The Language
Core Library
Engine Library
Plugins Library
C++ API
Integration Samples
C++ Plugins
Migration
Migrating to UNIGINE 2.0
C++ API Migration
Dynamic Meshes
This article describes usage examples of dynamic meshes by using the ObjectMeshDynamic class. This class is used to procedurally create dynamic meshes and modify them in run-time. You can also load an existing mesh as a dynamic one in order to modify it.
Creating a Dynamic Mesh
Creating a New Dynamic Mesh
Adding trianlges
You can create a dynamic mesh from scratch, by adding one triangle after another. This variant is suitable to create meshes with a moderate number of triangles. To create a new dynamic mesh you should do the following:
  1. First of all, reserve a necessary space in a vertex buffer for triangle vertices and add indices for them to the index buffer. This is done by calling one of the following methods: All of these functions allocate memory for polygons of the corresponding form.
  2. Add the corresponding number of vertices via addVertex() method.
  3. After each call of the addVertex() function, you can set up properties of the last added vertex manually via calling: All these functions a optional, you can call them as needed.
  4. Calculate tangent vectors for all vertices via updateTangents().
  5. Calculate a bounding box and a bounding sphere for the created mesh by calling updateBounds().
  6. If necessary, you can remove duplicated vertices of the created mesh and optimize it for faster rendering. Use updateIndices() function, for example, if a quad polygon is created via addTriangles(2) (6 vertices are created) instead of an optimized addQuads(1) (4 vertices are created).
Usage Example
The following example shows how to create of a quad polygon by using the addTriangleQuads() function.
Source code (UnigineScript)
int init() {
	ObjectMeshDynamic mesh = new ObjectMeshDynamic(); // Create a dynamic mesh and add it into the editor.
	engine.editor.addNode(node_remove(mesh));
	mesh.setWorldTransform(translate(Vec3(0.0f,0.0f,2.0f)));
	mesh.setMaterial("mesh_base","*");
	mesh.setProperty("surface_base","*");
	mesh.addTriangleQuads(1); // Allocate space in a vertex buffer and create vertex indices.
	mesh.addVertex(vec3(-1.0f,-1.0f,0.0f)); // Add vertices and assign texture coordinates, if necessary.
	mesh.addTexCoord(vec4(0,0,0,0));
	mesh.addVertex(vec3(1.0f,-1.0f,0.0f));
	mesh.addTexCoord(vec4(1,0,0,0));
	mesh.addVertex(vec3(1.0f,1.0f,0.0f));
	mesh.addTexCoord(vec4(1,1,0,0));
	mesh.addVertex(vec3(-1.0f,1.0f,0.0f));
	mesh.addTexCoord(vec4(0,1,0,0));
	mesh.updateTangents(); // Calculate tangent vectors.
	//mesh.updateIndices(); // Optimize vertex and index buffers, if necessary.
	mesh.updateBounds(); // Calculate a mesh bounding box.
Adding a Big Number of Vertices
To create dynamic meshes with a huge number of vertices, it is better to use a more optimized approach: instead of allocating memory in small chunks (which can be costly), all necessary memory is preallocated first and filled with data after that.
  1. Allocate space for triangle vertices in an index buffer using allocateIndices().
  2. Allocate space for vertices in a vertex buffer using allocateVertex().
  3. Add the corresponding number of vertices via addVertex() method.
  4. Add the corresponding number of indices via addIndex() method.
  5. Follow steps 3-6 described above.
Usage Example
int init() {
	mesh.allocateIndices(6); // Allocate space in index and vertex buffers.
    mesh.allocateVertex(4);
	mesh.addVertex(vec3(-1.0f,-1.0f,0.0f)); // Add vertices.
	mesh.addIndex(0); // Add indices for created vertices.
    mesh.addIndex(1);
    mesh.addIndex(2);
    mesh.addIndex(0);
    mesh.addIndex(2);
    mesh.addIndex(3);
Creating a Dynamic Mesh Based on the Existing Mesh
Passing a Mesh to a New Dynamic Mesh
Usage Example
int init() {
	Mesh mesh = new Mesh();
	mesh.addBoxSurface("box", vec3(0.2));
	ObjectMeshDynamic dynamic_mesh = new ObjectMeshDynamic(mesh);
	// Assign a material and a property.
	dynamic_mesh.setMaterial("mesh_base","*");
	dynamic_mesh.setProperty("surface_base","*");
Passing a Mesh Name to a New Dynamic Mesh
To create a new dynamic mesh from the existing .mesh file, you should pass to the constructor of the ObjectMeshDynamic class the path to the file. The path is relative to the data/ folder of your project.
Usage Example
The following example shows how to create a new dynamic mesh from existing .mesh file. It is supposed that you have a file with a mesh and you pass the path to the file as an argument to the ObjectMeshDynamic constructor. In this example a statue mesh from the Unigine samples is used.
int init() {
	// by passing the path of the existing mesh as an argument
	ObjectMeshDynamic dynamic_mesh = new ObjectMeshDynamic("/samples/common/meshes/statue.mesh");
	engine.editor.addNode(node_remove(dynamic_mesh));
Copy a Mesh to the Existing Dynamic Mesh
Usage Example
In the following example described how to copy the mesh from the Mesh instance to the ObjectMeshDynamic instance. It is supposed that you already have the Mesh instance, but in this example we create a new instance of the Mesh class with the box surface.
int init() {
	ObjectMeshDynamic dynamic_mesh = new ObjectMeshDynamic();
	dynamic_mesh.setMesh(mesh);
Adding Physics to Dynamic Meshes
To add some physical properties to the dynamic mesh so that it could participate in interactions between objects or external physical forces, it should have a body. You can easily assign it from UnigineScript or in the UnigineEditor.
Usage Example
The following example shows how to add the rigid body with a shape to the dynamic mesh. In the example the dynamic mesh is created from the existing mesh with the box surface.
// create a new dynamic mesh from the Mesh instance and add it to editor
// Assign a material and a property to the dynamic mesh
// Assign a body and a shape to the dynamic mesh
BodyRigid body = class_remove(new BodyRigid(dynamic_mesh));
ShapeBox shape = class_remove(new ShapeBox(body, vec3(0.2f)));
Intersections with Dynamic Meshes
To detect if the dynamic mesh intersects a line or bounds of the specified volume, you should use one of these functions;
Saving a Dynamic Mesh to a File
Usage Example
	dynamic_mesh.getMesh(mesh);
	// save the mesh to the data/samples/dynamic_mesh.mesh file
	mesh.save("samples/dynamic_mesh.mesh");
