Unigine.ParticleModifierScalar Class
Inherits from: | ParticleModifier |
This class is used to represent a particle system modifier, that controls a scalar parameter (radius, velocity, etc.). Modifiers are used to control how various parameters of particle systems change over the particle's life time.
Properties
float MinValue#
The minimum value for the modifier defining the lower limit for the value of the controlled parameter.
float MaxValue#
The maximum value for the modifier defining the upper limit for the value of the controlled parameter.
Curve2d CurveMax#
The current maximum curve set for the modifier. This curve defines the upper limit for the value of the controlled parameter at each point of the particle's lifetime. The actual value changes randomly over time between the lower and the upper limits.
Curve2d CurveMin#
The current minimum curve set for the modifier. This curve defines the lower limit for the value of the controlled parameter at each point of the particle's lifetime. The actual value changes randomly over time between the lower and the upper limits.
Curve2d Curve#
The current curve set for the modifier. The actual value of the controlled parameter is defined by this curve.
float ConstantMax#
The current maximum constant value set for the modifier. this constant defines the upper limit for the value of the controlled parameter. The actual value varies randomly between the lower and upper limits.
float ConstantMin#
The current minimum constant value set for the modifier. this constant defines the lower limit for the value of the controlled parameter. The actual value varies randomly between the lower and upper limits.
float Constant#
The current constant value set for the modifier. in the CONSTANT modifier mode the actual value of the controlled parameter remains equal to this constant throughout the particle's lifetime.
float CurveScale#
The Sets a new curve scale for the modifier. The scale defines the maximum possible value for the parameter controlled by the modifier.
Members
Была ли эта статья полезной?
