This example shows how to customize the mouse cursor appearance and change default mouse behavior in your application. It will help you to solve the following tasks:
- Changing the default mouse cursor image.
- Toggling mouse cursor's handling modes.
- Customizing your application's icon and title.
Defining Mouse Behavior#
- Grab - the mouse is grabbed when clicked (the cursor disappears and camera movement is controlled by the mouse). This mode is set by default.
- Soft - the mouse cursor disappears after being idle for a short time period.
- User - the mouse is not handled by the system (allows input handling by some custom module).
- In the Editor, by selecting the corresponding option in the Controls Settings
- Via code by adding the corresponding line to the logic (world or system logic, components, expressions, etc.)
engine.controls.setMouseHandle(MOUSE_HANDLE_SOFT);
//or
engine.controls.setMouseHandle(MOUSE_HANDLE_USER);
Customizing Mouse Cursor#
You can change the look of the mouse cursor in your application using any square RGBA8 image you want. This can be done by simply adding the following lines to your code (e.g. the world's init() method):
Image mouse_cursor = new Image("textures/cursor.png");
mouse_cursor.resize(mouse_cursor.getWidth(), mouse_cursor.getWidth());
if (mouse_cursor.isLoaded() && mouse_cursor.getFormat() == IMAGE_FORMAT_RGBA8)
engine.app.setMouseCursorCustom(mouse_cursor);
// show the OS mouse pointer
engine.app.setMouseCursorSystem(1);
Example Code#
- Sets a custom icon and title for the application window.
- Sets a custom mouse cursor.
- Switches between the three handling modes on pressing the ENTER key.
Insert the following code into your world script file.
// my_world.usc
// auxiliary variables
Controls controls;
Gui gui;
string handling_mode[3] = ("GRAB", "SOFT", "USER" );
// widgets
WidgetLabel label;
WidgetLabel label2;
WidgetButton button;
int init() {
controls = engine.game.getPlayer().getControls();
gui = engine.getGui();
Image icon = new Image("textures/cursor.png");
if (icon.isLoaded() && icon.getFormat() == IMAGE_FORMAT_RGBA8)
engine.app.setIcon(icon);
engine.app.setTitle("Custom Window Title");
// preparing UI: creating a label and a button and adding them to the GUI
label = new WidgetLabel(gui);
label2 = new WidgetLabel(gui);
button = new WidgetButton(gui, "BUTTON");
label.setPosition(10, 20);
label2.setPosition(10, 40);
button.setPosition(10, 80);
gui.addChild(label, GUI_ALIGN_OVERLAP | GUI_ALIGN_TOP | GUI_ALIGN_LEFT);
gui.addChild(label2, GUI_ALIGN_OVERLAP | GUI_ALIGN_TOP | GUI_ALIGN_LEFT);
gui.addChild(button, GUI_ALIGN_OVERLAP | GUI_ALIGN_TOP | GUI_ALIGN_LEFT);
// resize the image to make it square
int update() {
if (controls.clearState(CONTROLS_STATE_USE) == 1)
switch (engine.controls.getMouseHandle())
case MOUSE_HANDLE_GRAB:
if (engine.app.isMouseGrab())
engine.app.setMouseGrab(0);
engine.gui.setMouseEnabled(1);
log.message("MOUSE_HANDLE switch from GRAB to SOFT\n");
break;
case MOUSE_HANDLE_SOFT:
log.message("MOUSE_HANDLE switch from SOFT to USER\n");
break;
case MOUSE_HANDLE_USER:
engine.controls.setMouseHandle(MOUSE_HANDLE_GRAB);
log.message("MOUSE_HANDLE switch from USER to GRAB\n");
break;
default:
break;
// updating cursor position info
label.setText(format("\n MOUSE COORDS: %d, %d)", engine.app.getMouseX(), engine.app.getMouseY()));
label2.setText(format("\n MOUSE HANDLE: %s", handling_mode[engine.controls.getMouseHandle()]));
