ssl_socket_00
This article describes the <UnigineSDK>/data/samples/plugins/ssl_socket_00.cpp sample.
The ssl_socket_00 sample demonstrates how to create a secure network communication client.
It is required to launch the SSLSocket plugin before running the sample.
In this sample, the client sends the GET request to the local web server by using an SSL certificate and displays the server's answer. To get the server's answer, you should open both the ssl_socket_00 and ssl_socket_01 samples, otherwise the "Can't connect to localhost:4433" string will be shown instead of the encrypted answer.
Last update: 2021-12-13
