Text Object
A text object is an object representing a plain text in a 3D space. The text is rendered into a texture that is applied to a flat polygon. It uses trilinear filtering and mipmaps to correctly display the text at any distance. There is no noise influence to the object and it is not distorted by TAA.
The font can be represented as a TrueType font (TTF) or as a texture atlas with letters.
- An ObjectText class to edit text objects via UnigineScript
Adding a Text Object
To add a text object to the scene via UnigineEditor, do the following:
- Run the project with UnigineEditor.
- On the Menu bar, click Create -> Object -> Text.
- Place the text object somewhere in the world.
Editing a Text Object
Text | Text input field. If the Rich text option is enabled, you can use tags for text formatting. | ||||
Name | Path to a *.ttf file or to a texture atlas with letters. | ||||
Color | Font color in the RGBA range. | ||||
Size | Font size, in dots. The more dots, the higher the size of the font. To match dots with a 3D space, there is a set value: 288 dots per unit. For example, if you have the Arial font with the size of 20, the physical height of the letter can be calculated as 20/288=0.0694 units. | ||||
Resolution | Resolution of the texture into which the text will be rendered. The lower the value, the less detailed will be the text and the less video memory will be required for the texture.
The resolution doesn't influence the text's physical size.
HSpacing | Horizontal spacing between letters (a kerning value). This parameter affects the text's physical size. | ||||
VSpasing | Vertical spacing between letters (a kerning value). This parameter affects the text's physical size. | ||||
Rich text | Flag indicating if the rich text formatting is enabled. | ||||
Outline | Flag indicating in the text outline is enabled. The outline looks like the dark shadow in the right lower corner of the text and is displaced by one dot. |
