Unigine.ParticleModifierVector Class
Inherits from: | ParticleModifier |
This class is used to represent a particle system modifier, that controls a vector parameter (position, direction, etc.). Modifiers are used to control how various parameters of particle systems change over the particle's life time.
Properties
vec3 MinValue#
The minimum value for the modifier defining the lower limit for the value of the controlled vector parameter.
vec3 MaxValue#
The maximum value for the modifier defining the upper limit for the value of the controlled vector parameter.
Curve2d CurveZMax#
The current maximum curve set for the modifier to control the Z component of the vector parameter. This curve defines the upper limit for the value of the Z component of the controlled vector parameter at each point of the particle's lifetime. The actual value changes randomly over time between the lower and the upper limits.
Curve2d CurveYMax#
The current maximum curve set for the modifier to control the Y component of the vector parameter. This curve defines the upper limit for the value of the Y component of the controlled vector parameter at each point of the particle's lifetime. The actual value changes randomly over time between the lower and the upper limits.
Curve2d CurveXMax#
The current maximum curve set for the modifier to control the X component of the vector parameter. This curve defines the upper limit for the value of the X component of the controlled vector parameter at each point of the particle's lifetime. The actual value changes randomly over time between the lower and the upper limits.
Curve2d CurveZMin#
The current minimum curve set for the modifier to control the Z component of the vector parameter. This curve defines the lower limit for the value of the Z component of the controlled vector parameter at each point of the particle's lifetime. The actual value changes randomly over time between the lower and the upper limits.
Curve2d CurveYMin#
The current minimum curve set for the modifier to control the Y component of the vector parameter. This curve defines the lower limit for the value of the Y component of the controlled vector parameter at each point of the particle's lifetime. The actual value changes randomly over time between the lower and the upper limits.
Curve2d CurveXMin#
The current minimum curve set for the modifier to control the X component of the vector parameter. This curve defines the lower limit for the value of the X component of the controlled vector parameter at each point of the particle's lifetime. The actual value changes randomly over time between the lower and the upper limits.
Curve2d CurveZ#
The current curve set for the modifier to control the Z component of the vector parameter.
Curve2d CurveY#
The current curve set for the modifier to control the Y component of the vector parameter.
Curve2d CurveX#
The current curve set for the modifier to control the X component of the vector parameter.
float CurveScale#
The Sets a new curve scale for the modifier. The scale defines the maximum possible value for the components of the vector parameter controlled by the modifier.
vec3 ConstantMax#
The current maximum constant vector value for the modifier. this vector defines the upper limit for the value of the controlled vector parameter. The actual value varies randomly between the lower and upper limits.
vec3 ConstantMin#
The current minimum constant vector value for the modifier. this vector defines the lower limit for the value of the controlled vector parameter. The actual value varies randomly between the lower and upper limits.
vec3 Constant#
The current constant vector value set for the modifier. in the CONSTANT modifier mode the actual value of the controlled parameter remains equal to this constant throughout the particle's lifetime.
Members
Была ли эта статья полезной?
