API Migration
Breaking Changes#
New HashMap/HashSet#
To improve performance and reduce memory consumption we have made some refactoring and optimization regarding Hash Maps and Hash Sets for this release. They both now store data linearly similar to vectors, which requires some changes in your code in case you have used them.
The findFast() method now returns a pointer instead of a double pointer:
UNIGINE 2.19 UNIGINE 2.19.1
ValueType **Hash::findFast(const KeyType &key) const
Unigine::HashMap<int, int> hash_map;
auto item = hash_map.findFast(0);
if(item)
   Unigine::Log::message("%d\n", (*item)->data);
ValueType *Hash::findFast(const KeyType &key) const
if(item)
   Unigine::Log::message("%d\n", item->data);
The emplace() method now returns an Iterator instead of a value:
ValueType &Hash::emplace(const KeyType &key)
Unigine::Log::message("%d\n", hash_map.emplace(0));
Iterator Hash::emplace(const KeyType &key)
Unigine::Log::message("%d\n", hash_map.emplace(0)->data);
HashMap vs BucketHashMap#
We've also kept the previous hash map implementation for backward compatibility and some specific cases, it is called BucketHashMap. Here is one of such examples, where the BucketHashMap must be used instead of the new HashMap - pointers to a key/value:
UNIGINE 2.19.1 - HashMap UNIGINE 2.19.1 - BucketHashMap
int *find(const HashMap<int, int> &hash_map, int key) {
	const auto &it = hash_map.find(key);
	if(it == hash_map.end()) return nullptr;
	return &it->data; //<-potentials crashes, use BucketHashMap
int *find(const BucketHashMap<int, int> &hash_map, int key) {
	return &it->data; //<-everything is ok!
AnimationPlayback Class#
Property Time Removed. Use the GetTime( ) method instead.
New Functions
New Properties
BootConfig Class#
CustomSystemProxy Class#
Decal Class#
Engine Class#
EngineWindowGroup Class#
New Properties
Image Class#
ImageConverter Class#
RunCpu( Image ) Renamed as RunCPU( Image ).
New Functions
Input Class#
InputJoystick Class#
LightEnvironmentProbe Class#
LightOmni Class#
LightProj Class#
Log Class#
New Properties
Material Class#
Materials Class#
CompileShaders( ) Removed. Use CreateShaderCache( bool ) instead.
New Functions
New Properties
NodeAnimationPlayback Class#
ObjectParticles Class#
Property LinearDamping Removed. Use LinearDampingOverTimeModifier( ) instead.
New Properties
Profiler Class#
Render Class#
Property QuadroSync Removed.
GetTemporaryTexture( Texture ) Removed. Use GetTemporaryTexture( Texture, string, Render.TEXTURE_ACCESSORY, Render.TEXTURE_LIFETIME, bool ) instead.
GetTemporaryTexture( Texture, string ) Removed. Use GetTemporaryTexture( Texture, string, Render.TEXTURE_ACCESSORY, Render.TEXTURE_LIFETIME, bool ) instead.
GetTemporaryTexture( Texture, string, int ) Removed. Use GetTemporaryTexture( Texture, string, Render.TEXTURE_ACCESSORY, Render.TEXTURE_LIFETIME, bool ) instead.
GetTemporaryTexture( int, int, int, int, int, int, string ) Removed. Use GetTemporaryTexture( int, int, int, int, int, int, string, Render.TEXTURE_ACCESSORY, Render.TEXTURE_LIFETIME, bool ) instead.
GetTemporaryTexture( int, int, int, int, int, int ) Removed. Use GetTemporaryTexture( int, int, int, int, int, int, string, Render.TEXTURE_ACCESSORY, Render.TEXTURE_LIFETIME, bool ) instead.
GetTemporaryTexture( int, int, int, int, int, int, string, Render.TEXTURE_ACCESSORY, Render.TEXTURE_LIFETIME, bool ) Set of arguments changed.
GetTemporaryTexture2D( int, int, int, int, string, Render.TEXTURE_ACCESSORY, Render.TEXTURE_LIFETIME, bool ) Set of arguments changed.
GetTemporaryTexture2DArray( int, int, int, int, int, string, Render.TEXTURE_ACCESSORY, Render.TEXTURE_LIFETIME, bool ) Set of arguments changed.
GetTemporaryTexture3D( int, int, int, int, int, string, Render.TEXTURE_ACCESSORY, Render.TEXTURE_LIFETIME, bool ) Set of arguments changed.
GetTemporaryTextureCube( int, int, int, int, string, Render.TEXTURE_ACCESSORY, Render.TEXTURE_LIFETIME, bool ) Set of arguments changed.
GetTemporaryOldTexture( Material, int, int, int, int, int, int, int, string ) Removed. Use GetTemporaryOldTexture( Material, int, Texture, string, Render.TEXTURE_ACCESSORY ) instead.
GetTemporaryOldTexture( Material, int, int, int, int, int, int, int ) Removed. Use GetTemporaryOldTexture( Material, int, Texture, string, Render.TEXTURE_ACCESSORY ) instead.
GetTemporaryOldTexture( Material, int, Texture, string ) Removed. Use GetTemporaryOldTexture( Material, int, Texture, string, Render.TEXTURE_ACCESSORY ) instead.
GetTemporaryOldTexture( Material, int, Texture ) Removed. Use GetTemporaryOldTexture( Material, int, Texture, string, Render.TEXTURE_ACCESSORY ) instead.
New Properties
New Functions
Renderer Class#
New Properties
ViewportData Class#
WallGroupData Class#
New Properties
World Class#
Manager Class (IG)#
Entity Class (IG)#
New Properties
Last update: 2025-04-23
