This example shows how to create a cloth pinned to 2 dummy bodies resting on a sphere using a particles joint.
// AppWorldLogic.h
#include <UnigineObjects.h>
// AppWorldLogic.cpp
#include "UnigineGame.h"
#include "UnigineObjects.h"
ObjectMeshDynamicPtr createSphere(char *name, float radius, const vec4& color, const vec3& pos)
// setting parameters
OMD->setMaterialParameter("albedo_color", color, 0);
OMD->setName(name);
return OMD;
// creating a dummy object
dummy->setName(name);
BodyDummy::create(dummy->getObject());
dummy->getBody()->addShape(ShapeBox::create(size)->getShape(), translate(0.0f, 0.0f, 0.0f));
return dummy;
ObjectMeshDynamicPtr createBodyCloth(char *name, float width, float height, float step, float mass, float friction, float restitution, float rigidity, float lrestitution, float arestitution, int num_iterations, const vec4& color, const Mat4& tm)
//assigning a cloth body to the dynamic mesh object and setting rope parameters
BodyClothPtr body = BodyCloth::create(OMD->getObject());
body->setMass(mass);
body->setFriction(friction);
body->setRigidity(rigidity);
OMD->setWorldTransform(tm);
OMD->setName(name);
return OMD;
int AppWorldLogic::init() {
// creating 2 dummy bodies to attach the cloth to
