Unigine.ObjectMeshSplineCluster Class
Inherits from: Object
Properties
int NumMeshes#
The Number of meshes.
string MeshPath#
The path to the source .mesh-file used for the object.
Members
static int type ( ) #
Returns the type of the node.
Return value
Node type identifier.
mat4 GetMeshTransform ( int num ) #
Returns the transformation of the given mesh instance.
Arguments
  • int num - Mesh instance number.
Return value
Mesh transformation matrix.
bool GetClusterTransforms ( WorldBoundBox bounds, mat4[] OUT_transforms ) #
Collects transformations (local coordinates) for all spline cluster meshes within the area specified by the given bounding box and puts them to the specified buffer.
Arguments
  • WorldBoundBox bounds - Bounding box, defining the area, for which the transformations of spline cluster meshes are to be collected.
  • mat4[] OUT_transforms - Buffer to store transformations of spline cluster meshes.
Return value
true, if there are transformations of spline cluster meshes; or false, if there are no transformations of spline cluster meshes found.
bool GetClusterWorldTransforms ( WorldBoundBox bounds, mat4[] OUT_transforms ) #
Collects transformations (world coordinates) for all spline cluster meshes within the area specified by the given bounding box and puts them to the specified buffer.
Arguments
Return value
