TextureRamp Class
Interface for handling ramp textures. This class lets the user store 2d curves in a form of a texture (convert vectors to raster data).
Ramp textures can be used for color variation in the particles_base material of Particle Systems or in other custom materials.
You can set up to 4 channels for the ramp texture.
TextureRamp Class
Members
Texture getTexture() const#
Returns the current new texture and updates hashes for curves, if required. Returns a pointer to the texture or null if the texture was not created.
Return value
Current new texture.
void setNumChannels ( int channels ) #
Sets a new number of channels for the texture.
Arguments
  • int channels - The number of texture channels.
int getNumChannels() const#
Returns the current number of channels for the texture.
Return value
Current number of texture channels.
void setResolution ( int resolution ) #
Sets a new width resolution for the texture.
Arguments
  • int resolution - The texture width resolution.
int getResolution() const#
Returns the current width resolution for the texture.
Return value
Current texture width resolution.
void setFlags ( int flags ) #
Sets a new texture flags.
Arguments
  • int flags - The texture flags.
int getFlags() const#
Returns the current texture flags.
Return value
Current texture flags.
isDefaultAll() const#
Returns the current
Return value
Current
getEventChanged() const#
The event handler signature is as follows: myhandler()
Usage Example
Source code
Return value
Event reference.
static TextureRamp ( int num_channels, int resolution, int flags ) #
Sets resolution, number of channels and texture flags for this TextureRamp instance. The pointer to the ramp texture is set to null and curves are marked for an update.
Arguments
  • int num_channels - Number of texture channels.
  • int resolution - Width resolution of the ramp texture.
  • int flags - Texture flags.
TextureRamp ( ) #
void releaseTexture ( ) #
Deletes the texture and its pointer.
void copy ( TextureRamp src_texture_ramp ) #
Copies the data of a source ramp texture to the texture.
Arguments
  • TextureRamp src_texture_ramp - Source ramp texture.
TextureRamp clone ( ) #
Duplicates the ramp texture and returns a pointer to the copy.
Curve2d getCurve ( int channel ) #
Returns a pointer to the Curve2d for the specified channel.
Arguments
  • int channel - Required channel.
Return value
Pointer to a Curve2d object.
void setDefaultCurve ( Curve2d default_curve ) #
Resets a curve to a default one.
Arguments
  • Curve2d default_curve - A curve to be used as the default one.
void setDefaultCurve ( int channel, const Curve2d default_curve ) #
Resets a curve for the given channel to a default one.
Arguments
  • int channel - R, G, B, or A channel set by the corresponding value from 0 to 3.
  • const Curve2d default_curve - A curve to be used as the default one.
int isDefault ( int channel ) #
Returns a value indicating if the value of the given curve channel is the default one which was previously set via setDefaultCurve.
Arguments
Return value
1 if the curve value is the default one set via setDefaultCurve, otherwise 0.
void save ( Xml xml ) #
Saves the ramp texture data to the given Xml node.
Arguments
  • Xml xml - Target Xml node.
void load ( const Xml xml ) #
Loads the ramp texture data from the given Xml node.
Arguments
  • const Xml xml - Source Xml node containing ramp texture data.
void saveState ( const Stream stream ) #
Saves the state of the ramp texture into a binary stream.
Example using saveState() and restoreState() methods:
Source code (UnigineScript)
// initialize a node and set its state
// save state
Blob blob_state = new Blob();
ramp.saveState(blob_state);
// change state
// restore state
blob_state.seekSet(0); // returning the carriage to the start of the blob
ramp.restoreState(blob_state);
Arguments
  • const Stream stream - The stream to save the ramp texture state data.
void restoreState ( const Stream stream ) #
Restores the state of the ramp texture from the binary stream.
// save state
// change state
// restore state
Arguments
  • const Stream stream - The stream that stores the ramp texture state data.
Last update: 2024-03-27
