The Language
Core Library
Engine Library
Plugins Library
C++ API
Integration Samples
C++ Plugins
Migration
Migrating to UNIGINE 2.0
C++ API Migration
This article explains how you can rebuild the Unigine Engine and its components (samples, plugins, etc.) by using Visual Studio on the Windows platform.
Rebuilding Unigine Engine or Its Components
Customization Options
Apart from developing your project with UnigineScript, you can also customize the Unigine application C++ code. What exactly is available for customization depends on the version of Unigine SDK:
  • With the limited binary/evaluation version you can only modify the following components:
    1. C++ plugins for the engine.
    2. The source code of Unigine-based sample applications.
    You can also modify the source code of Unigine Editor and high-level scripts (just like all other scripts, they do not require recompilation).
  • If you have the full source version, you can modify the entire Unigine codebase:
    1. The C++ source code of the engine itself.
    2. All Unigine standalone tools.
    3. C++ plugins for the engine.
    4. Plugins for 3D editors.
    5. The source code of Unigine-based sample applications.
After customizing the code, recompilation of Unigine application or its libraries is required.
It is strongly not recommended to modify the engine source code directly, because you will need to merge your modifications each SDK update. Instead, it is better to use C++ API (including C++ plugin system) designed specifically for extending basic Unigine functionality.
Rebuild the Unigine-Powered Application
For Windows, 32-bit or 64-bit, debug or release, single or double coordinates precision versions can be compiled. To recompile both the Unigine engine (i.e. the dynamic library Unigine_*.dll) and application on its base (i.e. the main application main_*.exe), do the following: For compilation via MS Visual Studio:
  • To rebuild the engine libraries:
    1. Open the solution file for Visual Studio: <UNIGINE_SDK>\source\engine\unigine_vs2010.vcxproj or <UNIGINE_SDK>\source\engine\unigine_vs2013.vcxproj. The postfix shows the version of Microsoft Visual Studio.
    2. Specify the solution configuration: Debug, Debug-Double, Release or Release-Double.
    3. Choose Build -> Build Solution in the menu or press F7.
  • To rebuild the main application:
    1. Open <UNIGINE_SDK>\source\app\main\main_vs2010.vcxproj or <UNIGINE_SDK>\source\app\main\main_vs2013.vcxproj. The postfix shows the version of Microsoft Visual Studio.
Rebuild Engine Plugins
To rebuild engine C++ plugins, perform one of the following: >To rebuild a plugin with Microsoft Visual Studio, do the following:
  • Open the solution of the necessary plugin to rebuild. All plugins are located in <UNIGINE_SDK>\source\plugins\.
  • Specify the solution configuration: Debug, Debug-Double, Release or Release-Double.
  • Choose Build -> Build Solution in the menu or press F7.
Rebuild Task-Specific Applications
Some specific functionality is not supported by the main Unigine application. For that, you need to recompile separate applications (their binary executables).
Only one plugin from <UnigineSDK>\source\plugins\app\ can be loaded at the same time. To load another plugin, you should unload the previous one.
To rebuild athe task-specific application with Microsoft Visual Studio, do the following:
  1. Open the solution of the necessary plugin to rebuild. All plugins are located in <UNIGINE_SDK>\source\plugins/.
Rebuild Sample Applications
Into Unigine SDK there are included sample applications that can be modified and used as templates to create your own applications.
To rebuild Unigine samples, you should do the following:
  1. Open the Visual Studio project file of the sample. Samples are located in the<UnigineSDK>\source\samples\ directory.
Rebuild 3D Graphics Plugins and Tools
To rebuild plugins for 3D graphics packages (3ds Max, Maya), and Unigine tools use semi-automatic compilation with build script or maunal compilation with SCons.
