This example shows how to:
  1. Create geometry for all parts of the mechanism.
  2. Assign bodies and collision shapes to the parts.
  3. Set up masses for the parts.
    It is very important to ensure mass balance – avoid connection of too heavy bodies to light ones, otherwise the joints may become unstable!
  4. Connect all parts of the mechanism using appropriate types of joints. Set up joint parameters.
  5. Animate the mechanism using joint motors.
  • 2 blue guide bars
  • a red piston
  • a green rod
  • a black wheel
  • 2 dummy objects with dummy bodies to attach the parts of our mechanism to.
We are also going to add some physical parameters to the geometry such as mass and collision shapes. So, we need a set of basic functions:
Source code (C#)
/// method, creating a named dummy body of a specified size at pos
ObjectDummy createBodyDummy(String name, vec3 size, dmat4 transform)
    // creating a dummy object
    ObjectDummy dummy = new ObjectDummy();
    // setting parameters
    dummy.WorldTransform = transform;
    dummy.Name = name;
    new BodyDummy(dummy);
    dummy.Body.AddShape(new ShapeBox(size), MathLib.Translate(0.0f, 0.0f, 0.0f));
    return dummy;
/// method, creating a named box having a specified size, color and transformation with a body and a shape
ObjectMeshDynamic createBodyBox(String name, vec3 size, float mass, vec4 color, dmat4 transform)
    // creating geometry and setting up its parameters (name and transformation)
    ObjectMeshDynamic OMD = Primitives.CreateBox(size);
    OMD.WorldTransform = transform;
    OMD.SetMaterialParameterFloat4("albedo_color", color, 0);
	OMD.SetCollision(1, 0);
    OMD.Name = name;
    BodyRigid body = new BodyRigid(OMD);
    body.AddShape(new ShapeBox(size), MathLib.Translate(new vec3(0.0f)));
    OMD.Body.GetShape(0).Mass = mass;
    return OMD;
/// method, creating a named cylinder having a specified size, color and transformation with a body and a shape
ObjectMeshDynamic createBodyCylinder(String name, float radius, float height, float mass, vec4 color, dmat4 transform)
    ObjectMeshDynamic OMD = Primitives.CreateCylinder(radius, height, 1, 32);
    OMD.Name = name;
    body.AddShape(new ShapeCylinder(radius, height), MathLib.Translate(new vec3(0.0f)));
    return OMD;
Now using these functions we can create our mechanism. We are going to use DynamicMesh objects for the parts and Dummy objects for mounting points.
Source code (C#)
dmat4 transform = new dmat4(MathLib.Translate(0.0f, 0.0f, 10.0f) * MathLib.RotateY(90.0f));
piston = createBodyBox("piston", new vec3(1.0f, 2.0f, 0.5f), 15.0f, new vec4(1.0f, 0.1f, 0.1f, 1.0f), transform * new dmat4(MathLib.Translate(0.0f, 3.5f, 0.0f)));
guide_bar1 = createBodyBox("guide_bar1", new vec3(1.0f, 9.0f, 0.5f), 15.0f, new vec4(0.0f, 0.1f, 0.7f, 1.0f), transform * new dmat4(MathLib.Translate(1.0f, 3.0f, 0.0f)));
guide_bar2 = createBodyBox("guide_bar2", new vec3(1.0f, 9.0f, 0.5f), 15.0f, new vec4(0.0f, 0.1f, 0.7f, 1.0f), transform * new dmat4(MathLib.Translate(-1.0f, 3.0f, 0.0f)));
wheel = createBodyCylinder("wheel", 3.0f, 0.25f, 25.0f, new vec4(0.1f, 0.1f, 0.1f, 1.0f), transform * new dmat4(MathLib.Translate(0.0f, -15.0f, -0.5f)));
rod = createBodyCylinder("rod", 0.1f, 15.0f, 5.0f, new vec4(0.1f, 1.1f, 0.1f, 1.0f), transform * new dmat4(MathLib.Translate(0.0f, -5.0f, 0.0f) * MathLib.RotateX(90.0f)));
//creating mounting points
dummy1 = createBodyDummy("dummy1", new vec3(1.0f, 1.0f, 1.0f), transform * new dmat4(MathLib.Translate(0.0f, -15.0f, -1.5f)));
dummy2 = createBodyDummy("dummy2", new vec3(1.0f, 1.0f, 0.5f), transform * new dmat4(MathLib.Translate(0.0f, 7.0f, 0.0f)));
Adding and Setting Up Joints#
Source code (C#)
jc = new JointCylindrical(dummy1.Body, wheel.Body);
jc.WorldAxis = new vec3(1.0f, 0.0f, 0.0f);
jc.LinearRestitution = 0.4f;
jc.AngularRestitution = 0.4f;
jc.LinearSoftness = 0.4f;
jc.AngularSoftness = 0.4f;
jc.LinearDamping = 4.0f;
jc.AngularDamping = 2.0f;
jc.LinearLimitFrom = -0.0005f;
jc.LinearLimitTo = 0.0005f;
// setting number of iterations
jc.NumIterations = 16;
Now let us attach the rod to the wheel and to the piston. This is where we need a hinge joint. For both of these joints we have to specify anchor point and joint axis coordinates in the JointHinge() constructor
Source code (C#)
// creating hinge joints
jh = new JointHinge(wheel.Body, rod.Body, new dvec3(0.0f, -12.5f, 10.0f), new vec3(1.0f, 0.0f, 0.0f));
jh2 = new JointHinge(rod.Body, piston.Body, new dvec3(0.0f, 2.5f, 10.0f), new vec3(1.0f, 0.0f, 0.0f));
jh.NumIterations = 8;
jh2.NumIterations = 8;
The next thing we are going to do is to attach 2 guide bars to the second mounting point(dummy2) using a pair of fixed joints. For both of these joints we will specify anchor point coordinates in the JointFixed() constructor
Source code (C#)
// creating fixed joints
jf1 = new JointFixed(dummy2.Body, guide_bar1.Body, new dvec3(0.0f, 7.0f, 9.0f));
jf2 = new JointFixed(dummy2.Body, guide_bar2.Body, new dvec3(0.0f, 7.0f, 11.0f));
jf1.NumIterations = 1;
jf2.NumIterations = 1;
And the last joint we are going to use is a prismatic joint to attach the piston to the second mounting point(dummy2). Here we will specify joint axis coordinates, linear limits to determine the range of motion for the piston and linear softness
Source code (C#)
// creating a prismatic joint
jp = new JointPrismatic(piston.Body, dummy2.Body);
jp.WorldAxis = new vec3(0.0f, 1.0f, 0.0f);
jp.LinearLimitFrom = -5.0f;
jp.LinearLimitTo = 0.0f;
jp.LinearSoftness = 0.5f;
jp.NumIterations = 8;
Using Joint Motors#
Source code (C#)
jc.AngularVelocity = 1000.0f;
jc.AngularTorque = 150.0f;
Putting it All Together#
In this section let us sum up all described above. The final code for our tutorial will be as follows:
Source code (C#)
// AppWorldLogic.cs
using System;
using System.Linq;
using System.Text;
using Unigine;
namespace UnigineApp
        PlayerSpectator player;
        // parts of the mechanism
        ObjectDummy dummy1;
        ObjectDummy dummy2;
        ObjectMeshDynamic rod;
        ObjectMeshDynamic wheel;
        ObjectMeshDynamic piston;
        ObjectMeshDynamic guide_bar1;
        ObjectMeshDynamic guide_bar2;
        // joints of the mechanism
        JointCylindrical jc;
        JointHinge jh;
        JointHinge jh2;
        JointFixed jf1;
        JointFixed jf2;
        JointPrismatic jp;
            dummy.Name = name;
            return dummy;
            OMD.Name = name;
            return OMD;
			OMD.Name = name;
            return OMD;
        public override bool Init()
            Physics.Gravity = new vec3(0.0f, 0.0f, -9.8f * 2.0f);
            Physics.FrozenLinearVelocity = 0.1f;
            Physics.FrozenAngularVelocity = 0.1f;
            // setting up player
            player = new PlayerSpectator();
            player.Position = new dvec3(22.0f, -2.0f, 10.0f);
            player.SetDirection(new vec3(-10.0f, -2.0f, 0.0f), new vec3(0.0f, 0.0f, -1.0f));
            Game.Player = player;
            return true;
Last update: 14.12.2022
