The Language
Core Library
Engine Library
Plugins Library
C++ API
Integration Samples
C++ Plugins
Migration
Migrating to UNIGINE 2.0
C++ API Migration
Basic Object Movements
After adding an object to Unigine, you can control its transformations with your control devices. This article shows how to control basic object movements and combine different transformations.
In examples below, we use the statue.mesh mesh from the <UNIGINE SDK>/data/samples/common/meshes/ folder.
Direction Vector
A direction vector is the important concept of mesh transformation. To move the node forward, you should know where is the forward direction of the mesh. When the mesh is exported from a 3D editor, it saves the information about the forward direction. And when you add the mesh to the Unigine, it will have the same orientation as it had in a 3D editor.
A mesh in Maya
The same mesh in Unigine
On pictures given above, the direction vector has positive Y-direction. To move this mesh forward, you should get the direction of the mesh by using the Y component (the second column) of the world transformation matrix of the mesh.
For example, in the City Traffic project the direction vector has positive Y-direction. To add a new car to City Traffic (to apply all the logic to the added car), it should be exported from a 3D editor with the specific direction vector.
The point is that content creators and programmers should make an arrangement about the direction vector.
Basic Movements
Moving Forward
This section contains different ways of setting the forward movement of the mesh.
In this example, we used the "p" key pressing to move the mesh forward.
Source code (UnigineScript)
// define the ObjectMeshStatic mesh and movement speed
ObjectMeshStatic mesh;
float movement_speed = 5.0f;
// initialize custom controls
void init_controls() {
	// check if the key is pressed and update the state of the specified control
	// you can use both 'p' or ASCII code (112)
	engine.controls.setStateKey(CONTROLS_STATE_AUX_0,'p');
// add a mesh as a node to the editor
Node add_editor(Node node) {
	engine.editor.addNode(node);
	return node_remove(node);
/* the world script init() function
int init() {
	/* create a camera and add it to the world
	Player player = new PlayerSpectator();
	player.setDirection(Vec3(0.755f,-1.0f,0.25f));
	// add the mesh to the world and set the material
	mesh = add_editor(new ObjectMeshStatic("unigine_project/meshes/statue.mesh"));
	mesh.setMaterial("mesh_base", "*");
	// call the init_controls() function
	init_controls();
/* the world script update() function
int update() {
	// get the frame duration
	float ifps = engine.game.getIFps();
	// check if the control key is pressed
	if(engine.controls.getState(CONTROLS_STATE_AUX_0)) {
		// get the current world transform matrix of the mesh
		Mat4 transform = mesh.getWorldTransform();
		// get the direction vector of the mesh
		Vec3 direction = transform.m00m10m20;
		// calculate the delta of movement
		Vec3 delta_movement = direction * movement_speed * ifps;
		// set a new position to the mesh
		mesh.setWorldPosition(mesh.getWorldPosition() + delta_movement);
Another way of getting the direction vector is by using this command:
Vec3 direction = Vec3(transform.col0);
This line is more readable, but it requires an additional casting to Vec3.
Another Way of Setting Mesh Position
The new position can be also set by using the setWorldTransform() function. The following examples contain the code from the update function of the world script. The part of controls initialization is the same for this method, the difference is in the world script's update() function.
	mesh.setWorldTransform(translate(delta_movement) * transform);
Or you can change the translation column of the world transformation matrix (see the Matrix Transformations article) to move the mesh:
// check if the control key is pressed.
	// here, you can also use transform.m03m13m23 += delta_movement;
	transform.col3 += Vec4(delta_movement,1.0f);
	// set a new world transform matrix to the mesh
	mesh.setWorldTransform(transform);
Rotation
This section contains implementation of the mesh rotation.
You can rotate the mesh in two ways, by using the setWorldTransform() function or the setWorldRotation() function. The following example uses the setWorldRotation() function:
float rotation_speed = 30.0f;
	// you can use both 'o' or ASCII code (111)
	engine.controls.setStateKey(CONTROLS_STATE_AUX_1,'o');
int init() {
	init_controls();
int update() {
	/* this block rotates the mesh
	if(engine.controls.getState(CONTROLS_STATE_AUX_1)) {
		// set the node rotation along the Z axis
		mesh.setWorldRotation(mesh.getWorldRotation() * quat(rotateZ(rotation_speed * ifps)));
In the example above, the node is rotated to the left by pressing the "o" keyboard key.
To use the setWorldTransform() function, you should replace the setWorldRotation() function with the following line:
mesh.setWorldTransform(mesh.getWorldTransform() * rotateZ(rotation_speed * ifps));
Combining Movements
Combining different movement controls is not more difficult than adding only one movement control.
The following example adds a mesh to the world and allows you to control the mesh. You can rotate it by using the "o", "[" keyboard keys and move forward by using the "p" keyboard key.
float rotation_speed_left = 30.0f;
float rotation_speed_right = -30.0f;
	engine.controls.setStateKey(CONTROLS_STATE_AUX_2,'[');
int init() {
	init_controls();
int update() {
	// check if the control key for moving forward is pressed
	// check if the control key for left rotation is pressed
		// set the node left rotation
		mesh.setWorldRotation(mesh.getWorldRotation() * quat(rotateZ(rotation_speed_left * ifps)));
	// check if the control key for right rotation is pressed
	if(engine.controls.getState(CONTROLS_STATE_AUX_2)) {
		// set the node right rotation
		mesh.setWorldRotation(mesh.getWorldRotation() * quat(rotateZ(rotation_speed_right * ifps)));
