaterialsModel() override;
	QModelIndex index(int row, int column, const QModelIndex &parent = QModelIndex()) const override;
	QModelIndex index(const Unigine::UGUID &guid) const;
	QModelIndex parent(const QModelIndex &child) const override;
	int rowCount(const QModelIndex &parent = QModelIndex()) const override;
	int columnCount(const QModelIndex &parent = QModelIndex()) const override;
	QVariant data(const QModelIndex &index, int role = Qt::DisplayRole) const override;
protected:
	void fetchMore(const QModelIndex &parent) override;
	bool canFetchMore(const QModelIndex &parent) const override;
	Item *root_;
MaterialsModel.cpp
#include <UnigineGUID.h>
#include <UnigineMaterials.h>
#include <QDebug>
using Unigine::UGUID;
namespace Materials
// MaterialsModel::Item.
class MaterialsModel::Item
	static Item *createRootItem(MaterialsModel *model);
	Item(Item *parent, MaterialsModel *model, const UGUID &guid);
	~Item();
	QModelIndex index() const;
	void append(Item *item);
	Item *child(int idx);
	Item *find(const UGUID &guid) const;
	int childCount() const;
	Item *parent();
	int row() const;
	QVariant data(int role) const;
	void fetchMore();
	bool canFetchMore() const;
	Item *parent_ = nullptr; // Not owned.
	MaterialsModel *model_ = nullptr; // Not owned.
	QVector<Item *> children_; // Owned.
	UGUID guid_;
MaterialsModel::Item *MaterialsModel::Item::createRootItem(MaterialsModel *model)
	Item *root = new Item(nullptr, model, UGUID());
	const int size = Unigine::Materials::getNumMaterials();
	for (int i = 0; i < size; ++i)
		const Unigine::MaterialPtr mat = Unigine::Materials::getMaterial(i);
		if (mat->isHidden())
			continue;
		if (const Unigine::MaterialPtr &parent_mat = mat->getParent())
			if (!parent_mat->isHidden())
				continue;
		root->children_.push_back(new Item(root, model, mat->getGUID()));
	return root;
MaterialsModel::Item::Item(Item *parent, MaterialsModel *model, const UGUID &guid)
	: parent_(parent), model_(model), guid_(guid)
MaterialsModel::Item::~Item()
	qDeleteAll(children_);
QModelIndex MaterialsModel::Item::index() const
	if (!parent_ || guid_.isEmpty())
		return QModelIndex();
	return model_->createIndex(row(), 0, const_cast<Item *>(this));
void MaterialsModel::Item::append(Item *item)
	const int size = children_.size();
	model_->beginInsertRows(index(), size, size);
	item->parent_ = this;
	children_.push_back(item);
	model_->endInsertRows();
auto MaterialsModel::Item::child(int idx) -> Item *
	return ((idx >= 0) && (idx < children_.size()))
		? children_[idx]
		: nullptr;
auto MaterialsModel::Item::find(const UGUID &guid) const -> Item *
	for (Item *child: children_)
		if (child->guid_ == guid)
			return child;
		if (child->canFetchMore())
			child->fetchMore();
		if (Item *grandchild = child->find(guid))
			return grandchild;
	return nullptr;
int MaterialsModel::Item::childCount() const
	if (!guid_.isValid())
		return children_.size();
	const Unigine::MaterialPtr mat = Unigine::Materials::findMaterialByGUID(guid_);
	int count = mat->getNumChildren();
	for (int i = count - 1; i >= 0; --i)
		if (mat->getChild(i)->isHidden())
			--count;
	return count;
MaterialsModel::Item *MaterialsModel::Item::parent()
	return parent_;
int MaterialsModel::Item::row() const
	if (parent_)
		return parent_->children_.indexOf(const_cast<Item *>(this));
	return 0;
QVariant MaterialsModel::Item::data(int role) const
	if (Qt::DisplayRole == role)
		const Unigine::MaterialPtr &mat = Unigine::Materials::findMaterialByGUID(guid_);
		return QVariant::fromValue(QString(mat->getName()));
	if (MaterialsModel::GUID_ROLE == role)
		return QVariant::fromValue(guid_);
	return QVariant();
void MaterialsModel::Item::fetchMore()
	const int size = mat->getNumChildren();
	QVector<Item *> items;
	items.reserve(size);
		const Unigine::MaterialPtr child_mat = mat->getChild(i);
		if (child_mat->isHidden())
			continue;
		items.push_back(new Item(this, model_, child_mat->getGUID()));
	if (items.empty())
		return;
	const int cur_size = children_.size();
	model_->beginInsertRows(index(), cur_size, cur_size + items.size() - 1);
	std::copy(std::begin(items), std::end(items), std::back_inserter(children_));
bool MaterialsModel::Item::canFetchMore() const
	return children_.empty() && childCount();
// MaterialsModel.
MaterialsModel::MaterialsModel(QObject *parent)
	: QAbstractItemModel(parent)
	, root_(Item::createRootItem(this))
MaterialsModel::~MaterialsModel()
	delete root_;
QModelIndex MaterialsModel::index(int row, int column, const QModelIndex &parent) const
	if (column > 0)
		return {};
	Item *parent_item = nullptr;
	if (!parent.isValid())
		parent_item = root_;
	else
		parent_item = static_cast<Item *>(parent.internalPointer());
	Item *child_item = parent_item->child(row);
	return child_item
		? createIndex(row, column, child_item)
		: QModelIndex();
QModelIndex MaterialsModel::index(const UGUID &guid) const
	if (guid.isEmpty())
	Item *item = root_->find(guid);
	return item ? item->index() : QModelIndex();
QModelIndex MaterialsModel::parent(const QModelIndex &child) const
	if (!child.isValid())
	Item *child_item = static_cast<Item *>(child.internalPointer());
	Item *parent_item = child_item->parent();
	return (parent_item != root_)
		? createIndex(parent_item->row(), 0, parent_item)
		: QModelIndex();
int MaterialsModel::rowCount(const QModelIndex &parent) const
	if (parent.column() > 0)
		return 0;
	else
	return parent_item->childCount();
int MaterialsModel::columnCount(const QModelIndex &parent) const
QVariant MaterialsModel::data(const QModelIndex &index, int role) const
	if (!index.isValid())
		return QVariant();
	Item *item = static_cast<Item *>(index.internalPointer());
	return item->data(role);
void MaterialsModel::fetchMore(const QModelIndex &parent)
		return;
	Item *item = static_cast<Item *>(parent.internalPointer());
	item->fetchMore();
bool MaterialsModel::canFetchMore(const QModelIndex &parent) const
		return false;
	return item->canFetchMore();
View Class#
Header File#
MaterialsView.h
#pragma once
#include <QWidget>
class QAbstractItemModel;
class QItemSelection;
class QTreeView;
namespace Materials
class MaterialsView : public QWidget
	Q_OBJECT
	MaterialsView(QAbstractItemModel *model, QWidget *parent = nullptr);
	~MaterialsView();
signals:
	void selected(const QModelIndexList &indexes);
	void menuRequested(const QModelIndexList &indexes);
public slots:
	void clearSelection();
	void globalSelectionChanged(const QModelIndexList &indexes);
private slots:
	void selectionChanged(const QItemSelection &selection);
	QTreeView *view_ = nullptr;
MaterialsView.cpp
#include <QVBoxLayout>
#include <QTreeView>
namespace Materials
MaterialsView::MaterialsView(QAbstractItemModel *model, QWidget *parent)
	: QWidget{parent}
	view_ = new QTreeView();
	view_->setAlternatingRowColors(true);
	view_->setSelectionMode(QAbstractItemView::ExtendedSelection);
	view_->setSelectionBehavior(QAbstractItemView::SelectRows);
	view_->setHeaderHidden(true);
	auto vl = new QVBoxLayout(this);
	vl->setContentsMargins(2, 2, 2, 2);
	vl->addWidget(view_);
	view_->setModel(model);
	connect(view_->selectionModel(), &QItemSelectionModel::selectionChanged
			, this, &MaterialsView::selectionChanged);
MaterialsView::~MaterialsView() = default;
void MaterialsView::clearSelection()
	view_->selectionModel()->clearSelection();
void MaterialsView::globalSelectionChanged(const QModelIndexList &indexes)
	if (indexes.empty())
		clearSelection();
		return;
	view_->setCurrentIndex(indexes.back());
	QItemSelection item_selection;
	for (const QModelIndex &index: indexes)
		item_selection.append(QItemSelectionRange(index));
	view_->selectionModel()->select(item_selection, QItemSelectionModel::ClearAndSelect);
	view_->scrollTo(indexes.back());
void MaterialsView::selectionChanged(const QItemSelection &selection)
	emit selected(view_->selectionModel()->selectedIndexes());
Auxiliary File#
This file contains registration of additional metatypes to be used in our plugin to make them known to Qt's meta-object system, we need Unigine::UGUID.
This file should be saved to the src folder with all other source files.
QtMetaTypes.h
#pragma once
// including UnigineGUID.h containing definition of the metatype we're going to declare
// including QMetaType to be able to declare metatypes
#include <QMetaType>
// registering the Unigine::UGUID type to make it known to Qt's meta-object system
Q_DECLARE_METATYPE(Unigine::UGUID)
Building the Plugin#
In order to build our plugin we also need a couple of files.
We need to create an initial meta data description file (Materials.json.in) to describe our Materials plugin and its dependencies. This file shall be used by CMake to generate the actual plugin .json meta data file.
Materials.json.in
Source code
    "Name" : "Materials",
    "Vendor" : "Unigine",
    "Description" : "<p>Provides functionality to overview and manipulate the Engine's materials</p><p>The plugin is used to demonstrate the basic usage of the new `Editor Plugin System` implementation. It contains the main plugin, tree model and tree view instances</p>",
    "Version" : "@PLUGIN_VERSION@",
    "CompatVersion" : "@PLUGIN_COMPAT_VERSION@",
    "Dependencies" : []
And we also need to modify the CMake build script src/CMakeList.txt. Regarding the described above file structure it should look like this:
src/CMakeList.txt
Source code
# Substitute placeholders in the plugin's meta file source with actual version data
# and create the final meta file.
if (EXISTS ${CMAKE_CURRENT_SOURCE_DIR}/Materials.json.in)
	set(PLUGIN_VERSION ${UNIGINE_VERSION})
	set(PLUGIN_COMPAT_VERSION ${UNIGINE_VERSION})
	configure_file(
		${CMAKE_CURRENT_BINARY_DIR}/Materials.json
endif()
# Enable automatic handling for moc, uic, and rcc
set(CMAKE_AUTOMOC TRUE)
set(CMAKE_AUTOUIC TRUE)
set(CMAKE_AUTORCC TRUE)
# Find additional required packages
find_package(Qt5 5.12 CONFIG REQUIRED COMPONENTS Gui)
find_package(Qt5 5.12 CONFIG REQUIRED COMPONENTS Widgets)
add_library(Materials SHARED
	# List of sources
	${CMAKE_CURRENT_SOURCE_DIR}/MaterialsPlugin.cpp
	${CMAKE_CURRENT_SOURCE_DIR}/MaterialsPlugin.h
	${CMAKE_CURRENT_SOURCE_DIR}/MaterialsView.cpp
	${CMAKE_CURRENT_SOURCE_DIR}/MaterialsView.h
	${CMAKE_CURRENT_SOURCE_DIR}/MaterialsModel.cpp
	${CMAKE_CURRENT_SOURCE_DIR}/MaterialsModel.h
target_include_directories(Materials SYSTEM
	PRIVATE
	${PROJECT_SOURCE_DIR}/include # <- - - - Path to Editor and Engine libraries
target_link_libraries(Materials
	PRIVATE
	Unigine::CompilerFlags # <- - - - Interface library with predefined compilation flags
	Unigine::Engine   # <- - - - - Engine
	Unigine::Editor   # <- - - - - Public Editor library
	Qt5::Core         #
	Qt5::Gui          # <- - - - - Required Qt components for the plugin
	Qt5::Widgets      #
# Set output directories for the Materials plugin target
set_target_properties(Materials
	PROPERTIES
	RUNTIME_OUTPUT_DIRECTORY ${PROJECT_SOURCE_DIR}/bin
	LIBRARY_OUTPUT_DIRECTORY ${PROJECT_SOURCE_DIR}/bin
	ARCHIVE_OUTPUT_DIRECTORY ${PROJECT_SOURCE_DIR}/lib
	CXX_VISIBILITY_PRESET hidden
target_compile_definitions(Materials
	PRIVATE
	QT_NO_DEBUG
Then we should change the default plugin project name to "Materials" in the CMakeList.txt in the plugin project's root folder:
CMakeList.txt
Source code
# Copyright (C), UNIGINE. All rights reserved.
cmake_minimum_required(VERSION 3.14)
project(Materials CXX) # < - - - Change project name here
include(${PROJECT_SOURCE_DIR}/cmake/Unigine.cmake)
add_subdirectory(${PROJECT_SOURCE_DIR}/src)
You should also set build type to Release for your generator, either by selecting manually from the IDE, or using --config CONFIG (with cmake --build). In case of a single-config generator (like Unix Makefiles) the currently active configuration is determined by the value of the CMake variable CMAKE_BUILD_TYPE.
Now we can use CMake to build our plugin.
Running the Plugin#
Now as the plugin is built we should copy resulting files to the following folder, so that UnigineEditor's Plugin System could load it automatically:
  • %project%/bin/editor — for Release build;
And finally we launch the UnigineEditor to check our plugin. If everything was done properly, you should see the Materials plugin in the list of loaded plugins (Help -> Plugins).
Plugins List
Last update: 09.04.2021
