Unigine.ObjectTerrainGlobal Class
Inherits from: Object
This class is used to create a global terrain object representing a certain fragment of Earth's surface on the basis of available GIS data (elevation and imagery). The global terrain is rendered using pre-generated tilesets which represent LODs for different data layers (heights, albedo, normals, and masks). Tilesets are managed via the TileSet class. Tileset data is stored in tileset files on the disk, these files are managed via the TileSetFile class
  • A TerrainGlobalDetail class to manage global terrain via C++, C# or UnigineScript API.
  • A TerrainGlobalLod class to manage a global terrain LOD via C++, C# or UnigineScript API.
  • A TerrainGlobalLodHeight class to manage a global terrain height LOD via C++, C# or UnigineScript API.
  • A TerrainGlobalLods class to manage a group of global terrain LODs via C++, C# or UnigineScript API.
  • A Tileset class to manage tileset data of of the ObjectTerrainGlobal via C++, C# or UnigineScript API.
  • A TilesetFile class to manage tileset files of the ObjectTerrainGlobal via C++, C# or UnigineScript API.
  • A UnigineScript API sample <UnigineSDK>/data/samples/objects/terrain_global_00
Properties
bool ForceIntersection#
The A value indicating if forced loading of terrain tiles for intersection detection is enabled.
This option is used to enable force loading of terrain tiles to ensure correct intersection detection.
Texture HeightTextureArray#
The height textures array.
string HeightTextureArrayName#
The name of the height textures array.
Texture NormalTextureArray#
The normal textures array.
string NormalTextureArrayName#
The name of the normal textures array.
Texture AlbedoTextureArray#
The albedo textures array.
string AlbedoTextureArrayName#
The name of the albedo textures array.
int NumDetails#
The total number of details.
int NumMasks#
The total number of masks.
Members
ObjectTerrainGlobal ( ) #
Constructor. Creates a new empty global terrain object with default properties.
void Clear ( ) #
Clears all terrain data (lods, textures, details, masks etc.).
static int type ( ) #
Returns the type of the object.
Return value
ObjectTerrainGlobal type identifier.
TerrainGlobalLods GetAlbedoLods ( ) #
Returns the group of terrain albedo LODs.
Return value
Terrain albedo LODs group.
int AddDetail ( string name ) #
Adds a new detail to the vector of terrain details.
Arguments
  • string name - Detail name.
Return value
Number of the new detail.
int CloneDetail ( int num ) #
Clones the detail with the specified number.
Arguments
  • int num - Detail number.
Return value
Number of the new cloned terrain detail.
TerrainGlobalDetail GetDetail ( int num ) #
Returns the terrain detail with the specified number.
Arguments
Return value
Terrain detail.
void RemoveDetail ( int num ) #
Removes the detail with the specified number.
Arguments
void SwapDetail ( int num_0, int num_1 ) #
Swaps two details of the terrain.
Arguments
  • int num_0 - Number of the first detail.
  • int num_1 - Number of the second detail.
void ResizeDetails ( int size ) #
Resizes the vector of terrain details.
Arguments
  • int size - New size.
int AddMask ( string name ) #
Adds a new mask to the vector of masks.
Arguments
  • string name - Mask name.
Return value
Number of the new mask, if the mask was added successfully; otherwise, -1.
int CloneMask ( int num ) #
Clones the mask with the specified number.
Arguments
  • int num - Mask number.
Return value
Number of the new cloned mask.
void RemoveMask ( int num ) #
Removes the mask with the specified number from the vector of masks.
Arguments
void SwapMask ( int num_0, int num_1 ) #
Swaps two masks.
Arguments
  • int num_0 - Number of the first mask.
  • int num_1 - Number of the second mask.
void ReplaceMasks ( string[] names ) #
Replaces the list of masks with a given one.
If a mask used by some detail is missing in the new list, such detail will be considered as having no mask assigned, otherwise it will keep its mask.
Arguments
  • string[] names - New list of masks.
void ResizeMasks ( int size ) #
Resizes the vector of masks.
Arguments
TerrainGlobalLods GetMaskLods ( ) #
Returns the group of terrain mask LODs.
Return value
Terrain mask LODs group.
void SetMaskName ( int num, string name ) #
Sets the name of the mask with the specified number.
Arguments
  • string name - New mask name.
string GetMaskName ( int num ) #
Returns the name for of mask with the specified number.
Arguments
Return value
Mask name.
TerrainGlobalLods GetHeightLods ( ) #
Returns the group of terrain height LODs.
Return value
Terrain height LODs group.
TerrainGlobalLods GetNormalLods ( ) #
Returns the group of terrain normal LODs.
Return value
Terrain normal LODs group.
int FetchTopologyData ( double x, double y, out Vec3 ret_point, out vec3 ret_normal, out vec3 ret_up, int force = 0 ) #
Returns topology data for a given terrain point.
Arguments
  • double x - X coordinate of the point.
  • double y - Y coordinate of the point.
  • out Vec3 ret_point - World coordinates of the point.
  • out vec3 ret_normal - Normal coordinates.
  • out vec3 ret_up - "Up" vector coordinates.
  • int force - Force flag. Use 1 to load files in any case; otherwise, 0. The default value is 0.
Return value
1 if the topology data was fetched successfully; otherwise, 0.
Last update: 14.12.2022
