Unigine.ObjectMeshSplineCluster Class
Inherits from: Object
Properties
int NumMeshes#
The Number of meshes.
string MeshName#
The Mesh name.
Members
static int type ( ) #
Returns the type of the node.
Return value
Node type identifier.
mat4 GetMeshTransform ( int num ) #
Returns the transformation of the given mesh instance.
Arguments
  • int num - Mesh instance number.
Return value
Mesh transformation matrix.
bool GetClusterTransforms ( WorldBoundBox bounds, mat4[] transforms ) #
Collects transformations (local coordinates) for all spline cluster meshes within the area specified by the given bounding box and puts them to the specified buffer.
Arguments
  • WorldBoundBox bounds - Bounding box, defining the area, for which the transformations of spline cluster meshes are to be collected.
  • mat4[] transforms - Buffer to store transformations of spline cluster meshes.
Return value
true, if there are transformations of spline cluster meshes; or false, if there are no transformations of spline cluster meshes found.
bool GetClusterWorldTransforms ( WorldBoundBox bounds, mat4[] transforms ) #
Collects transformations (world coordinates) for all spline cluster meshes within the area specified by the given bounding box and puts them to the specified buffer.
Arguments
Return value
int GetNumSurfaceTargets ( int surface ) #
Returns the total number of surface targets.
Arguments
  • int surface - Surface number.
Return value
Total number of surface targets.
string GetSurfaceTargetName ( int surface, int target ) #
Returns the name of a given surface target.
Arguments
  • int target - Target number.
Return value
Target name.
int FindSurfaceTarget ( string name, int surface ) #
Searches for a surface target with a given name.
Arguments
  • string name - Target name.
Return value
Target number if it exists; otherwise, -1.
Last update: 14.12.2022
