Switcher
A switcher is an object that disables or enables its child nodes at the specified distance to the camera. Possible use cases are:
  • Enabling one object and disabling another at a specified distance
  • Disabling an object while moving away
  • Enabling an object while approaching
To be operated, the child nodes of the switcher should be placed inside the switcher object fully or partially.
Each object is composed of a switcher and two spheres of different colors
Adding a Switcher#
To add a switcher to the scene via UnigineEditor, do the following:
  2. On the Menu bar, click Create -> Optimization -> Switcher.
  3. Place the object somewhere in the world.
  4. Make the object that will be operated the child of the switcher.
  5. Specify the switcher parameters and the distance of enabling / disabling.
Switching between Two Objects#
To switch between two object at the specified distance (like shown at the picture above), do the following:
  1. Create a node dummy for convenient grouping.
  2. Make the first switcher the child of the node dummy.
  3. Make the first object the child of the first switcher and specify its maximum visibility distance.
  4. Make the second switcher the child of the node dummy.
  5. Make the second object the child of the second switcher and specify its minimum visibility distance.
    For objects to be switched at the same point, the maximum visibility distance of the first and minimum visibility distance of the second should match.
Switcher Parameters#
In the Node tab of the Parameters window, you can adjust the following parameters of the switcher:
Node tab of the World Switcher node
Bounding Box Parameters
Edit Size Toggles the editing mode for the world trigger node on and off. When enabled, the bounding box sides that can be resized are highlighted with the colored rectangles. To change the size of a side, drag the corresponding rectangle.
Point A flag indicating if the distance to the object is counted from the center of the bounding box (if disabled, the distance will be counted from its nearest edge).
Size The size of the switcher's bounding box along the X, Y, and Z axes, in units.
Offset The offset of the switcher's bounding box along the X, Y, and Z axes, in units.
Switching Parameters#
Switching of distances:
Min distance The minimum distance of visibility, in units. If a camera is closer to a node than this minimum distance, a node is not visible.
Max distance The maximum distance of visibility, in units. If a camera is further from a node than this maximum distance, a node is not visible.
Last update: 2019-08-16
